    questions about runcommand.sh
    runcommand
    32 Posts 5 Posters 16.1k Views
      BuZz administrators
      the PR didn't actually work btw - it would try and launch a script with the parameters as the name of the script. You would need to do bash "$configdir/all/runcommand-onstart.sh" "$@" not bash "$configdir/all/runcommand-onstart.sh $@"
        BuZz administrators
        implemented in https://github.com/RetroPie/RetroPie-Setup/commit/0c39c7438b7986997313e74707e9873e820bbfa1
          meleu @BuZz
          @BuZz Really cool man! Thanks!
            Another runcommand question:
            Why runcommand.log went to /dev/shm?
              BuZz administrators
              ram based.
                meleu @BuZz
                @BuZz
                one more question...
                Premise: thinking in RetroArch only.
                I'm using runcommand-onstart.sh to change a system specific's retroarch.cfg before launching the game. Is the $system passed to runcommand-onstart.sh a valid configdir?
                In other words, can I use /opt/retropie/configs/$system/retroarch.cfg?
                I'm doing this way and it's working fine for the classic consoles (atari2600, nes, snes, megadrive, etc...). But I'm worried if this will work for any libretro emulator.
                  BuZz administrators @meleu
                  @meleu yes.
                  https://github.com/RetroPie/RetroPie-Setup/blob/master/scriptmodules/supplementary/runcommand/runcommand.sh#L119-L123
                    meleu @BuZz
                    @BuZz
                    (* sigh * here I go bother you again...)
                    would you mind to export the log variable in runcommand.sh?
                    reason:
                    make it accessible in runcommand-on{start,end}.sh.
                    use case:
                    Since users can execute custom commands in runcommand-on{start,end}.sh some bugs can be inserted.
                    It would be a good practice for those who want to write something in these scripts, to log some info for bug tracking.
                    Another benefit: It helps us to help inexperienced users with problems because of third-party on{start,end} scripts.
                      BuZz administrators
                      Just write your own log or use the same filename. Actually, I will redirect stderr to the log, so errors will get logged automatically.
                      meleuM 2 Replies Last reply Reply Quote 1
                        meleu @BuZz
                        @BuZz
                        Oh! You did it!
                        I'll redirect log messages to stderr. Thanks again!
                          meleu @BuZz
                          @BuZz
                          Don't you think that would be useful to register the start/end of the runcommand-on{start,end}.sh?
                          The goal is to facilitate problem diagnosis in runcommand.log. Example: If some user has problems on launching a game because of a bad runcommand-onstart.sh and don't know it, he can paste his runcommand.log and this info would help the diagnose.
                          I was thinking in something like this:
                          # calls script with parameters system, emulator, rom, and commandline
                          function user_script() {
                              local script="$configdir/all/$1"
                              if [[ -f "$script" ]]; then
                                  echo "--- start of \"$script\" ---" >> "$log"
                                  bash "$script" "$system" "$emulator" "$rom" "$command" </dev/tty 2>>"$log"
                                  echo "--- end of \"$script\" ---" >> "$log"
                              fi
                          [EDIT: I know we can register this info using the script itself, but not everyone follows this good practice.]
                            @meleu I don't. Runcommand will continue even if there is an error. Please try to not constantly send me questions and requests.
