    Pcsx_rearmed ignores the offset settings
    pcsx-rearmed
    15 Posts 4 Posters 411 Views
      reruns_towel
      I have Retropie 4.5 running on a Raspberry pi 3A+ in a Gameboy case. Due to the construction I can't see 32 pixels on the left side.
      I have the following settings in config.txt:
      overscan_left=32
      #overscan_right=0
      #overscan_top=0
      #overscan_bottom=0
      #overscan_scale=1
      #framebuffer_width=480
      #framebuffer_height=320
      framebuffer_width=448
      I start the emulation station with the following parameters:
      emulation station --no-splash --screensize 448 320 --screenoffset 32 0
      I can adjust the libretto cores to the resolution using the custom acpect ratio switch.
      pcsx_rearmed ignores the settings and runs at 480x320.
      How can I change this ?
      Thank you very much for your efforts in advance.
      Regards
        MrLightgun
        Is lr-pcsx-rearmed a possibility or do you need some particular functionality from pcsx-rearmed?
          reruns_towel
          lr-pcsx-rearmed is bound to most roms. But some need the better performance of the standalone core. ( Audio glitches etc. )
            mitu Global Moderator @reruns_towel
            @reruns_towel A PI 3A+ is basically a 3B+ in terms of CPU - do you have any examples where games run better on the standalone emulator than the Libretro core ?
              reruns_towel @mitu
              @mitu But that's not really the question that moves me here. What about the forum rules here. Do you know the brother of Lucifer. The Pal version runs much better with the Standalone Core. I'm more interested in how I pass on the FB offsets to the application.
              Not to be forgotten is the 512MB ram at the A3+.
                @reruns_towel said in Pcsx_rearmed ignores the offset settings:
                What about them ?
                I'll give it a try.
                Try adding back overscan_scale to the config.txt file.
                  mitu Global Moderator @mitu
                  @mitu said in Pcsx_rearmed ignores the offset settings:
                  I'll give it a try.
                  I can't find this PS1 game - what's the original game title ? Is it a homebrew/hack ?
                    dankcushions Global Moderator
                    i already replied to you here: https://github.com/libretro/pcsx_rearmed/issues/366:
                    #overscan_scale=1
                    remove comment:
                    overscan_scale=1
                    then your firmware overscan setting would be applied globally - no need to configure emulators/emulationstation
                      reruns_towel @dankcushions
                      Thanks for your answer, but that doesn't help me. If I use overscan_scale=1 in config.txt, the whole layout is bad.
                      The display is a DPI display for a mobile phone and is rotated 270 degrees. With this settings all emulators Reicast, pico 8, n64 and all libretto cores run.
                      The only one that doesn't work with these settngs is pcsx-rearmed.
                      I thought there was a way to use a console command in runcommand-onstart to reset and reset the fb when pcsx should be started.
                        dankcushions Global Moderator @reruns_towel
                        yes, because you've applied other settings on top of something that should be solved with overscan settings alone, i think. i think if you just used config.txt settings of:
                        overscan_left=32
                        #overscan_right=0
                        #overscan_top=0
                        #overscan_bottom=0
                        overscan_scale=1
                        and not your emulationstation and libretro settings, i would be curious as to the result.
                          NO ! if i only use this 2 settings the emulationstation layout is broken. on the top is a black border and the Layout has cutoffs. the autostart.sh is also cleaned in this case.
                            @reruns_towel i would then adjust
                            overscan_left=32
                            overscan_right=0
                            overscan_top=0
                            overscan_bottom=0
                            until emulastation looks has no cut offs, and then everything should be good. you can use positive of negative numbers
                              What you're suggesting doesn't make much sense in this case. The settings I have are ok.
                              Everything runs fast and as it should be.
                              Except pcsx.
                              i'm looking for a command to run when i start pcsx. fbset -move doesn't work.
                                @reruns_towel it makes perfect sense to me :P you want to add fake overscan to your screen. you can do that in the way i instructed, and that would apply to the whole system. the way you've previously done it is to add overscan to the console (command line) only, and then adjust each bit of software to solve the issue, which as you've found, isn't always possible.
                                  @dankcushions said in Pcsx_rearmed ignores the offset settings:
                                  Sorry for the late response, That's why I made my changes:
                                  Github issue
                                  I forgot to post the following entry in my config.txt:
                                  dpi_timings=320 0 10 10 10 **512** 0 5 2 5 0 0 0 60 0 9600000 2
                                  pi@retropie:~ $ vcgencmd dispmanx_list
                                  display:0 format:XRGB8888 transform:1 layer:-127 src:0,0,448,320 dst:48,0,448,320 cost:338 lbm:0
                                  display:0 format:RGBA32 transform:20001 layer:10000 src:0,0,512,320 dst:0,0,512,320 cost:374 lbm:0
                                  display:0 format:RGBA32 transform:1 layer:20100 src:0,0,15,9 dst:463,2,15,9 cost:98 lbm:0
                                  it is possible to pass the following mode in run-onstart.sh for pcsx-rearmed:
