    RetroPie 4.4 problem with XboxOneWireless connection
    retropie 4.4controller conconnection probxbox one contro
    2 Posts 2 Posters 2.9k Views
    • V
      voicy
      Hello there,
      I got some problems with my xbox wireless controller and i hope that someone here could help me.
      PI Model : 3B+
      Power Supply : USB Charger
      RetroPie Version : retropie-4.4-rpi2_rpi3
      Build From : retropie-4.4-rpi2_rpi3
      Guide used :
      I cant get my 3 Xbox Wirelesscontroller to work properly.
      All three of my controller are from the model 1708
      I could connect all three of them via the retropie bluetooth-menu, and every controller is lightning up when i start the raspberry
      but when i try to configure the controller via "Configure Input" i only get 1 Controller detected.
      That should be the reason
      How do i get my other 2 controller in there... or how do i connect them correct??
      I hope you can understand me and my problems and i would be very glad if someone could help me
        I remember a topic a month ago with a similar problem - the pairing of Xbox controllers worked, but they acted as a single controller. The solution was to install an alternate driver for the controller - xpadneo (https://github.com/atar-axis/xpadneo).
        If you want to give it a try, the installation is quite easy:
        • Remove any Bluetooth controller from the RetroPie script Bluetooth configuration.
        • Remove the xpad driver from the RetroPie setup script, from the drivers package section.
        • Install xpadneo (run this from the SSH session):
        git clone https://github.com/atar-axis/xpadneo.git
        cd xpadneo
        sudo ./install
        • Reboot and then redo the Bluetooth pairing for the controllers.
        See if you get 3 devices (/dev/input/event[0-2]) and Emulationstation detects all your controllers after the installation.
