    OrangePi PC Plus - USB Rom issue - hope you can help
    retrorangepieorange pi pcpc plusretropieroms
    3 Posts 3 Posters 743 Views
      duke2k7
      Hey folks, I've looked through the forums with specific searches but I can't seem to find a topic that gives me any help (not necessarily the answer as I'm here to learn).
      Basically I am used to Retropie on the Raspberry range of boards, but I had an Orange Pi PC Plus gifted me and wanted to have a tinker.
      When I place a fat32 formatted usb thumb drive into the Orange Pi, the same doesn't happen as when I do it with the Raspberry Pi. It doesnt create the folder list for roms like the Raspberry Pi does, in fact it does nothing at all.
      I have tried the following:
      1. create 'retropie-mount' in the root of the USB, inserted etc, no joy.
      2. create 'retropie' in the root of the USB, inserted, same result.
      I couldn't even see the USB roms option in the setup menu, only samba shares. The Orange Pi PC Plus doesn't have WiFi so i wont be using samba.
      Ive searched for this on g o o g l e but i keep getting the same result; the 'automatic' method which simply isnt working.
      Hopefully one of you guys or gals has some advice I can use?
      Many thanks,
        BuZz administrators @duke2k7
        @duke2k7 We don't support this board. It's not running official retropie.
        • herb_fargusH
          herb_fargus administrators
          You could try lakka
