    Auto-Load pacman Rom
    pacmanauto-load
    12 Posts 4 Posters 1.8k Views
    • F
      Fredthedoggy
      I just got a Raspberry Pi 0 and set up retro pie. my goal is to make a scale PAC-MAN machine currently my autostart.sh is
      /opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ nes ~/RetroPie/roms/nes/pacman.zip
      When I boot It goes through all the boot commands, and other setup processes, and then the screen goes dark for 20 seconds or so. then it shows the retropie logo (In Text) with uptime, temp, and other useless things. I can run the command
      EmulationStation
      to open the emulators, but It wont go into the pacman game. (I can open the game manually though)
      Summary:
      I want my retropie to boot into pacman, but even with what I think is a correct autostart.sh it doesnt work. What is the correct command to open the pacman NES rom on start?
        The command you posted seems correct, it works for me (minus the ROM name). I guess the command fails and that's why you get the login prompt after boot.
        What's in /dev/shm/runcommand.log right after you try to auto-boot the game ?
        • F
          Fredthedoggy
          Is says:
          Failed to open ~/RetroPie/roms/nes/pacman.zip:  No such file or directory
          the thing is, I know that that is the filename
          mituM 1 Reply Last reply Reply Quote 1
            mitu Global Moderator @Fredthedoggy
            @Fredthedoggy What is the output of the following command ?
            ls -lh ~/RetroPie/roms/nes/pacman.zip
            Also, post the complete autostart.sh file.
            • F
              Fredthedoggy
              @mitu that was the full file (/opt/retropie/supplementary/runcommand/runcommand.sh 0 SYS nes ~/RetroPie/roms/nes/pacman.zip) is that not the full thing?
              • F
                Fredthedoggy
                @mitu The command you gave me? it said
                ls cannot access '~/RetroPie/roms/nes/pacman.zip': No such file or directory
                mituM lostlessL 2 Replies Last reply Reply Quote 0
                  @Fredthedoggy This means the file is not present there - so the Runcommand cannot run the ROM. You'll need to copy the ROM to the right place and re-try - how did you transfer the ROM to RetroPie and where ?
                  • lostlessL
                    lostless @Fredthedoggy
                    @Fredthedoggy maybe try unzipping the rom and use the .nes file?
                    • F
                      Fredthedoggy
                      @lostless So put the .nes file in the nes folder directly?
                      • lostlessL
                        @Fredthedoggy yes. Sometimes the zip files you find have multiple versions of a game and may confuse the emulator.
                        • F
                          Fredthedoggy
                          Thanks for the advice guys, but turns out I have to press ctrl+\ not ctrl+' for tilda
                          Thank you.
                          • DNunoD
                            DNuno
                            Well, I got the same idea. My objective was to start a mame game (Star Wars) automatically.
                            After spending some time to set up this, I wanted to share the solution to complete the explanation available of the Retropie FAQ.
                            So here's the content of my autostart.sh file :
                            pi@nunopi:/opt/retropie/configs/all $ more autostart.sh
                            /opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ "mame-libretro" "/home/pi/RetroPie/roms/mame-libretro/starwars.zip"
                            It works as expected! Quite easy with an example now :-)
