    Making Fonts Readable on 1Up Pi-Boy XL
    pi3 model b1up
    4 Posts 3 Posters 700 Views
      phil8715
      Hi,
      I'm a newbie.
      I've bought a 1Up Pi-Boy XL which uses a Raspberry Pi 3B+.
      When I go into the menus the text is so tiny I have to hook it up to a monitor via hdmi.
      I pressed F4 to get to the terminal screen and entered the required commands, also I tried to look at all the fonts but without seeing that the fonts are I'm fighting a losing battle.
      The screen is 4.3 inch screen.
      Any font recommendations would be appreciated.
      Thank you in advance.
        For console fonts, see https://retropie.org.uk/docs/FAQ/#how-can-i-increase-the-console-font-size. For Emulationstation, choose a minimal theme like CRT Centered or the - recently added - [MiniJawn theme](link url).
          phil8715 @mitu
          @mitu I'm not sure if I stated correctly what I was trying to do.
          Basically I'm trying to make the text on the dos type screen larger to make it readable on the Pi-boy.
          I'm not trying to make the games appear larger as I already know how do this. At present I'm having to connect my 1UP Pi-Boy XL to a monitor so I can assess the settings screens.
          My GPI Case doesn't have this issue.
          I'm trying to find an image on the Pi-Boy that is set up in such a way that I don't need to connect it to a monitor to read and change settings as required.
          Thanks in advance.
            dankcushions Global Moderator @phil8715
            @phil8715 said in Making Fonts Readable on 1Up Pi-Boy XL:
            that’s what the console font link above achieves. (“console” in this context = dos type screen)
