    Controls not saving in RGUI menu
    rguicontrollersarcade buttons
    45 Posts 2 Posters 7.8k Views
      @Lugzyboy82 said in Controls not saving in RGUI menu:
      You say start retroarch from the retropie system in emulationstation.
      In EmulationStation, you enter the RetroPie system and there's a RetroArch menu entry which starts RetroArch. I don't think I can put it simpler than that.
      L 4 Replies Last reply Reply Quote 0
      • L
        Lugzyboy82 @mitu
        @mitu hahaha. I thought it was going to be something other than that. I will give it a go. I will keep you informed.
        • L
          Lugzyboy82 @mitu
          @mitu here's an update. I updated the binds etc in retroarch as mentioned above. I saved and exited and then restarted the whole system. I went back to retroarch to see if the controllers have saved, which they did. But upon playing a ROM the controls are completely different again. So annoying so I am no further on.
          • L
            Lugzyboy82 @mitu
            @mitu I have also checked the config file which now corresponds with the binds I entered earlier, but the controls don't seem to work.
            • L
              Lugzyboy82 @mitu
              @mitu I have noticed this line at the top of the config file:
              config_save_on_exit = "false"
              Is this correct??
                mitu Global Moderator @Lugzyboy82
                Is this correct??
                Yes.
                Did you 'save' the configuration when you started a game from that system at some point ? What game/rom did you start (and doesn't have the controls you've set) ?
                • L
                  Lugzyboy82 @mitu
                  @mitu hi there. I don't think I have saved a game at all. I have tried to use Alien Storm and I cant even access the game as the start button seems to be set as reset the emulator.
                    Not saving a 'game', but the RetroArch configuration for that game/system - with 'Save Configuration' from the RGUI. What system is this ROM from - arcade/mame-libretro/etc. ?
                    • L
                      Lugzyboy82 @mitu
                      @mitu its for the sega mega drive. I cant recall doing a save. If I have, then the controls are completely different to what I would use.
                        @Lugzyboy82 Post the contents of the /opt/retropie/configs/megadrive/retroarch.cfg (also accessible via file shares at \\retropie\configs\megadrive\retroarch.cfg) to pastebin.com and provide the link.
                        • L
                          Lugzyboy82 @mitu
                          https://pastebin.com/L0B7k6vL
                            The config you provided looks like it's have been produced with Save Configuration from RetroArch's RGUI. The settings here will override the main settings you defined - for all systems - by using RetroArch started from the RetroPie system, that's why your controls are not working.
                            Are you using a RetroPie image from retropie.org.uk/download or a 3rd party image downloaded from elsewhere ?
                            • L
                              Lugzyboy82 @mitu
                              @mitu I am using the retropie image suggested in the initial setup documents. That makes sense what you say, so how do I correct this?
                                But if you didn't save this config file, then how it's automatically saved ? It has config_save_on_exit = "true" in there, so if it hasn't been enabled, maybe there's another mechanism that you activated which switches this on, potentially breaking again the configuration.
                                L 3 Replies Last reply Reply Quote 0
                                • L
                                  Lugzyboy82 @mitu
                                  @mitu yes, I remember that now. I was following a video tutorial online which was unsuccessful. What do I need to do now to make this work? Re-install retropie??
                                  • L
                                    Lugzyboy82 @mitu
                                    @mitu or can I just delete my config file and install the correct one?
                                    • L
                                      Lugzyboy82 @mitu
                                      @mitu or can I change the line to config_save_on_exit = "false"??
                                        You should replace the megadrive system's retroarch.cfg with the default one provided by RetroPie and re-try to see if your main input mapping is applied. The file contents should be:
                                        input_remapping_directory = "/opt/retropie/configs/megadrive/"
                                        • L
                                          Lugzyboy82 @mitu
                                          @mitu I will have to wait until I get a new memory card unless this config can be downloaded or a possible pastebin link?
                                          • L
                                            Lugzyboy82 @mitu
                                            @mitu I have managed to get the correct config file in there which is now correct. Thank you so much.
