    Pi4 , retropie and wifi problem
    wifi problempi4
    9 Posts 3 Posters 734 Views
      pasaico
      Hi all
      I have installed retropie 4.5.17
      I have installed monkypie IMG
      I have installed other IMG retropie.
      The First Time i opened pi4 and installed retropie , my wifi home Is connected. After reboot, I was no longer able to connect with any version of retropie.
      I checked the location of the wifi, the password, I brought the wifi closer to the pi4, nothing, I rewrote new img on the SD, I can no longer connect my wifi home 2.4 ghz
      while, installing puppy linux, my wifi connects without any problem.
      Solution?
      1 Reply Last reply Reply Quote -2
        We don't support 3rd party images - as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
        Install Raspbian Lite and update your OS/packages, check that your Wifi is working and then try the manual installation https://retropie.org.uk/docs/Manual-Installation/.
          pasaico @mitu
          @mitu i have installed rasbianLite, i can't update package without internet WiFi.
          I have follow all step for configure connect wifi, but nothing. WifiGuide
          I see my wifi home with "iwlist wlan0 scan", i have configured the wpa_supllicant.conf.
          But nothing.
            BuZz administrators @pasaico
            @pasaico use a weekly Dev image for rpi4 from http://files.retropie.org.uk/images/weekly/
              pasaico @BuZz
              @BuZz ok, i have Just installed.
              Same problem.
              Any ideas?
              My Pi4 is model B Rev 1.2
                This post is deleted!
                  BuZz administrators
                  Ignore my previous reply if you read it before I removed. Got mixed up with another forum post.
                    BuZz administrators
                    Use the WiFi configuration in RetroPie-Setup. Set the country for WiFi via raspi-config (it will prompt you to do this). Please provide more details if this doesn't work.
                    Use our documentation btw.
                      pasaico @BuZz
                      @BuZz
                      I write the solution for my case. Maybe it could help someone
                      Pi4 model b
                      access point: TP-LINK RE450
                      Retropie, any version for some strange reason does not connect to the access point.
                      SOLUTION: I had to install an OPEN-WRT custom firmware on the access point.
                      Once rebooted and configured, everything works.
                      The strange thing, that the first time, with the firmware stock was connected perfectly, then you can not.
