    Solution for " White Screen of Death "
    145 Posts 20 Posters 100.8k Views
    • CybermenC
      Cybermen
      Hi, maybe someone has already found out whether there is a solution for " White Screen of Death ". https://github.com/retropie/retropie-setup/wiki/themes .
      I have more than 10 system running on Retropie and would like to use the Zoid Theme ?
      I currently have version 3.7 installed.
      Thank you very much.
      • Z
        Zigurana
        From that link you included: https://github.com/retropie/retropie-setup/wiki/themes#white-screen-of-death
        Its a fundamental design flaw in emulationstation, so unless someone takes up the task to recode significant parts of the theming of ES, there is no solution.
          dankcushions Global Moderator
          @Cybermen said in Solution for " White Screen of Death ":
          the wiki page lists 3 solutions!! the top one seems like it would be most suitable for you. have you tried it?
          • CybermenC
            Cybermen
            Hi, I tried the first option . With different settings , but unfortunately it did not work for me
              dankcushions Global Moderator @Cybermen
              @Cybermen what setting did you try? post your /boot/config.txt and we can verify.
              • ProxyCellP
                ProxyCell
                Which raspberry pi model do you have?
                Please consider merging some systems together to reduce the overall burden.
                RPi3b+ - No overclock
                RetroPie - latest from Github, as always
                2x SF30 Pro 8Bitdo controllers
                • CybermenC
                  Cybermen
                  I have the Raspberry PI 3. This ist my config.txt:
                  # http://www.raspberrypi.org/documentation/configuration/config-txt.md
                  #hdmi_safe=1
                  #disable_overscan=1
                  #overscan_left=16
                  #overscan_right=16
                  #overscan_top=16
                  #overscan_bottom=16
                  # overscan.
                  #framebuffer_width=1280
                  #framebuffer_height=720
                  #hdmi_force_hotplug=1
                  #hdmi_group=1
                  #hdmi_mode=1
                  #hdmi_drive=2
                  # no display
                  #config_hdmi_boost=4
                  # uncomment for composite PAL
                  #sdtv_mode=2
                  arm_freq=1300
                  core_freq=500
                  over_voltage=2
                  #dtparam=i2c_arm=on
                  #dtparam=i2s=on
                  #dtparam=spi=on
                  # Uncomment this to enable the lirc-rpi module
                  #dtoverlay=lirc-rpi
                  dtparam=audio=on
                  gpu_mem_256=128
                  gpu_mem_512=256
                  gpu_mem_1024=256
                  overscan_scale=1
                  gpu_mem=256
                  I tried it by gpu_mem= with: 256, 384, 512, 640
                  dankcushionsD herb_fargusH 2 Replies Last reply Reply Quote 0
                    ahhh, but if you read the wiki page, that setting will do nothing for you:
                    https://github.com/RetroPie/RetroPie-Setup/wiki/Memory-Split
                    Also note that in order to ensure sensible memory splits across Pi models, RetroPie utilises the gpu_mem_256, gpu_mem_512 and gpu_mem_1024 overrides, which apply to Pis with that amount of memory (for example, the Pi 2 has 1024MB memory, so will use the gpu_mem_1024 setting). This setting overrides the gpu_mem setting that is described below, so if you still want to adjust the memory split, you will have to manually edit /boot/config.txt and adjust the relevant value, or delete the lines entirely.
                    ie, for a raspberry pi 3, you want to edit
                    gpu_mem_1024 = 256
                    keep raising it till it works for you :) 384 should be safe and fix it.
                    • herb_fargusH
                      herb_fargus administrators @Cybermen
                      @Cybermen please format code blocks properly as described on the read this first page on my signature
                      • CybermenC
                        Cybermen
                        Wow , many thanks dankcushions . it works beautifully ! I have the Wiki read but unfortunately misunderstood , you have brought me only on the right way , many thanks . problem solved , so it works .
                          BuZz administrators
                          I added formatting to his post.
                            edmaul69 @dankcushions
                            @dankcushions said in Solution for " White Screen of Death ":
                            gpu_mem_1024 = 256
                            So i use the carbon theme but i have custom made themes on the gamelist for 11 systems. If i add 1 or two more i end up with it locking up scrolling through the games. If i add 3 i get a white screen. On my pi 3 if i change the 1024 to 384 it still white screens on the same amount of themes as on 256. Any clue why that change wont fix it. I can post my config.txt if i need.
                            RookervikR 1 Reply Last reply Reply Quote 0
                            • RookervikR
                              Rookervik Global Moderator @edmaul69
                              @edmaul69
                              There's a minimum amount of VRAM required to display certain size wallpapers. If you have just 1, 1920x0180 wallpaper, you MUST have 256 meg RAM split. But that 256 RAM split will take you up to 10 or so wallpapers. The next jump is probably 512 split. Which should still be just fine with most of the emulators that the Pi can handle.
                              You can make sure your theme wallpapers are 720p and that will help you with the RAM issues. ES was not designed for the Pi, but it works.
                              The Carbon theme was designed for the Pi's limited video RAM just for the white screen problems. If you're going to make some custom themes, try thinking in 'parts' instead of 'wallpapers.' Several 512x512 images take less VRAM than a 1920x1080 wallpaper. Try to re-use elements so ES doesn't have to fill VRAM with a massive picture.
                                BuZz administrators
                                Thread moved - help questions should go to the help & support area.
                                  edmaul69 @Rookervik
                                  @Rookervik said in Solution for " White Screen of Death ":
                                  @edmaul69
                                  On the system select screen it is still carbon on the inside its custom. the pics are really really tiny because i made them previously on the simple theme and it uses the stretching. Most of the pics are around 10x10 pixels. They have different fonts in each console though. The fact that i can have eleven of them on 256 megs but cant have 14 of them on 384 makes no sense.
                                  • RookervikR
                                    @edmaul69
                                    That is very strange. A 10x10 pixel image will take the VRAM of a 16x16 image. Everything unwraps to a power of 2. As long as these images are not SVGs. An SVG stretched to full screen takes a canvas to display, and that canvas takes the full VRAM of that area. So even if the SVG has a single line in it, and the file size is 0.5kb, it will take the same VRAM as a 1080p PNG uncompressed. Fonts shouldn't take too much RAM, and they are regular RAM. Try 512 RAM split. 384 hasn't ever made any difference for me before.
                                    If you're still bothered by things, you can try zipping up the theme and sending it to me. I can look at it and figure out what you problem is.
                                      edmaul69 @Rookervik
                                      @edmaul69
                                      So changing the
                                      gpu_mem_1024=500
                                      made absolutely no difference. Most of my themes have an 8x8 solid color block. Maybe 2 of them. If they need a stripe on the top it might have a 1x343 pic. A few of the ones i have working have a pic of woodgrain or metal for the top or bottom less than 350x350. None of the 3 / 4 themes i am trying to add use more than 2 8x8 pics. None of the ones i am trying to add have a pic bigger than 8x8.
                                      EDIT: is there a way to verify how much ram is being used for the gpu? I have a whole extensive overclocking list of stuff that i got from someone online for running n64 games and when i had it all set in the config.txt it made absolutely no improvements. And that had my cpu overclocked at 1450 and i saw no improvement. So im not sure if the themes my problem now or if overclocking and ram split is a problem. I have to have force_edid_audio for the sound to work on my tv but i wouldnt think that would affect this. It tells me it cant be overclocked in raspi-config on both 3.7 and 4.0 beta 2. I will start a new thread on the config.txt problems if that is my issue
                                      • RookervikR
                                        @edmaul69
                                        So tell me, is this white screen a completely white screen, so you can't see anything, or is it a white theme with none of your theming elements? From what you're saying, you are actually using less assets than Carbon itself. Which can load 60 systems without RAM issues. Does your theme look like this when you load it? If so, the theme xml files have errors in them.
                                        Also, keep in mind that the RAM splits should stay in powers of 2. Just like any images you use in the theme. 2, 4, 8, 16, 32, 64, 128, 256, 512, 1024, 2048, 4096... Your 1x343 image uses the same RAM a 512x512 image would take, as does the 350x350 image. They all unfold to a power of 2 in VRAM.
                                          edmaul69 @Rookervik
                                          @edmaul69
                                          No my theme stuff is not blank. All the themes i have added and are trying to add all work. I just boot to a pure white screen when i have too many of them.
                                          • RookervikR
                                            @edmaul69
                                            Welp, I've suggested everything I can think of. I've made 3 or 4 themes and if you keep the assets small in size then you don't run into memory issues. You say your assets are small, so I can't really figure out what the problem is. Sorry. :(
