    LR-Caprice32 help with virtual keyboard
    capriceamstrad cpccapricerpi
    3 Posts 2 Posters 635 Views
    • carlhungus74C
      carlhungus74
      Hello,
      Just install LR-Caprice32 to play my good ol' CPC games.
      I've got a bartop with no keyboard/mouse (2 joysticks and a dozen buttons only).
      So I want to use the integrated Caprice virtual keyboard, cause in many CPC games, you have to click on various keys to start the game.
      It popup correctly (With Start/Y if I remember), but cannot move the cursor. I think it should work with mouse, but I haven't.
      Do you know a trick ?
      Try CapriceRPI. Seems great, and virtual keyboard works just fine, even with a joystick. But as it is not retroarch, cannot use global hotkeys (volume, reset and so on..). So I would prefer the first LR solution.
        cyperghost
        @carlhungus74 afair activate keyboard and then press select
        • carlhungus74C
          carlhungus74
          Great ! Try a lot of thing, but not this one :)
          Thanks again @cyperghost
