Raspberry Pi4 Retropie Setup Problem
Hello, I am new to the raspberry community but I recently bought a raspberry pi4 with the Cana kit and a128gig sd card. About a week ago I successfully installed Raspbian and retropie and was playing multiple games without a problem. A few days ago I tried to remove the blank out timer screen with some script I found online and after a reboot the device would not display anything. I decided to wipe the sd card clean and start from scratch. I did the exact same steps I did prior l. Raspbian works fine but went I got to install retropie I keep getting an error that binary sdl2 is unable to install and therefore will not install emulationstation or retroarch. If I set the platform for rpi2 in the retropie_packages.sh then all installs fine but I cant use emulationstation or retroarch. Not sure if this on me or if something changed in the download. Anything help would be appreciated. Thanks
@GreatWhite82 said in Raspberry Pi4 Retropie Setup Problem:
binary sdl2
I did a fresh install on my Pi3 and did the usual "update all components" and I too have been getting "binary sdl2 is unable to install " errors.
RPI4 is not yet supported. If you are using the development branch don't expect stuff to work all the time - and currently binaries are being built for it etc.
Neither of you provided any information as agreed when registering and in the sticky topics
I understand they haven't made retropie for the 4 yet but as I said if you set the platform to 3 it will work and it did work for me about a week ago. As far as the rules, I read them and I'm not sure what other information you would like. I was trying to keep it short and not write a lengthy novel on my entire set up. Also being new to all this how bout you cut me some slack. Thanks
@GreatWhite82 No need for the attitude - I am simply informing that you should provide more information when requesting help.
I believe the issue @mat bumped into is related to sdl1 not sdl2 - which is being fixed now. The more information you provide the easier it is for us to help.
Can not advise on RPI4 without more information about set-up as to how you installed etc.
@GreatWhite82 Administrators like to walk around and yell at people just because they can. Personally I would have just told this
bunch of lovely and happy words deleted
. Ban me I don't give tworats
! Have a great day! -
@LinuxGuy2020 Your wish is granted. If you just registered to insult people, then go find another avenue to vent your frustrations.
this actually has been solved, follow the steps exactly here, and you'll fix that SDL2 error. i had the same thing and this fixed it.
https://retropie.org.uk/forum/topic/23984/solved-rpi4-sdl2-problem-during-installation-meanwhile-its-available-via-apt-get
