    Food Fight - joystick troubles, solved
    ad stick
    125 Posts 5 Posters 22.3k Views
      mahoneyt944 @grant2258
      @grant2258
      Thank you, made some updates, see below. Just need to add the diagonals and maybe tighten up the stopping values.
      You said diagonals are radial. Does that mean we check under a different port for diagonals or something? or can I just update my "if/else if" press checks under port 0 and 2 to check for diagonals first? So diagonals takes precedence over linear moves.
      static READ16_HANDLER( analog_r )
        static int up = 0;
        static int down = 0;
        static int left = 0;
        static int right = 0;
        int center = 127;
        int xvalue = center;
        int yvalue = center;
        if (whichport == 0)
          if (code_pressed(JOYCODE_1_LEFT)) { xvalue = 255; left=1; right=0; up=0; down=0; }
          else if (code_pressed(JOYCODE_1_RIGHT)) { xvalue = 0; left=0; right=1; up=0; down=0;}
          if (xvalue == center && right) return 122;
          else if (xvalue == center && left) return 134;
          else return xvalue;
        else if (whichport == 2)
          if (code_pressed(JOYCODE_1_UP)) { yvalue = 255; left=0; right=0; up=1; down=0; }
          else if (code_pressed(JOYCODE_1_DOWN)) { yvalue = 0; left=0; right=0; up=0; down=1; }
          if (yvalue == center && down) return 122;
          else if (yvalue == center && up) return 134;
          else return yvalue;
      return center;
        grant2258 Banned
        well whichport 0 is the axsis and whichport2 is the yaxis it only reads one at a time.
        you need to keep track of the x and y changes you never know what port is going to read so you need to keep track of x and y settings. Ill try knock something up for you to use thats a little easier to work with.
          @grant2258
          This is what I tried(see main code below), it works ok, but glitchy. Mostly because when pressing diagonals it's easy to press one direction earlier than the other. Which results in false stops being set linearly.
          Probably just need to add a center check for the linear directions so they only set at exact positions and are harder to hit... like this:
          else if (code_pressed(JOYCODE_1_LEFT && yvalue == center)) { xvalue = 255; left=1; right=0; up=0; down=0; }
            //return readinputport(whichport);
            static int up = 0;
            int center = 127;
            if (whichport == 0)
              // check for diagonal presses first
              if (code_pressed(JOYCODE_1_LEFT) && code_pressed(JOYCODE_1_UP)) { xvalue = 255; left=1; right=0; up=1; down=0; }
              else if (code_pressed(JOYCODE_1_LEFT) && code_pressed(JOYCODE_1_DOWN)) { xvalue = 255; left=1; right=0; up=0; down=1; }
              else if (code_pressed(JOYCODE_1_RIGHT) && code_pressed(JOYCODE_1_UP)) { xvalue = 0; left=0; right=1; up=1; down=0; }
              else if (code_pressed(JOYCODE_1_RIGHT) && code_pressed(JOYCODE_1_DOWN)) { xvalue = 0; left=0; right=1; up=0; down=1; }
              // check linear presses
              else if (code_pressed(JOYCODE_1_LEFT)) { xvalue = 255; left=1; right=0; up=0; down=0; }
              else if (xvalue == center && left) return 132;
              else return xvalue;
              if (code_pressed(JOYCODE_1_UP) && code_pressed(JOYCODE_1_LEFT)) { yvalue = 255; left=1; right=0; up=1; down=0; }
              else if (code_pressed(JOYCODE_1_UP) && code_pressed(JOYCODE_1_RIGHT)) { yvalue = 255; left=0; right=1; up=1; down=0; }
              else if (code_pressed(JOYCODE_1_DOWN) && code_pressed(JOYCODE_1_LEFT)) { yvalue = 0; left=1; right=0; up=0; down=1; }
              else if (code_pressed(JOYCODE_1_DOWN) && code_pressed(JOYCODE_1_RIGHT)) { yvalue = 0; left=0; right=1; up=0; down=1; }
              else if (code_pressed(JOYCODE_1_UP)) { yvalue = 255; left=0; right=0; up=1; down=0; }
              else if (yvalue == center && up) return 132;
              else return yvalue;
          return center;
            grant2258 Banned
            here is the new simplified code this uses the cheat input ports as well cocktail mode isint added atm if you need it just let me know.
              #define max  255
              #define cent 128
              #define bump 51;
              #define up   1
              #define down 2
              #define left 4
              #define right 8
              static INT16  xvalue = 0x80;
              static INT16  yvalue = 0x80;
              static INT16  lastx  = 0x80;
              static INT16  lasty  = 0x80;
              static INT16  currentx  = 0x80;
              static INT16  currenty  = 0x80;
              static INT16  center = 0;
              int flag;
              int temp;
               UINT16 direction;
              if( options.cheat_input_ports) // use cheat ports
                if(whichport == 0 || whichport ==2)   direction = readinputport(6);
                temp = direction & ~16;
                if ( temp == 0 ) center =1;
                else if ( temp == up         ) { center=0; xvalue = cent; yvalue = max;  currentx=cent;      currenty= cent+bump; }
                else if ( temp == down       ) { center=0; xvalue = cent; yvalue = 0;    currentx=cent;      currenty= cent-bump; }
                else if ( temp == left       ) { center=0; xvalue = max;  yvalue = cent; currentx=cent+bump; currenty= cent;      }
                else if ( temp == right      ) { center=0; xvalue = 0;    yvalue = cent; currentx=cent-bump; currenty= cent;      }
                else if ( temp == right+up   ) { center=0 ;xvalue = 0;    yvalue = max;  currentx=cent-bump; currenty= cent+bump; }
                else if ( temp == right+down ) { center=0; xvalue = 0;    yvalue = 0;    currentx=cent-bump; currenty= cent-bump; }
                else if ( temp == left+up    ) { center=0; xvalue = max;  yvalue = max;  currentx=cent+bump; currenty= cent+bump; }
                else if ( temp == left+down  ) { center=0; xvalue = max;  yvalue = 0;    currentx=cent+bump; currenty= cent-bump; }
                else log_cb(RETRO_LOG_INFO, LOGPRE "unhandled condition %d\n",temp);
            //   log_cb(RETRO_LOG_INFO, LOGPRE "flag:%d center:%d xval:%d yval:%d\n", temp, center, xvalue, yvalue);
                if (whichport == 0)
                  if (center)
                    return currentx;
                  return xvalue;
                  if (center)
                    return currenty;
                  return yvalue;
                else log_cb(RETRO_LOG_INFO, LOGPRE "unhandled condition1 %d\n",temp);
              else // use original inputs
            add new cheat ports here just before INPUT_PORTS_END https://github.com/libretro/mame2003-plus-libretro/blob/0134c428b75882aa474f78dbbf2c6ecde49b97b7/src/drivers/foodf.c#L291
            	PORT_START	/* fake port for digital joystick control */
            	PORT_BIT( 0x01, IP_ACTIVE_HIGH, IPT_JOYSTICK_UP    | IPF_8WAY | IPF_CHEAT )
            	PORT_BIT( 0x02, IP_ACTIVE_HIGH, IPT_JOYSTICK_DOWN  | IPF_8WAY | IPF_CHEAT )
            	PORT_BIT( 0x04, IP_ACTIVE_HIGH, IPT_JOYSTICK_LEFT  | IPF_8WAY | IPF_CHEAT )
            	PORT_BIT( 0x08, IP_ACTIVE_HIGH, IPT_JOYSTICK_RIGHT | IPF_8WAY | IPF_CHEAT )
              @grant2258 center is 127. Not 128. Did you test this code yet?
                grant2258 Banned
                actually its 128 for out purposes wen want it dead on center
                  @grant2258 I was testing 128 yesterday and it made it slightly to one side. Thats why I changed it to 127 to get a true center...?
                    grant2258 Banned
                    The game auto calibrates as well so dont worry about it too muchthe value is fine.
                      @grant2258 did you test it?
                        grant2258 Banned
                        just a basic test is working fine as be sure to enable cheat ports or youll be using the old original analog code.
                        If you have issues after testing it let me know. The input ports on the horizontal seem to be reading a bit fast slow it down till you dont get button bounce on the device your using.
                        too
                        if (whichport ==2) direction = readinputport(6);
                        if that doesnt dampen it enough for you read it every second time with whichport ==2 condition.
                          @grant2258 tested, can't move left or right and diagonals are stoping off target most times. Sometimes diagonals stop in linear directions too.
                            grant2258 Banned
                            works fine here make sure your using cheat ports the re-calibrate your your joystick in the service menu. When you mess about with this code you change the calibration during my testing i had to repeatedly delete the nvram to undo teh games calibration.
                            Thats why care needs to be done when testing. The horizontal could be reading too fast for you i explained this before its button debounce delay the read time.
                            the code is here
                            wget https://raw.githubusercontent.com/grant2258/Blaster-Barcade/3d1f20d2bcc51552672119cdded187633cdfe1d7/src/drivers/foodf.c
                            ps this code works fine in default nvram when you spin the joystick round once and works every time if you calibrate
                              @grant2258
                              Had a compiling error that's why it was messed up.
                              Fixed now ... Testing now
                                grant2258 Banned
                                this code here https://github.com/grant2258/Blaster-Barcade/blob/3d1f20d2bcc51552672119cdded187633cdfe1d7/src/drivers/foodf.c#L199
                                change it too
                                    if( counter == 8) {  direction = readinputport(6); counter =0; }
                                    else counter ++;
                                and add somewhere at the top where the other variables are this should take care of the debounce works fine on a keyboard (horizontal centering )
                                static INT16  counter = 0;
                                  @grant2258
                                  if the counter isn't 8 direction wont be set to be used with temp. is that an issue? Or should this be a while loop
                                    grant2258 Banned
                                    it intentional it uses the last read. The problem is it reads so fast you get button debounce you need to slow the reads down unti you get horizontals without issues.
                                      @grant2258 right but on first time run your direction wasn't set yet to have a last read position.
                                        grant2258 Banned @mahoneyt944
                                        @mahoneyt944 are you having any issues ? you shouldnt be. The analog reads far too fast for button debounce you need 10 - 20 ms for the debounce. Even when you dont press a button it will read zero as center it will happen so fast you wont notice it and teh buttons will be read in less time than you could press it.
                                          @grant2258 if I change the code to use the counter even after calibration I get issues. He moves diagonals slowly and looks choppy. Then when exiting and re-entering the emulator he doesn't stop moving. If I don't use the counter it's fine just sometimes stops linear instead of diagonal.
                                            grant2258 Banned
                                            Well i would suggest you delete your foodf nvram and cfg files since the input ports where added and it was save before that. Ive only tested on a windows machine will compile on pi and test it in my barcade. And be sure to have your cheat ports on.
