    (SOLVED) Secret of Mana Hi-res problem
    hiressommanafiltersnes
    1 Posts 1 Posters 985 Views
    • thelostsoulT
      thelostsoul
      I had a problem and found what it caused. I post the description and solution here, so whenever someone searches and finds this, it might help. The problem was, if I go into Game select screen in Secret of Mana, where you can select game file, the screen looks odd, like in the picture (twice+artifacts). It has something to do with the Hi-res mode in some screens. You can enable and disable Hi-res mode in emulator, but both look wrong.
      Solution: If your screen looks like this, you most probably have enabled an emulator filter called Blargg NTSC filter. Disabling will make it look normal again. This problem occurred with the emulator Snes9x 1.60 and I didn't tested any other. I am curious, do you experienced this bug ever? And if so, which emulator and game?
      📜 RE/SET: 100 SNES Games for your RetroPie, 🎁 Share your hidden gems and insider tips
