    Mame installation in RetroPie (HELP)
    mameretropieubuntu 18.04
    12 Posts 3 Posters 1.1k Views
      A Former User
      Hello everyone, today i have installed RetroPie in Ubuntu 18.04.3, AMD FX eight core processor, AMD RADEON HD 5750
      normally works perfect (joypads installation) but there isn't any emulator, i have the roms but not the emulators, i don't know how to install mame or another emulator in retro pie (I have see the GitHub page and confused), anyone can send me the steps for install mame or another emulator in retro pie or send me the files of the mame emulator for put in retro pie?¿
      Thank you ;)
        If you used the documentation to perform a manual installation, then the MAME/Arcade emulators are already installed, you just have to copy the ROMs to their place and then restart Emulationstation - they'll appear in their respective systems (Mame/Arcade).
          A Former User
          No, he doesn't detect my roms
            Where did you copy them ? How are the files named ? Can you give some examples of ROMs you copied and where ?
              A Former User
              the rom files are, bombjack.zip and pitfall.zip
                I couldn't find any MAME rom named pitfall.zip, though there is a bombjack romset (http://adb.arcadeitalia.net/dettaglio_mame.php?game_name=bombjack&arcade_only=0&autosearch=1).
                Are you sure these are MAME roms ? Which folder did you use ?
                  A Former User
                  Hello, can anyone send me the mame emulator files for retropie? thanks ;)
                  mituM 1 Reply Last reply Reply Quote -1
                    mitu Global Moderator @A Former User
                    @Ludgie Please don't open multiple topics with the same subject.
                      A Former User
                      This post is deleted!
                        A Former User
                        thanks, i will go to use only mame, thank you for the help
                          If you'd like to help you diagnose and fix the problem, you'll have to provide more info - see my last questions.
                            Clyde
                            One reason the roms don't show up could be the Option "Parse Gamelists Only" in Emulation Station's Main Menu -> Other Settings (Screenshot). It should be set to OFF to see every zip file in the rom directories in Emulation station. If they will run, however, depends on the correct rom/emulator combination, see https://retropie.org.uk/docs/Arcade/.
