    Are microSD cards too small?
    microsdtoo smalllostsimnano
    19 Posts 11 Posters 2.4k Views
    • matchamanM
      matchaman
      Two days ago I lost a 512GB card that was left on my home office. Most likely it fell on the floor and the robotic vacuum (that was soon emptied by my wife) sucked it.
      So the "philosophical" argument I have right now is: are microSDs (and nano SIM cards) too small? When does practicality for small space go over the top?
      ByteThisB 1 Reply Last reply Reply Quote 0
      • thelostsoulT
        thelostsoul
        You should carry it in a bigger plastic case. I wouldn't say that they are "too small". The small size have a purpose and enables for smaller hardware. In this case, it was a chain of user error and bad luck. Hope you didn't lost valuable work or data on it.
        📜 RE/SET: 100 SNES Games for your RetroPie, 🎁 Share your hidden gems and insider tips
        WeirdHW 1 Reply Last reply Reply Quote 0
        • WeirdHW
          WeirdH @thelostsoul
          @thelostsoul said in Are microSD cards too small?:
          Basically this. They're not designed to be left out on a desk somewhere, but to fit in something else that's also relatively small.
          • sirhenrythe5thS
            sirhenrythe5th @WeirdH
            I still have an 8"Floppy Drive, maybe someone could create a driver to run it with the Pi.
            This one should be safe to be vacuumed 😂
            RetroRatio: 1.91
            Started Games beaten: 2,40%
              T0biasCZe
              yes, also they are weak
              i already breaked 3 Micro sd cards in half
              thelostsoulT IceChes1I 2 Replies Last reply Reply Quote 1
              • thelostsoulT
                thelostsoul @T0biasCZe
                @T0biasCZe said in Are microSD cards too small?:
                How? I mean, that is quite unusual. In my entire life since the inception of SD cards and Micro sd cards, I never broke any of them. And the smaller they are, the harder to break them.
                • V
                  VictimRLSH
                  I think we are overlooking something quite worrisome here. The ROBOT vacuum sucked up the 512GB, but what happened to it after that?!? I'm sure a stock Roomba doesn't need anywhere near 512GB to navigate a house. Are you SURE it's just vacuuming when you're not there....
                  I suspect foul play, with a robot uprising soon to follow.
                  System Config: Retropie 4.4 with full desktop, RPi 3B, 256gb SD, 5v 2.1A 5,200 mAH USB battery. EasyMSX controller mounted with Pimoroni Hyperpixel 4 (non touch). Also running 4.6 on a 4gb Pi 4 serving as my primary desktop computer now.
                  IceChes1I obsidianspiderO 2 Replies Last reply Reply Quote 2
                  • IceChes1I
                    IceChes1 @VictimRLSH
                    @VictimRLSH said in Are microSD cards too small?:
                    HA! Yes, because Roombas have MicroSD slots.
                    Actually they might...
                    Who's got a spare Roomba and a dremel they can lend me? 😂
                    HOME CONSOLE
                    Pi 4
                    SanDisk 64 GB
                    Master branch install
                    3.5 amp CanaKit PSU
                    Logitech F310, Dell keyboard, Dell mouse, JetFlash Transcend 16 GB USB stick
                    HANDHELD
                    Pi 0 W
                    SanDisk 32 GB
                    Random image I found. Had a driver I needed.
                    IPEGA PG-9157 USB Receiver
                    • IceChes1I
                      IceChes1 @T0biasCZe
                      How? I can't snap mine without a pair of vice-grips. Not that I've tried...
                      HOME CONSOLE
                      Pi 4
                      SanDisk 64 GB
                      3.5 amp CanaKit PSU
                      HANDHELD
                      Pi 0 W
                      SanDisk 32 GB
                      • ByteThisB
                        ByteThis @matchaman
                        @matchaman said in Are microSD cards too small?:
                        So the "philosophical" argument I have right now is: are microSDs (and nano SIM cards) too small? When does practicality for small space goes over the top?
                        What did you have on the card ? You never specified. I assume Retropie. That was a good sized card.
                        • KN4THXK
                          KN4THX
                          I do not think they are too small. Storage mediums of any size are typically not removed from the device it is used in unless it is being moved to another device either permanently or temporarily.
                          I have external SSDs and HDDs and I while i enjoy that size, I wish they were much, much smaller. I love the idea of the USB flash drive that is dongle size, but the transfer speeds and heat buildup keep me from buying another.
                          Personally, I think the Commodore 64 floppy disk drives are the best storage medium. Roombas can't suck them up and a significant other doesn't know how to view the contents :)
                          "If you're gonna play the Game Boy, You gotta learn to play it right" - https://www.youtube.com/watch?v=FYLGl92ETNQ
                            obsidianspider @VictimRLSH
                            That Robot is now playing Sega Saturn games. ;)
                            sirhenrythe5thS 1 Reply Last reply Reply Quote 4
                            • sirhenrythe5thS
                              sirhenrythe5th @obsidianspider
                              @obsidianspider LOL, made my day!! XD XD
                              RetroRatio: 1.91
                              • V
                                VictimRLSH
                                Well, I know that I play video games when I should be doing housework....
                                  A Former User
                                  What if... we make them smaller?
                                  • IceChes1I
                                    IceChes1
                                    @itskryode Are you thinking...
                                    micro micro sd...
                                    HOME CONSOLE
                                    Pi 4
                                    SanDisk 64 GB
                                    3.5 amp CanaKit PSU
                                    HANDHELD
                                    Pi 0 W
                                    SanDisk 32 GB
                                    thelostsoulT 1 Reply Last reply Reply Quote 0
                                    • thelostsoulT
                                      thelostsoul @IceChes1
                                      @IceChes1 I'd suggest Nano SD cards, like its counterpart of Nano SIM cards.
                                      • matchamanM
                                        matchaman
                                        Oh, snap...
                                        • thelostsoulT
                                          thelostsoul @matchaman
                                          @matchaman I saw that image too, but didn't look into it, because I thought its a SIM card. So, these are essentially Nano sd cards. But they are only produced by Huawei, so maybe not a standard soon. https://nasilemaktech.com/nm-card/
