    Advance Mame sample sound not working
    advance mameaudiosamplesnot workingdonkey kong
    7 Posts 4 Posters 1.1k Views
    • F
      francis2019
      Hello I have the latest Advance mame installed on my retropie.
      The Retropie version is 4.5.1
      The sound is working correctly for all the games except the one with samples (DKONG, DKONG JR)
      I have the mame 106 roms installed with the samples that comes with it.
      I put the samples in another folder
      bios/mame-advmame/samples
      and I change the config in the advancemame.rc
      But the samples for DKONG and DKONG JR are not working. And I tried different version of samples
      Here is the relevant config in advancemame.rc:
      device_alsa_device default
      device_alsa_mixer channel
      device_sdl_samples 512
      device_sound sdl
      dir_sample /home/pi/RetroPie/bios/mame-advmame/samples
      But whatever I do the sample sound in dkong is not working (DKONG Bump and Mario Jump)
      Is there a way to see if the samples has been correctly loaded when we start a game.
      I check on the runcommand, but I didnt see anything relevant
      any help with that
      • sirhenrythe5thS
        sirhenrythe5th
        I had the same issue with "Zaxxon" using AdvanceMame.
        After Hours of tinkering i got it working by enabling "Demo Sounds" in the DIP-Switch-Menu of that Game.
        No idea how samples are connected to the enabled DemoSounds in Attract-Mode of the PCB, but it works till now and was the only way to get the samples playing.
        RetroRatio: 1.91
        Started Games beaten: 2,40%
        • W
          wstanek
          Its not a case sensitive path is it? My directories have it as BIOS all caps. Just wondering why you put the samples in the BIOS dir. You can hide a directory from showing up in the roms list by adding a period (.samples). I think.
          ws
          Latest Build: https://retropie.org.uk/forum/topic/23649/mad-planets-cabinet-build-finished?_=1578928113680
          mituM F 2 Replies Last reply Reply Quote 0
            mitu Global Moderator @wstanek
            @wstanek Linux is case sensitive, so you should be using the proper casing when configuring the paths.
            • F
              francis2019
              @francis2019 said in Advance Mame sample sound not working:
              /bi
              You are right I change the bios to BIOS and now its working
              thanks !!!!
              • F
                francis2019 @wstanek
                @wstanek Yes it was the bios that was not in caps, its weird because when i go to the network folder in windows bios is not in caps
                  mitu Global Moderator @francis2019
                  That's the file share name, not the folder name as seen by the Pi.
