Updating issues with RetroPie on RPi 4 issues?
@mitu Thanks. I've just tried that. No change. I have since removed and reinstalled sixaxis just to be sure it was't that. I still can't see the PS3 pad on bluetooth.
@George-Spiggott - Is the pad fully charged?
Try removing it and re-adding it from the command-line..
$ bluetoothctl remove <mac address of pad> $ bluetoothctl connect <mac address of pad>
If that doesn't work, see if bluetoothctl can detect the pad..
$ bluetoothctl Agent registered [bluetooth]# scan on Discovery started ...
If it can discover other bluetooth devices but not the game pad, then there might be a discovery filter that's blocking it. To check it, do..
$ bluetoothctl Agent registered [bluetooth]# menu scan Menu scan: Available commands: ------------------- uuids [all/uuid1 uuid2 ...] Set/Get UUIDs filter rssi [rssi] Set/Get RSSI filter, and clears pathloss pathloss [pathloss] Set/Get Pathloss filter, and clears RSSI transport [transport] Set/Get transport filter duplicate-data [on/off] Set/Get duplicate data filter clear [uuids/rssi/pathloss/transport/duplicate-data] Clears discovery filter. back Return to main menu version Display version quit Quit program exit Quit program help Display help about this program export Print evironment variables [bluetooth]# duplicate-data DuplicateData: off
You can see mine is off, so there's no active filter. If yours is on, then try running the 'clear duplicate-data' and 'duplicate-data off' commands.
Yes it is charged, I get a controller showing (shown below) when the pad is attached via a cable but I can't remove it.
[CHG] Controller DC:A6:32:51:52:36 Discovering: yes
I tried the scan but it did not pick up the pad. Duplicate data is off. There's a weekly update out today I'll see if that fixes it.
@George-Spiggott said in Updating issues with RetroPie on RPi 4 issues?:
I've been having the same problem with my Wii U Pro controllers. They paired and worked fine on my Pi3B but I can't connect them on my Pi4. I tried on the Feb 7th version but haven't yet on today's update. Busy at the moment clearing all my stuff off the Pi3 to place on my Pi4.
@ByteThis I have a Wii U Pro controller and it's pairing without issues with the Pi4, configuration is fine and it works in RetroArch (that's the extent of my test).
The PS3 does not have native pairing - AFAIK - and it needs to be be first connected via USB to start the pairing - https://retropie.org.uk/docs/PS3-Controller/#using-the-retropie-setup-gui-to-configure-the-ps3-controller-bluetooth-connection-for-sixaxis. -
@mitu said in Updating issues with RetroPie on RPi 4 issues?:
Thanks I will try it again when I have everything transferred over. Did you have it paired with the older versions of the weekly dev branch or the latest versions ?
@ByteThis said in Updating issues with RetroPie on RPi 4 issues?:
I installed the first dev image released and updated normally since then - updating the OS and packages in Raspbian along the RetroPie's installed packages.
@IceChes1 said in Updating issues with RetroPie on RPi 4 issues?:
PSP games run very well.
Could you please tell me what core are you using for PSP and your configuration?
I'm tryng PSP but I cannot reach a smooth gameplay.
Thanks -
I am using ppsspp, NOT lr-ppsspp with all default settings.
Using PPSSPP here on a vanilla Pi4 at 2x resolution. It depends on the game. Medieval runs fine, GTA Vice City slows down when there's a lot on screen, Little big planet ran ok even on my vanilla Pi3B (1x resolution). Even overclocked I've never got the Tomb raider games to run smoothly consistently.
Are you meaning running Tom Raider on PI3 or PI4. On PI4 it runs really good...both of them Anniversary and Legends.
@WODAK on the pi4, alrhough I haven't tried overclocking rhe GPU on this build. Legend is jumpy and Anniversary slows down when the screen is busy, eg on the second level near the waterfall.
True...mine is overclocked... as for the game play....I didn't complete any level ... just tired to play a little bit moving, running around, learning how to play :)...etc...maybe for 5 minutes each...and it didn't have any hickups or anything.
@WODAK How high is your GPU overclocked?
I've got mine realy high...but it really is stable...looks like I had luck on hardware... the highest temperature I got was 53 C ....:)
over_voltage=6 hdmi_enable_4kp60=1 arm_freq=2100 gpu_freq=800
and my clock speeds:
#Not running any emulators: core => frequency(1)=289709472 v3d:=> frequency(46)=366358880 arm => frequency(48)=2100515584 #running emulators core => frequency(1)=549993152 v3d:=> frequency(46)=799993664 arm => frequency(48)=2100568320
so the GPU is at 550 and v3d is at 800....GPU is as 2100...and I'm running on 1080p TV ...
if you are trying to overclock...take it easy...use the bottom up method...and always CHECK your temperatures...
not to forger...setting the cpu governor to performance...but setting it in run command (so setting it on only when game runs )
@WODAK My CPU is at 2000. My GPU used to be set to 600 but the new firmware has lest me a little confused as to what is currently possible. It looks like only your v3d is set higher than any setting I have previously had.
With the latest firmware you can go with GPU to 550...and V3D to as high as 850...you can set this parameters separatly as GPU and then the other parameters core_freq, h264_freq, isp_freq, and v3d_freq or all together as gpu_freq (gpu dosn't go above 500, only if u set hdmi_enable_4kp60=1 then you can go up to 550 HZ)...
I know .... a little bit confusing ...:)
@WODAK said in Updating issues with RetroPie on RPi 4 issues?:
You mean core frequency doesn't go above 500
@quicksilver said in Updating issues with RetroPie on RPi 4 issues?:
right :)
That's strange - I just picked up a PS3 controller today and paired it without issues. Are you following all the steps explained in PS3 controller doc page ?
I installed the
sixaxis
driver, then started the BT dialog - with the PS3 plugged in - and followed the on-screen message to pair it.
