    Boot to rom using lr-mame2003-plus
    mame2003-plusautostart.sh
    37 Posts 4 Posters 6.9k Views
      mahoneyt944 @mitu
      @mitu I use:
      /opt/retropie/supplementary/runcommand/runcommand.sh 0 SYS arcade /home/pi/RetroPie/roms/arcade/cclimber.zip
      in my autostart.sh (boot to rom) and it works. Then I change it to:
      /opt/retropie/supplementary/runcommand/runcommand.sh 0 SYS arcade /home/pi/RetroPie/roms/arcade/tron2.zip
      and it doesn't work. Tron works when booting from es but won't load if I try boot from rom using my autostart.sh I noted that any rom that uses my default arcade emulator ( Mame 2003) works when using boot to rom via the autostart.sh .....only Tron, which uses Mame2003plus will not load using this method .
        Unless you're able to provide a detailed log file for RetroArch (via Runcommand), I can't help you further. There's no need to re-repeat your command line over and over.
        I advise you to exit Emulationstation, then launch the command line - like it's written in the autostart script- , use the launch menu (press any key during launching dialog) to enable verbose logging, get the /dev/shm/runcommand.log file and upload it to pastebin.com.
          mahoneyt944 @mitu
          @mitu well I'm at a loss now. I exited es like you said typed the same command line I've been trying and it boots to Tron just fine. I enabled verbose loging but it was successful so idk if that's going to help since it's not logging the error since it wasn't launched from the autostart file..... It seems the only time the command doesn't work is through autostart.sh otherwise it works as intended. https://pastebin.com/rNgn9vt2
            grant2258 Banned
            not looked into this but it could be autostart is running as root try
            sudo -u pi /opt/retropie/supplementary/runcommand/runcommand.sh 0 SYS arcade /home/pi/RetroPie/roms/arcade/cclimber.zip
              mahoneyt944 @grant2258
              @grant2258 ok I added the sudo -u pi part and was able to boot into verbose logging heres the file with error: https://pastebin.com/Jn7782aU
              still didn't boot with sudo command added.
                grant2258 Banned
                do you have a extra newline somewhere ?
                Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so --config /opt/retropie/configs/arcade/retroarch.cfg "/home/pi/RetroPie/roms/arcade/tron2.zip
                " --verbose --appendconfig /dev/shm/retroarch.cfg
                  grant2258 Banned
                  try
                  sudo -u pi -- /opt/retropie/supplementary/runcommand/runcommand.sh 0 SYS arcade /home/pi/RetroPie/roms/arcade/cclimber.zip
                    @grant2258 I tried
                    sudo -u pi -- /opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ arcade /home/pi/RetroPie/roms/arcade/tron2.zip
                    and
                    sudo -u pi /opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ arcade /home/pi/RetroPie/roms/arcade/tron2.zip
                    in my autostart file neither work....
                      @mahoneyt944 the (1st) log file you posted doesn't show an error, except this one:
                      [libretro ERROR] cpunum_get_localtime() called for invalid cpu num!
                      which I don't know if it's fatal (the ROMs seem to load fine), but doesn't look like there's any other error. Maybe there's a timing problem during boot that prevents RA from starting - can you disable the splashscreen (image/video) from the RetroPie-Setup ?
                      I see you're using RetroArch 1.7.1 and an older Mame2003-plus version, what version of RetroPie are you using ? Please add more details about it - https://retropie.org.uk/forum/topic/3/read-this-first.
                      I'll try to replicate the issue, but I'll have to install Mame2003+ first.
                      @grant2258 autostart.sh is executed as the pi user, after autologin; the initial command line was probably truncated during copy/paste.
                        OK, so it works for me, here's the content of my autostart.sh:
                        # emulationstation #auto
                        For the record, my splashscreen is set to a static image, the default one in RetroPie.
                          mahoneyt944 @mitu
                          @mitu I just fully installed a new image , it's 4.4.9 I believe. I could try to update retroarch though, not sure why it wouldn't be the newest... And my arcade cores too. I also use a video splash screen, the sonic one where he runs back and forth to make the retropie lettering. It seems my issue is specific to mame2003plus as I can boot to any rom using Mame2003 as the emulator.
                          What is the default retroarch when installing the new 4.4 image? Maybe retroarch has updated since that image was made.
                          Also, did you look at the second log file I posted?
                          See the end of the log where it fails.
                          Retropie 4.4.9
                          Rpi3b+ over clocked
                          New image installed beginning of March.
                            mitu Global Moderator @mahoneyt944
                            @mahoneyt944 said in Boot to rom using lr-mame2003-plus:
                            Is the ROM working when launched through Emulationstation ? You said it does.
                            Most likely yes, there is an update to 1.7.6 since the 4.4 image was released.
                            That one fails because if you're using su for the command line, so it's normal. The error message means that the ROM file cannot be found.
                            Retropie 4.4.9
                            Rpi3b+ over clocked
                            Is this a RetroPie image or a 3rd party image ? A fresh RetroPie image does not have the version 4.4.9.
                            DId you try disabling the splashscreen, as I said earlier, and see if the ROM starts ?
                              BuZz administrators
                              The error in your last log is due to a linefeed in the rom path.
                              and here:
                              [libretro INFO] [MAME 2003+] Content path: /home/pi/RetroPie/roms/arcade/tron2.zip
                              you need to put it all on one line without a newline in the middle.
                                mahoneyt944 @mitu
                                @mitu the image came from retropie, but I did update the script, update all from source, etc. I didn't try disabling the splash yet but I will in a bit.
                                The rom works perfectly launched from es and when I exit es and input it manually, just not from autostart.sh
                                  mahoneyt944 @BuZz
                                  @BuZz my autostart.sh only uses a single line. If it's getting more than that it Isnt from how it's typed in autostart.sh but maybe happening from something else or being interpreted oddly
                                    BuZz administrators @mahoneyt944
                                    @mahoneyt944 I can only say what's going on in the log - and in the log it has a LF or CR character before the end of the content. copy the autostart off your machine and upload it somewhere (so it's unmodified).
                                      mahoneyt944 @BuZz
                                      @BuZz
                                      I removed the #emulationstation #auto line 2 of the autostart.sh, and it worked. I didn't think that line would matter since it doesn't effect mame2003 roms launched the same way. Why does multi lines cause this issue? Is there a way to include multiple lines?
