    Issue with twin usb controllers for arcade sticks
    sj@jxarcade controll
    11 Posts 3 Posters 4.0k Views
      mburry83
      Hey
      I am having issues with the arcade controllers i purchassed from amazon they are the SJ@JX model.
      i have retropie x86 installed on a pc with ubuntu linux
      the problem i am comming across is it is a single usb board controlling 2 arcade sticks, and when i try and set them up it is only works for 1 player it will not distinguish the difference from the 2 sets of switches. i did try and serch it but the closes thing was to edit the cmdline.txt file but i dont have one.
      please help
        Have you checked the Xin-Mo doc page ? If you're trying to set up something similar, then for a normal PC use the alternative method to add the usbquirks parameter, by creating a new configuration file in /etc/modprobe.d.
          mburry83 @mitu
          @mitu i have just tried this method but the pc still does not recognize the controller as 2 different controllers
            mburry83
            hi i have tried this method
            I have the same USB controller and finally got it recognized as 2 controllers in Emulationstation:
            The solution: You must set a "quirk" for the usbhid module
            Follow the instructions here:
            Be aware that the vendor / product ID might differ. (Check via lsusb, the USB name for the double usb CY-2121 controller is "Personal Communications Systems, Inc")
            https://github.com/RetroPie/RetroPie-Setup/wiki/Xin-Mo-Controller
            I'm using RetroPi via Ubuntu 16.04, so here's how I managed this for Ubuntu:
            Search for the vendor ID / Product ID via lsusb
            create a file named "usbhid.config" under /etc/modprobe.d/"
            Add the following line to the file: "options usbhid quirks=0x0810:0xe001:0x00000040"
            0810 is the VendorID
            e001 is the product ID
            Save the file
            run "sudo update-initramfs - u - k $(uname -r)"
            Restart your PC
            check via "cat /sys/mmodules/usbhid/parameters/quirks", if the quirk has been applied successfully
            Take al look into "/dev/input": There should be a js0 and a js1 now
            but i cannot get it to work
            then i tried this command
            sudo rmmod usbhid && sudo modprobe usbhid quirks=0x0810:0xe301:0x00000040
            it works but is gone the next time i boot the machine
            am i doing something wrong
              mitu Global Moderator @mburry83
              @mburry83 The file name you create in /etc/modprobe.d must be named .conf , not .config.
                mburry83
                I did see that issue and it is rename to .conf
                  @mburry83 Post the exact content of that file and the complete filename.
                    mburry83
                      @mburry83 said in Issue with twin usb controllers for arcade sticks:
                      Your command line is different than the content of the file - the USB VendorID/ProductID in the file are not the same.
                      Replace the contents of the .conf file with:
                      options usbhid quirks=0x0810:0xe301:0x040
                        mburry83
                        Thank you I had just noticed that. All working now
                        • HalvhjearneH
                          Halvhjearne
                          @mburry83
                          the way it says in the docs might not work anymore, i had to add it to grub or it would not accept it:
                          GRUB_CMDLINE_LINUX_DEFAULT="quiet splash usbhid.quirks=0x16c0:0x05e1:0x040"
