    PC Engine to TurboGrafx in Simple Theme for Pi Zero W not working
    simpleturbografx-16themepi zero wtheme help
    4 Posts 2 Posters 724 Views
    • saikyo78S
      saikyo78
      Hi! I just bought a raspberry pi zero W, and I'm starting a new retropie image from scratch. I downloaded the latest retropie image and updated it, and I have an existing pi 3b image, so I then copied over my:
      • gamelists
      • image files
      • roms
      • bios files
      I also wanted to change the megadrive to genesis, and pc engine to turbografx, and I'm using the simple theme. To do this, I created a platforms.cfg text file that says:
      megadrive_theme="genesis"
      megadrive_platform="genesis"
      pcengine_theme="tg16"
      pcengine_platform="tg16"
      I've also updated all my main/optional packages from binary and rebooted. The genesis looks great! The PC Engine, however, looks like this:
      I've also tried to update my es_systems.cfg to reflect Turbografx, but it still will not update. Can you all tell me if you've ran into a similar problem, and how to fix it? What's strange is that I don't have a platforms.cfg on my old pi 3 image (and my es_systems.cfg file still says pc engine), so I'm not sure how I have it working on the pi 3 and not on the Zero. Thank you all so much for your help!
      • Lyle_JPL
        Lyle_JP
        Not all themes recognize platform="tg16". IIRC, the simple theme actually uses Turbografx theming by default, so just leave theme and platform on "pcengine" in the .cfg and it should work.
        saikyo78S 1 Reply Last reply Reply Quote 0
        • saikyo78S
          saikyo78 @Lyle_JP
          @Lyle_JP I am a big dummy, and this fixed it - thank you so much!!
          Lyle_JPL 1 Reply Last reply Reply Quote 0
          • Lyle_JPL
            Lyle_JP @saikyo78
            @saikyo78 My pleasure.
