    Having issues running games from USB drive
    retropie-mountusb driveadding roms
    3 Posts 2 Posters 459 Views
    • MurchedM
      Murched
      Pi Model or other hardware: Rasberry Pi 3B+
      RetroPie Version: 4.5.1
      USB Devices connected: SanDisk Cruzer Blade 64Gb
      Hi, guys.
      I'm experiencing some weird behavior from retropie when trying to add new games to my library and I'm wondering if it's a known issue. I'm running my games from a USB drive using the retropie-mount function described at the github wiki.
      I have a relatively small library of games (less than 500) working from different systems (even dreamcast and playstation that people usually have problems getting to work). My issue is, when I try to add new games, they do not work. I tested the new roms on a fresh mount and they work flawlessly. The problem only seem to happen when I try to add new games after some time using the same USB mount.
      The games I had before continue to work after I add the new ones.
      The issue is persistent. Happened 3 times already with 2 different USB drives (one formatted FAT32 and the other ExFAT).
      Have anyone experienced this before?
      Thanks!
        dankcushions Global Moderator
        how do you mean "they do not work"? what happens? can you post a log as per https://retropie.org.uk/forum/topic/3/read-this-first ?
        • MurchedM
          Murched
          Sorry for being vague.
          The games go through the usual runcommand launch menu, then black screen, then back to games list.
          The runcommand log for a nes game look like this:
          Parameters:
          Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-fceumm/fceumm_libretro.so --config /opt/retropie/configs/nes/retroarch.cfg "/home/pi/RetroPie/roms/nes/Metroid (USA).zip" --appendconfig /dev/shm/retroarch.cfg
          And for a PSX game look like this:
          Parameters:
          Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-pcsx-rearmed/pcsx_rearmed_libretro.so --config /opt/retropie/configs/psx/retroarch.cfg "/home/pi/RetroPie/roms/psx/Alundra.PBP" --appendconfig /dev/shm/retroarch.cfg
          Memcard 2: disabled
          Starting PCSX-ReARMed
          Running PCSX Version 1.9 (May 28 2019).
          psxMap: warning: wanted to map @80000000, got 0x6f50a000
          Init new dynarec
          testing if we can run recompiled code..
          test passed.
          warning: RAM is not directly mapped, performance will suffer
          Mapped (RAM/scrp/ROM/LUTs/TC):
          77000000/1f800000/1fc00000/08000000/7018f000
          found BIOS file: SCPH101.bin
          RGB565 supported, using it
          plugin: plugins/builtin_gpu
          plugin: plugins/builtin_spu
          plugin: plugins/builtin_pad
          Plugins loaded.
          Loaded CD Image: /home/pi/RetroPie/roms/psx/Alundra.PBPbad psar_sig:
          selected sound output driver: libretro
          Both these games work on a fresh mount, but not on my current library.
          Thanks.
