    Help With Running Emulators RPi4
    help me pleasepi4psxgamecube
    13 Posts 4 Posters 408 Views
      SwitchedPC
      Whenever I update script emulation station will never boot
      workaround found
      Important need to finish my build:
      How to install Psx2 Emulator for RetroPie Pi4
      How to install GameCube
      Or other alteratives to Retropie
      DarksaviorD BuZzB 2 Replies Last reply Reply Quote -2
      • DarksaviorD
        Darksavior @SwitchedPC
        @SwitchedPC That's because they're not supported. Pi is too slow. You do know retropie is for pc's as well, right?
          SwitchedPC @Darksavior
          @Darksavior I did not know that :/ That makes me sad I have tons of ROMs for both ready to go... And 4gb of ram should run Gamecube at 60fps Idk about ps2 though...
            BuZz administrators @SwitchedPC
            @SwitchedPC please use a topic title that actually gives an overview of the issue. This forum wouldn't be much help if all the topics were named like this.
            Edit your post please.
              SwitchedPC @BuZz
              @BuZz is this a better name for the topic?
              BuZzB 1 Reply Last reply Reply Quote -1
                @SwitchedPC what's with all the exclamation marks..stop being so dramatic. Ridiculous.
                  SwitchedPC
                  @BuZz there I fixed it will you help me now?
                    @SwitchedPC you've already been helped. Thanks for fixing the title.
                      SwitchedPC
                      @BuZz time to rechange the text
                      • DarksaviorD
                        @SwitchedPC The amount of ram in a device is not a way to judge its performance.
                          SwitchedPC
                          @Darksavior at this point I'm not trying to argue performance I just want to run the emulators on rpi4
                            mitu Global Moderator @SwitchedPC
                            @SwitchedPC The PS2 emulator doesn't run on the PI4, it's a PC only program. As for the Gamecube emulator (dolphin), it needs an 64bit environment to run (barely), but Raspbian doesn't provide such system.
                            So if you're looking to run PS2 or Gamecube games with RetroPie, your only option right now is a PC, not a Pi4.
                              SwitchedPC @mitu
                              @mitu sad day
