    Any way to power on PC with DualShock 4 controller?
    ds4 bluetoothds4dualshock 4x86ubuntu
    5 Posts 3 Posters 2.0k Views
      Panja
      Maybe not the right forum to ask... But I guess a lot more people will have the same question so here is goes...
      I have 2 DualShock 4 controllers hooked up through bluetooth to my Ubuntu x86 machine.
      All is working well. Though it would be awesome if I press the PlayStation home button it'll power on my computer.
      Is this something that can be done?
      Does someone have this working already? :)
      ParabolaralusP 1 Reply Last reply Reply Quote 0
      • ParabolaralusP
        Parabolaralus @Panja
        @Panja I'm sure there's a way, but it's probably not going to involve just the PC as I have yet to see a BIOS/UEFI that has any BT config which would be required.
        What I think could work is if you setup a Pi that scans for BT devices constantly and if it sees your dualshock 4 controllers send a wake on lan packet to the PC which then fires it up. The PC would need to be wired though. Just theorizing so don't ask me any more then what I already said!
        Askubuntu.com might be a good place to ask as well.
        P 1 Reply Last reply Reply Quote 2
          Panja @Parabolaralus
          @Parabolaralus
          Thanks for thinking with me!
          • HalvhjearneH
            Halvhjearne
            you may be able to have it wake from sleep, but idk if it will then react to any bt device near aswell, which would be a pain as it would turn on for any bt device broadcasting.
            personally i had to disable wake from my bt device as my mouse would instantly wake the pc again when i tried to put it to sleep.
              Panja
              After hearing the replies I think I will just power it on with the front button.
              Thanks for the replies!
