    Using Shaders & Hi Res Packs
    11 Posts 4 Posters 7.7k Views
      Abstract3000
      Ok, SO I return for some help for what I believe to be outdated info on the wiki and old youtube videos,
      running Retropie 3.8 updated from the menu says 4 now though, and first off the Shaders, how do i access them?
      my retroarch.cfg in /opt/retropie/emulators/snes mentions nothing of shaders whatsoever and is practically blank in comparison to the example here ->
      Also tried to setup the hotkey t press n and swap through them like the example here ->
      but i am missing the configs folder in the retroarch directory? must have been moved or lots of changes.....
      As for the High Res texture packs, once again info missing in my setup, in the mupen64plus.cfg file I have no lines mentioning Rice or Glide and nothing mentions the enabling of Hi Res Textures to set to True? This moved as well?
      My SNES Games look absolutely terrible, and have noticeable lag .... using a RP3 with a 64GB Class 10 MicroSD
      thanks again for the help!
        edmaul69
        What emulator are you running for snes? If your n64 mupen64plus.cfg isnt working properly, make a backup then delete everything in the file and save. When you choose gles n64 or rice as your default emulators in your emulators.cfg it will re-add all the info in the mupen64plus.cfg
          Abstract3000
          lr-snes9x-next
            edmaul69 @Abstract3000
            @Abstract3000 i edited my post please read about n64. Not sure why snes9x is laggy for you. A class 10 might be too slow for a 64gb
              Abstract3000 @edmaul69
              @edmaul69 Thanks for the info on the N64 I will give it a shot, as for the Micro SD I don't think it gets any faster than Class 10 with UHS 3... The Snes9X emulator seems to run great though the controls are different as it isnt apart of the libreto (spelling that wrong) thing so I assume thats why it isn't, I'll see if I can mess with the Emulators config files and give that a shot, the worst game I notice is Donkey Kong Country (just terrible) bu got the shaders to work, through the retro pie tools/setup menu I found an option to install them, and now you just press "n" to cycle through them.
                @Abstract3000 said in Using Shaders & Hi Res Packs:
                Now is your card a class 10 or a uhs 3? A class 10 and uhs 1 are 10mb/s but a uhs 3 is 30mb/s. I have a 64mb uhs 3 that ran great before i switch to an external hard drive.
                  This post is deleted!
                    dankcushions Global Moderator
                    bad sd cards won't cause lag in-game. everything is in memory for the 16-bit systems.
                    update lr-snes9x from source: https://github.com/retropie/retropie-setup/wiki/updating-retropie#updatinginstalling-individual-packages
                    and set tv to game mode.
                      @edmaul69 Oddly enough it mentions both on the front the 10 in the circle and the U around the 3, the package claims 90MB/s per sec PNY elite performance bought it from a National retailer not no online Chinese retailer, everything else seems to be running just fine the SNES emulators just seem off so I'm sure there is some settings I need to screw with
                        Abstract3000 @dankcushions
                        @dankcushions Will try that to see if it makes a difference :)
                        • FloobF
                          Floob
                          You can switch shaders on using the configuration tool here:
                          https://github.com/retropie/retropie-setup/wiki/Configuration-Editor
                          Or you can manually customise your retroarch.cfg files, some info here:
                          Broadly speaking, a very popular shader is from davej, which is included in RetroPie.
                          http://libretro.com/forums/showthread.php?t=4937
                          https://retropie.org.uk/forum/topic/897/updated-crt-pi-shader
