    I need help with Rertropie login
    loginretropieretropie-setupretropie longinfix login
    5 Posts 3 Posters 455 Views
      marc_mib
      All was installed good and played then l went and install something in the experimental stuff (stupid me) then l logged off then turned on the pi but it keeps going in pi@retropie:~ $ please can someone help me. I have a keyboard to my pi. IMG_20191016_224205__01_6091_3998.jpg
      • herb_fargusH
        herb_fargus administrators @marc_mib
        @marc_mib could always do a sudo reboot
        See also https://retropie.org.uk/docs/Updating-RetroPie/
          marc_mib @herb_fargus
          Still boots in pi@retropie:~ $
            Maybe you disabled the auto-boot to emulationstation, though looking at your command line mishaps I see you managed to type emulationstation and you didn't get a response.
            As a rule of thumb - commands are case sensitive in Linux, so retropie-setup is not the same as RetroPie-Setup . Try
            sudo $HOME/RetroPie-Setup/retropie_setup.sh
            and that will start the setup script. Re-install Emulationstation from the setup and then reboot.
              marc_mib @mitu
              Thanks for your help
