    Problema monitor con Raspberry
    raspberrypi 3b+bartop arcade
    28 Posts 3 Posters 1.7k Views
      mitu Global Moderator @angel1682
      Just copy the contents and paste it in the topic.
        angel1682 @mitu
        I don't know where I have to write it and if I have to delete something
          It looks like your config.txt file is already set to a certain resolution and has the hdmi_force_hotplug=1 option added. Did you modify the file ? Because the default RetroPie image doesn't have this settings.
            angel1682 @mitu
            @mitu it took a long time to arrive at a good resolution, I had documented some small variations, but now I have forgotten everything, I am a non-programming nurse๐Ÿ˜‚
              I would comment the resolution lines (add a # at the beginning of the line) and also comment the hdmi_drive line. Try with these modifications to see if the video works.
                angel1682 @mitu
                @mitu I apologize humbly but I don't understand what I have to do.If I send you the file you can edit it that at this moment I can't understand
                  In your file, you have these lines :
                  hdmi_group=1
                  hdmi_mode=19
                  Modify the line and add a # at the beginning of the line:
                  # hdmi_group=1
                  # hdmi_mode=19
                  Make a copy/backup of the file, just in case.
                    angel1682 @mitu
                    @mitu thanks a lot now works again๐Ÿ˜Š๐Ÿ˜Š๐Ÿ˜Š
