    Food Fight - joystick troubles, solved
    ad stick
    125 Posts 5 Posters 22.3k Views
      mahoneyt944 @barbudreadmon
      @barbudreadmon in fbneo , and all versions of mame besides mame2003-plus, your player will face right when you let go of the joystick. This hack fixes this issue by allowing you to stop facing the direction last applied. This is a new control hack described in post #97. And post #119 describes how to setup the hack.
        barbudreadmon @mahoneyt944
        @mahoneyt944 ok, it seems i didn't understand the issue, i'll see if a fix can be implemented for fbneo
          @barbudreadmon this hack could be ported I'm sure, but would require lots of conversions. Here's the details.
          #785 - foodf.c patch
          For digital controls to work, a default value has to be applied when no direction is being pressed. This emulates a analog sticks center position value. Here's the fix and patch to this fix here
          #786 - digital centering correction patch
          #815 - digital centering bug patch
          Good luck.
            mahoneyt944
            New bootstrap patch to include the joystick calibration. Eliminating the setup hassles. Once it's merged I'll update the setup instructions in post #119.
            #841 - foodf bootstrap patch
              mahoneyt944
              New bootstrap officially merged, updated instructions in post #119.
