    EASYGET LED arcade buttons and joystick are not being recognized by retro pie.
    retro piecontrollerhelpfirst installeasygetarcade buttons
    6 Posts 2 Posters 952 Views
      duck94
      It just says "No Gamepad Detected". Does anyone have any ideas on how to fix this? Im using a Raspberry Pi 3b+ with just retropi installed on the SD card. Was thinking about just buying a controller and configuring it with that, but as I plan to use this for mostly arcade games I am going to want the buttons and joystick operational. Let me know if you have any ideas, thanks!
        From the amazon's page:
        Q: Is there something special i have to do? neither board is being detected by retropie or on my windows machine when i plug it in via usb.
        A: Please change another 5Pin slot on the encoder board to install the USB Cable. You must have connected the USB cable to the wrong slot.
        Please have a try. You can get contact with us via message if you still have any issue.
          duck94 @mitu
          @mitu said in EASYGET LED arcade buttons and joystick are not being recognized by retro pie.:
          any
          I did read this in the comments, but still it did not work unfortunately. Still "No Gamepads Detected"
            mitu Global Moderator @duck94
            @duck94 So, did you try contacting them, as they suggest ? Maybe your unit is defective or there's something else that needs configured. Does it work on Windows/PC ?
              duck94 @mitu
              @mitu So what i find weird is that they did work on my old raspberry pi. It's just this new one. So i didn't know if there was something extra I need to download onto my SD card to get them connected. But from what I've heard from others, these normally do work with raspberry pi 3b+
                Well, the usual troubleshooting steps are
                • start with the RetroPie image from retropie.org.uk/download. It's a tested and mostly stock Raspbian image and the best baseline system to start experimenting.
                • make sure you have an adequate power supply and you don't get any under-voltage warnings.
                • test if the device is detected by the OS by running a few command line utilities
                # see what USB devices are connected with
                lsusb
                # see what input devices are detected by the OS and what kind (gamepad/keyboard/mouse/etc.)
                cat /proc/bus/input/devices
                • test if the device inputs are registered in the system by running a few joystick/gamepad testing programs fromt the command line that capture the button/joypad/d-pad presses and show them on the terminal:
                # 1st joystick
                jstest /dev/input/js0
                # 2nd joystick
                jstest /dev/input/js1
                # another testing utility
                evtest
