    Food Fight - joystick troubles, solved
    ad stick
    125 Posts 5 Posters 22.3k Views
      mahoneyt944 @grant2258
      @grant2258
      it works for me like this instead
      static READ16_HANDLER( analog_r )
        #define max  255
        #define cent 128
        #define bump 51;
        #define up   1
        #define down 2
        #define left 4
        #define right 8
        static INT16  xvalue = 0x80;
        static INT16  yvalue = 0x80;
        static INT16  currentx  = 0x80;
        static INT16  currenty  = 0x80;
        static INT16  center = 0;
        static INT16  counter = 0;
        int temp;
        UINT16 direction;
        if( options.cheat_input_ports) // use cheat ports
          if(whichport == 0 || whichport ==2)   direction = readinputport(6);
          if (counter == 8)
            temp = direction & ~16;
            if ( temp == 0 ) center =1;
            else if ( temp == up         ) { center=0; xvalue = cent; yvalue = max;  currentx=cent;      currenty= cent+bump; }
            else if ( temp == down       ) { center=0; xvalue = cent; yvalue = 0;    currentx=cent;      currenty= cent-bump; }
            else if ( temp == left       ) { center=0; xvalue = max;  yvalue = cent; currentx=cent+bump; currenty= cent;      }
            else if ( temp == right      ) { center=0; xvalue = 0;    yvalue = cent; currentx=cent-bump; currenty= cent;      }
            else if ( temp == right+up   ) { center=0; xvalue = 0;    yvalue = max;  currentx=cent-bump; currenty= cent+bump; }
            else if ( temp == right+down ) { center=0; xvalue = 0;    yvalue = 0;    currentx=cent-bump; currenty= cent-bump; }
            else if ( temp == left+up    ) { center=0; xvalue = max;  yvalue = max;  currentx=cent+bump; currenty= cent+bump; }
            else if ( temp == left+down  ) { center=0; xvalue = max;  yvalue = 0;    currentx=cent+bump; currenty= cent-bump; }
            else log_cb(RETRO_LOG_INFO, LOGPRE "unhandled condition %d\n",temp);
            counter = 0;
          else counter++;
          if (whichport == 0)
            if (center)
              return currentx;
            return xvalue;
          else if (whichport == 2)
            if (center)
              return currenty;
            return yvalue;
        else // use original inputs
          return readinputport(whichport);
        grant2258 Banned
        ok just put the counter in if your horizontals arent sticking havent tested it on the pie yet just on a windows box will let you know how i get on. I have a few other things in tinkering with havent spent a great deal of time on this
          @grant2258 the counter is in, I just moved where it is so direction is always defined on each read but the position is not updated unless it's on the right count.
          We could probably initialize direction normally this way too instead of undefined and remove the if statement
          Like this
            #define max  255
            #define cent 128
            #define bump 51;
            #define up   1
            #define down 2
            #define left 4
            #define right 8
            static INT16  direction = readinputport(6);
            int temp;
              if (counter == 8)
                counter = 0;
              else counter++;
              if (whichport == 0)
                if (center)
                  return currentx;
                return xvalue;
                if (center)
                  return currenty;
                return yvalue;
            grant2258 Banned
            strange ill checkout it out on the pi. You need to understand something about this code. This function only reads one axis at a time x then y over and over at high speeds keep that in mind if you make changes.
              @grant2258
              It's seems to work good, the only issue I had was on the first run of the code direction wasn't defined so temp was trying to use an undefined variable and it caused glitches.
              So I changed it slightly,
              This version should solve it:
              Outdated
                #define max  255
                #define cent 128
                #define bump 51
                #define up    1
                #define down  2
                #define left  4
                #define right 8
                static INT16  currentx  = 0x80; // face left first round
                static INT16  currenty  = 0x7F;
                static INT16  delay = 0;
                  if (delay == 8) // debounce protection
                    int temp = readinputport(6) & ~16;
                    delay = 0;
                  else delay++;
                  if (whichport == 0)
                    if (center)
                      return currentx;
                    return xvalue;
                    if (center)
                      return currenty;
                    return yvalue;
                mahoneyt944
                Temp should also be defined inside the "delay" debounce section so it's not repeatily initialized. So it's initialized when we actually go to use it. Updated it above . I'll test it later
                And great work. This is a very clever solution.
                  grant2258 Banned
                  actually that code isint there at all i just told you can increase the loop.
                  https://github.com/grant2258/Blaster-Barcade/commit/3d1f20d2bcc51552672119cdded187633cdfe1d7#diff-4b920d5f055f4340a0d6485c3bc5846eR199
                  this code always ensures the last direction is set was sent regardless if your missed read direction or not. the last position pressed is returned always. you should only have the delay around the reading the input port.
                  The only change you need to make is change
                  UINT16 direction;
                  to static UINT16 direction =0; so its initialized at center when adding the delay loop.
                  was only originally there incase somone set cocktail mode thats reads 1 and 3 for player 2
                    @grant2258
                    Correct it has to be static, That was my thinking. That's what I meant by the first time read it wasn't set. That's what caused my issue before.
                    With that fixed, coded your way it updates direction once every 8 count but writes to the xcurrent, ycurrent, xvalue, yvalue on every count, which it doesn't need to since it's using the same direction value every time it writes. So I changed your code to update direction once every 8 count and write to xcurrent, ycurrent, xvalue, yvalue on every 8 count too.
                    They both do the same thing, my version of your code just uses more efficiency when setting the variables.
                    Then I moved int temp into it's scope so it's not initialized on every count but only when being used.
                    Im glad it's working now regardless, I can't help thinking if we did something similar we could fix true analog stops too. Obviously 8 way is the best we can do on digital. Making mame2003-plus the home of working food fight lol. 💪, Unofficially.
                    It's easier with digital because it's 8-way on or off movements but analog has range so you'd need to know the range of each direction.
                      grant2258 Banned
                      Well this game isint 49 way its two pots on a gambit. Ie really big ass thumb stick. The code is sending back like this for a reason.
                      Say you read x pause and y doesnt get updated your centering will be off because your only sending one axis back (it only reads one at a time0) and the other one got missed the x and y being off can effect your positioning. You looking at the code like its digital and its not you need to mimic an analog stick it was reading at this rate in the first place. the original code always met this condition anyway so it wasnt an issue until a delay was added i just showed you some code how to easily implement it.
                      It seems you know what your doing hopefully this we help you understand a iittle more if you wanna try fix something else. To be honest I never payed this game before I like it but the music sucks balls! doorooh doooroho doooooooooooooooo aaaaaaaaaaaaarg
                        @grant2258
                        What I'm getting at is, I test games on my spare pi outside my arcade cab which uses a PS2 style controller so it has digital and analog to work with. If I set the new center digital feature off and the cheat input feature off my digital keeps running as expected and analog will stop but always facing right. While still moving, analog has crisp moving directions between that of a 8 way control as it should.
                        If I turn centering on both digital and analog stop to the right. Analog still has it crisp movements though.
                        Now turn on cheat input. Both digital and analog stop correctly but analog is cut to 8 way movements because of the returns in the cheat input feature (which I know it's not meant for analog).
                        If we coded this part:
                        To instead look for current analog positions, and return stops positions, analog could also benefit from fixed stops without being reduced to 8 way. It just has a lot more positions to account for.
                        You'd need a grid chart to define each direction range of both pots(x and y) to use as a lookup table then determine a stop from it based on your position.
                          grant2258 Banned
                          to be honest the game should re calibrate when you use it a while the game is coded this way. The grid you work out can change you need to know what the self calibrating code is doing in the game.
                          The ps2/3/4/xbox360 pads are useless for this game the analog resolution its too low on them its not too bad on a xbox one though. the digital code leaves you facing your last direction if you code it properly i have no issues with it. I will test this on the pi and let you know if i have any issues with the digital. The thing with the original is the joystick might not have self centered either.
                            @grant2258 so you're saying if you use a Xbox one controller analog stick it doesn't snap right everytime you stop? And because PS2 analog has less range it snaps right?
                            I have no issue with digital with the fix implemented here. I'll probably just optimize the hell out of it and test and bugs.
                              grant2258 Banned @mahoneyt944
                              @mahoneyt944 yes if its centered it will snap right but it has a higher resolution you can circle the eyes easier ect
                                @grant2258 oh I see..... Well I don't care about moving the eyes when I'm stopped, as long as I stop facing where I last pressed. So this fix does just that for analog and digital. But the side effect is it reduces analog to 8 way movements....Since we are returning set movements and stops instead of actual positions when centering.
                                  grant2258 Banned
                                  im lost now the digital code on runs when you set the cheat options it in the if condition.
                                    @grant2258 I'm just saying this fix benefits when using analog sticks too but at the cost of cutting the analogs precision to 8 way. That's all. Analog always centers facing to the right and it sucks to play it that way. I know this input cheat is not intended for analog but using it with the analog stick allows you to center facing more properly.
                                    So it got me thinking if we use the off section of our cheat input option to correct analog to stop facing in the direction last pressed too it would complete the driver. It's just a lot more directions to account for on analog.
                                    Cheat Input Off would fix analog and on would fix digital.
                                    I'll never use analog because my cab has digital but it would be cool to see fixed for the benefit of the games emulation.
                                    To correct analog in this hypothetical cheat input off code it would be something like:
                                    if (centered) { return stop_direction;}
                                    Else return readinputport(whichport);
                                    The stop_direction would be set based on the last position your stick was in before centering. Similarly to what you did to fix digital . Just more directions to account for.
                                      grant2258 Banned
                                      you would need to look at that but thats not in the original games specs. The rolling just the eyes is important in analog controls in this game the gimbal lets you walk up to piles of food and throw it all directions without moving because it had such a big throw it would be easy to pull off. I think it would be a sane move to return 7f in digital if your going to switch between the two.
                                        @grant2258 agreed.
                                        So is Digital uses 0 to 255, 128 being center and analog uses 00 to FF, 7F being center? Correct?
                                        I'll look into it at a later date. No hurry right now though.
                                          grant2258 Banned
                                          nope analog uses 0 - 255 as well the fist 0xff hex is (255 decimal) ff is the mask the second 0x7f is default center value. the min and max are at the end
                                            @grant2258
                                            @Cornervizion
                                            Here's a true control fix for food fight that I'm calling "Live center - rev 3".
                                            Turning on cheat input ports activates the code for analog joysticks without debounce delay. If you're using a digital joystick, you must also turn on grant2258's centering fix which will use the same fix that analog uses but with debounce delay.
                                            Still some things I'd like to edit but I've had enough for today, probably a rev 4 coming soon though when I find more time. I plan to tighten up any dead zones for analog so every possible value is accounted for to be completely accuracy, its fairly close now though. I'd like to eventually implement this into an official driver for the game so it just finally "fixed" once and for all once it's perfect. Credit to grant2258 for his work done in the earlier code versions above that made this possible.
                                            For now though here's the WIP foodf.c driver with fixes implemented:
                                            Outdated
                                            	Atari Food Fight hardware
                                            	driver by Aaron Giles
                                            	Games supported:
                                            		* Food Fight
                                            	Known bugs:
                                            		* none at this time
                                            	Memory map
                                            	MAIN CPU
                                            	000000-00FFFF   R     xxxxxxxx xxxxxxxx   Program ROM
                                            	014000-01BFFF   R/W   xxxxxxxx xxxxxxxx   Program RAM
                                            	01C000-01CFFF   R/W   xxxxxxxx xxxxxxxx   Motion object RAM (1024 entries x 2 words)
                                            	                R/W   x------- --------      (0: Horizontal flip)
                                            	                R/W   -x------ --------      (0: Vertical flip)
                                            	                R/W   ---xxxxx --------      (0: Palette select)
                                            	                R/W   -------- xxxxxxxx      (0: Tile index)
                                            	                R/W   xxxxxxxx --------      (1: X position)
                                            	                R/W   -------- xxxxxxxx      (1: Y position)
                                            	800000-8007FF   R/W   xxxxxxxx xxxxxxxx   Playfield RAM (32x32 tiles)
                                            	                R/W   x------- --------      (Tile index MSB)
                                            	                R/W   --xxxxxx --------      (Palette select)
                                            	                R/W   -------- xxxxxxxx      (Tile index LSBs)
                                            	900000-9001FF   R/W   -------- ----xxxx   NVRAM
                                            	940000-940007   R     -------- xxxxxxxx   Analog input read
                                            	944000-944007     W   -------- --------   Analog input select
                                            	948000          R     -------- xxxxxxxx   Digital inputs
                                            	                R     -------- x-------      (Self test)
                                            	                R     -------- -x------      (Player 2 throw)
                                            	                R     -------- --x-----      (Player 1 throw)
                                            	                R     -------- ---x----      (Aux coin)
                                            	                R     -------- ----x---      (2 player start)
                                            	                R     -------- -----x--      (1 player start)
                                            	                R     -------- ------x-      (Right coin)
                                            	                R     -------- -------x      (Left coin)
                                            	948000            W   -------- xxxxxxxx   Digital outputs
                                            	                  W   -------- x-------      (Right coin counter)
                                            	                  W   -------- -x------      (Left coin counter)
                                            	                  W   -------- --x-----      (LED 2)
                                            	                  W   -------- ---x----      (LED 1)
                                            	                  W   -------- ----x---      (INT2 reset)
                                            	                  W   -------- -----x--      (INT1 reset)
                                            	                  W   -------- ------x-      (Update)
                                            	                  W   -------- -------x      (Playfield flip)
                                            	94C000            W   -------- --------   Unknown
                                            	950000-9501FF     W   -------- xxxxxxxx   Palette RAM (256 entries)
                                            	                  W   -------- xx------      (Blue)
                                            	                  W   -------- --xxx---      (Green)
                                            	                  W   -------- -----xxx      (Red)
                                            	954000            W   -------- --------   NVRAM recall
                                            	958000            W   -------- --------   Watchdog
                                            	A40000-A4001F   R/W   -------- xxxxxxxx   POKEY 2
                                            	A80000-A8001F   R/W   -------- xxxxxxxx   POKEY 1
                                            	AC0000-AC001F   R/W   -------- xxxxxxxx   POKEY 3
                                            	Interrupts:
                                            		IRQ1 = 32V
                                            		IRQ2 = VBLANK
                                            #include "driver.h"
                                            #include "machine/atarigen.h"
                                            #include "vidhrdw/generic.h"
                                            #include "foodf.h"
                                            #include "bootstrap.h"
                                             *	Statics
                                            static UINT8 whichport = 0;
                                             *	NVRAM
                                            static READ16_HANDLER( nvram_r )
                                            	return ((data16_t *)generic_nvram)[offset] | 0xfff0;
                                             *	Interrupts
                                            static void update_interrupts(void)
                                            	int newstate = 0;
                                            	if (atarigen_scanline_int_state)
                                            		newstate |= 1;
                                            	if (atarigen_video_int_state)
                                            		newstate |= 2;
                                            	if (newstate)
                                            		cpu_set_irq_line(0, newstate, ASSERT_LINE);
                                            	else
                                            		cpu_set_irq_line(0, 7, CLEAR_LINE);
                                            static void scanline_update(int scanline)
                                            	/* INT 1 is on 32V */
                                            	if (scanline & 32)
                                            		atarigen_scanline_int_gen();
                                            static MACHINE_INIT( foodf )
                                            	atarigen_interrupt_reset(update_interrupts);
                                            	atarigen_scanline_timer_reset(scanline_update, 32);
                                             *	Digital outputs
                                            static WRITE16_HANDLER( digital_w )
                                            	if (ACCESSING_LSB)
                                            		foodf_set_flip(data & 0x01);
                                            		if (!(data & 0x04))
                                            			atarigen_scanline_int_ack_w(0,0,0);
                                            		if (!(data & 0x08))
                                            			atarigen_video_int_ack_w(0,0,0);
                                            		coin_counter_w(0, (data >> 6) & 1);
                                            		coin_counter_w(1, (data >> 7) & 1);
                                             *	Analog inputs
                                              * Live Center - rev 3 - by mahoneyt944 & grant2258 *
                                              static INT16  currentx  = 0x80; // face left start of first round
                                              INT16 center = readinputport(6) & ~16; // check for joy center
                                              INT16 t = 0; // no debounce delay for analog
                                              // debounce delay for digital
                                              if (options.digital_analog) {t = 8; if (delay > t) delay = 0;}
                                              if (options.cheat_input_ports) // using cheat ports
                                                if (delay == t) // debounce protection
                                                  delay = 0;
                                                  if (whichport == 0) // x port called
                                                    if ( center == 0 ) {} // joy at center, no change
                                                    else
                                                      INT16 temp = readinputport(whichport); // find new x stop direction
                                                      if (temp > 128) // left
                                                        if (temp > 190) currentx = 190;
                                                        else currentx = temp;
                                                      else if (temp < 128) // right
                                                        if (temp < 65) currentx = 65;
                                                      else currentx = 128; // x at center
                                                  else if (whichport == 2) // y port called
                                                    else
                                                      INT16 temp = readinputport(whichport); // find new y stop direction
                                                      if (temp > 128) // up
                                                        if (temp > 190) currenty = 190;
                                                        else currenty = temp;
                                                      else if (temp < 128) // down
                                                        if (temp < 65) currenty = 65;
                                                      else currenty = 128; // y at center
                                                else delay++;
                                                // return x position
                                                if (whichport == 0)
                                                  if (center == 0)
                                                    return currentx;
                                                // return y position
                                                  if (center == 0)
                                                    return currenty;
                                              else // return original input
                                            static WRITE16_HANDLER( analog_w )
                                            	whichport = offset ^ 3;
                                             *	POKEY I/O
                                            static READ16_HANDLER( pokey1_word_r ) { return pokey1_r(offset); }
                                            static READ16_HANDLER( pokey2_word_r ) { return pokey2_r(offset); }
                                            static READ16_HANDLER( pokey3_word_r ) { return pokey3_r(offset); }
                                            static WRITE16_HANDLER( pokey1_word_w ) { if (ACCESSING_LSB) pokey1_w(offset, data & 0xff); }
                                            static WRITE16_HANDLER( pokey2_word_w ) { if (ACCESSING_LSB) pokey2_w(offset, data & 0xff); }
                                            static WRITE16_HANDLER( pokey3_word_w ) { if (ACCESSING_LSB) pokey3_w(offset, data & 0xff); }
                                             *	Main CPU memory handlers
                                            static MEMORY_READ16_START( readmem )
                                            	{ 0x000000, 0x00ffff, MRA16_ROM },
                                            	{ 0x014000, 0x01cfff, MRA16_RAM },
                                            	{ 0x800000, 0x8007ff, MRA16_RAM },
                                            	{ 0x900000, 0x9001ff, nvram_r },
                                            	{ 0x940000, 0x940007, analog_r },
                                            	{ 0x948000, 0x948001, input_port_4_word_r },
                                            	{ 0x94c000, 0x94c001, MRA16_NOP }, /* Used from PC 0x776E */
                                            	{ 0x958000, 0x958001, watchdog_reset16_r },
                                            	{ 0xa40000, 0xa4001f, pokey2_word_r },
                                            	{ 0xa80000, 0xa8001f, pokey1_word_r },
                                            	{ 0xac0000, 0xac001f, pokey3_word_r },
                                            MEMORY_END
                                            static MEMORY_WRITE16_START( writemem )
                                            	{ 0x000000, 0x00ffff, MWA16_ROM },
                                            	{ 0x014000, 0x01bfff, MWA16_RAM },
                                            	{ 0x01c000, 0x01cfff, MWA16_RAM, &spriteram16, &spriteram_size },
                                            	{ 0x800000, 0x8007ff, atarigen_playfield_w, &atarigen_playfield },
                                            	{ 0x900000, 0x9001ff, MWA16_RAM, (data16_t **)&generic_nvram, &generic_nvram_size },
                                            	{ 0x944000, 0x944007, analog_w },
                                            	{ 0x948000, 0x948001, digital_w },
                                            	{ 0x950000, 0x9501ff, foodf_paletteram_w, &paletteram16 },
                                            	{ 0x954000, 0x954001, MWA16_NOP },
                                            	{ 0x958000, 0x958001, watchdog_reset16_w },
                                            	{ 0xa40000, 0xa4001f, pokey2_word_w },
                                            	{ 0xa80000, 0xa8001f, pokey1_word_w },
                                            	{ 0xac0000, 0xac001f, pokey3_word_w },
                                            MEMORY_END
                                             *	Port definitions
                                            INPUT_PORTS_START( foodf )
                                            	PORT_START	/* IN0 */
                                            	PORT_ANALOG( 0xff, 0x7f, IPT_AD_STICK_X | IPF_PLAYER1 | IPF_REVERSE, 100, 60, 0, 255 )
                                            	PORT_START	/* IN1 */
                                            	PORT_ANALOG( 0xff, 0x7f, IPT_AD_STICK_X | IPF_PLAYER2 | IPF_REVERSE | IPF_COCKTAIL, 100, 60, 0, 255 )
                                            	PORT_START	/* IN2 */
                                            	PORT_ANALOG( 0xff, 0x7f, IPT_AD_STICK_Y | IPF_PLAYER1 | IPF_REVERSE, 100, 60, 0, 255 )
                                            	PORT_START	/* IN3 */
                                            	PORT_ANALOG( 0xff, 0x7f, IPT_AD_STICK_Y | IPF_PLAYER2 | IPF_REVERSE | IPF_COCKTAIL, 100, 60, 0, 255 )
                                            	PORT_START	/* IN4 */
                                            	PORT_BIT( 0x01, IP_ACTIVE_LOW, IPT_COIN1 )
                                            	PORT_BIT( 0x02, IP_ACTIVE_LOW, IPT_COIN2 )
                                            	PORT_BIT( 0x04, IP_ACTIVE_LOW, IPT_START1 )
                                            	PORT_BIT( 0x08, IP_ACTIVE_LOW, IPT_START2 )
                                            	PORT_BIT( 0x10, IP_ACTIVE_LOW, IPT_COIN3 )
                                            	PORT_BIT( 0x20, IP_ACTIVE_LOW, IPT_BUTTON1 | IPF_PLAYER1 )
                                            	PORT_BIT( 0x40, IP_ACTIVE_LOW, IPT_BUTTON1 | IPF_PLAYER2 )
                                            	PORT_SERVICE( 0x80, IP_ACTIVE_LOW )
                                            	PORT_START	/* SW1 */
                                            	PORT_DIPNAME( 0x07, 0x00, "Bonus Coins" )
                                            	PORT_DIPSETTING(    0x00, "None" )
                                            	PORT_DIPSETTING(    0x05, "1 for every 2" )
                                            	PORT_DIPSETTING(    0x02, "1 for every 4" )
                                            	PORT_DIPSETTING(    0x01, "1 for every 5" )
                                            	PORT_DIPSETTING(    0x06, "2 for every 4" )
                                            	PORT_DIPNAME( 0x08, 0x00, DEF_STR( Coin_A ))
                                            	PORT_DIPSETTING(    0x00, DEF_STR( 1C_1C ))
                                            	PORT_DIPSETTING(    0x08, DEF_STR( 1C_2C ))
                                            	PORT_DIPNAME( 0x30, 0x00, DEF_STR( Coin_B ))
                                            	PORT_DIPSETTING(    0x20, DEF_STR( 1C_4C ))
                                            	PORT_DIPSETTING(    0x10, DEF_STR( 1C_5C ))
                                            	PORT_DIPSETTING(    0x30, DEF_STR( 1C_6C ))
                                            	PORT_DIPNAME( 0xc0, 0x00, DEF_STR( Coinage ))
                                            	PORT_DIPSETTING(    0x80, DEF_STR( 2C_1C ))
                                            	PORT_DIPSETTING(    0xc0, DEF_STR( 1C_2C ))
                                            	PORT_DIPSETTING(    0x40, DEF_STR( Free_Play ))
                                              PORT_START	/* fake port for digital joystick control */
                                            	PORT_BIT( 0x01, IP_ACTIVE_HIGH, IPT_JOYSTICK_UP    | IPF_8WAY | IPF_CHEAT )
                                            	PORT_BIT( 0x02, IP_ACTIVE_HIGH, IPT_JOYSTICK_DOWN  | IPF_8WAY | IPF_CHEAT )
                                            	PORT_BIT( 0x04, IP_ACTIVE_HIGH, IPT_JOYSTICK_LEFT  | IPF_8WAY | IPF_CHEAT )
                                            	PORT_BIT( 0x08, IP_ACTIVE_HIGH, IPT_JOYSTICK_RIGHT | IPF_8WAY | IPF_CHEAT )
                                            INPUT_PORTS_END
                                             *	Graphics definitions
                                            static struct GfxLayout charlayout =
                                            	8,8,
                                            	RGN_FRAC(1,1),
                                            	2,
                                            	{ 0, 4 },
                                            	{ 8*8+0, 8*8+1, 8*8+2, 8*8+3, 0, 1, 2, 3 },
                                            	{ 0*8, 1*8, 2*8, 3*8, 4*8, 5*8, 6*8, 7*8 },
                                            	8*16
                                            static struct GfxLayout spritelayout =
                                            	16,16,
                                            	RGN_FRAC(1,2),
                                            	2,
                                            	{ RGN_FRAC(1,2), 0 },
                                            	{ 8*16+0, 8*16+1, 8*16+2, 8*16+3, 8*16+4, 8*16+5, 8*16+6, 8*16+7, 0, 1, 2, 3, 4, 5, 6, 7 },
                                            	{ 0*8, 1*8, 2*8, 3*8, 4*8, 5*8, 6*8, 7*8, 8*8, 9*8, 10*8, 11*8, 12*8, 13*8, 14*8, 15*8 },
                                            	8*32
                                            static struct GfxDecodeInfo gfxdecodeinfo[] =
                                            	{ REGION_GFX1, 0, &charlayout,   0, 64 },	/* characters 8x8 */
                                            	{ REGION_GFX2, 0, &spritelayout, 0, 64 },	/* sprites & playfield */
                                            	{ -1 }
                                             *	Sound definitions
                                            static READ_HANDLER( pot_r )
                                            	return (readinputport(5) >> offset) << 7;
                                            static struct POKEYinterface pokey_interface =
                                            	3,
                                            	600000,
                                            	{ 33, 33, 33 },
                                            	/* The 8 pot handlers */
                                            	{ pot_r, 0, 0 },
                                            	{ pot_r, 0, 0 },
                                            	{ pot_r, 0, 0 },
                                            	{ pot_r, 0, 0 },
                                            	{ pot_r, 0, 0 },
                                            	{ pot_r, 0, 0 },
                                            	{ pot_r, 0, 0 },
                                            	{ pot_r, 0, 0 },
                                            	/* The allpot handler */
                                            	{ 0, 0, 0 }
                                             *	Machine driver
                                            static MACHINE_DRIVER_START( foodf )
                                            	/* basic machine hardware */
                                            	MDRV_CPU_ADD(M68000, 6000000)
                                            	MDRV_CPU_MEMORY(readmem,writemem)
                                            	MDRV_CPU_VBLANK_INT(atarigen_video_int_gen,1)
                                            	MDRV_FRAMES_PER_SECOND(60)
                                            	MDRV_VBLANK_DURATION(DEFAULT_60HZ_VBLANK_DURATION)
                                            	MDRV_MACHINE_INIT(foodf)
                                            	MDRV_NVRAM_HANDLER(generic_1fill)
                                            	/* video hardware */
                                            	MDRV_VIDEO_ATTRIBUTES(VIDEO_TYPE_RASTER)
                                            	MDRV_SCREEN_SIZE(32*8, 32*8)
                                            	MDRV_VISIBLE_AREA(0*8, 32*8-1, 0*8, 28*8-1)
                                            	MDRV_GFXDECODE(gfxdecodeinfo)
                                            	MDRV_PALETTE_LENGTH(256)
                                            	MDRV_VIDEO_START(foodf)
                                            	MDRV_VIDEO_UPDATE(foodf)
                                            	/* sound hardware */
                                            	MDRV_SOUND_ADD(POKEY, pokey_interface)
                                            MACHINE_DRIVER_END
                                             *	ROM definition(s)
                                            ROM_START( foodf )
                                            	ROM_REGION( 0x10000, REGION_CPU1, 0 )	/* 64k for 68000 code */
                                            	ROM_LOAD16_BYTE( "301-8c.020",   0x000001, 0x002000, CRC(dfc3d5a8) SHA1(7abe5e9c27098bd8c93cc06f1b9e3db0744019e9) )
                                            	ROM_LOAD16_BYTE( "302-9c.020",   0x000000, 0x002000, CRC(ef92dc5c) SHA1(eb41291615165f549a68ebc6d4664edef1a04ac5) )
                                            	ROM_LOAD16_BYTE( "303-8d.020",   0x004001, 0x002000, CRC(64b93076) SHA1(efa4090d96aa0ffd4192a045f174ac5960810bca) )
                                            	ROM_LOAD16_BYTE( "304-9d.020",   0x004000, 0x002000, CRC(ea596480) SHA1(752aa33a8e8045650dd32ec7c7026e00d7896e0f) )
                                            	ROM_LOAD16_BYTE( "305-8e.020",   0x008001, 0x002000, CRC(e6cff1b1) SHA1(7c7ad2dcdff60fc092e8a825c5a6de6b506523de) )
                                            	ROM_LOAD16_BYTE( "306-9e.020",   0x008000, 0x002000, CRC(95159a3e) SHA1(f180126671776f62242ec9fd4a82a581c551ffce) )
                                            	ROM_LOAD16_BYTE( "307-8f.020",   0x00c001, 0x002000, CRC(17828dbb) SHA1(9d8e29a5e56a8a9c5db8561e4c20ff22f69b46ca) )
                                            	ROM_LOAD16_BYTE( "308-9f.020",   0x00c000, 0x002000, CRC(608690c9) SHA1(419020c69ce6fded0d9af44ead8ec4727468d58b) )
                                            	ROM_REGION( 0x2000, REGION_GFX1, ROMREGION_DISPOSE )
                                            	ROM_LOAD( "109-6lm.020",  0x000000, 0x002000, CRC(c13c90eb) SHA1(ebd2bbbdd7e184851d1ab4b5648481d966c78cc2) )
                                            	ROM_REGION( 0x4000, REGION_GFX2, ROMREGION_DISPOSE )
                                            	ROM_LOAD( "110-4d.020",   0x000000, 0x002000, CRC(8870e3d6) SHA1(702007d3d543f872b5bf5d00b49f6e05b46d6600) )
                                            	ROM_LOAD( "111-4e.020",   0x002000, 0x002000, CRC(84372edf) SHA1(9beef3ff3b28405c45d691adfbc233921073be47) )
                                            ROM_END
                                            ROM_START( foodf2 )
                                            	ROM_LOAD16_BYTE( "201-8c.020",   0x000001, 0x002000, CRC(4ee52d73) SHA1(ff4ab8169a9b260bbd1f49023a30064e2f0b6686) )
                                            	ROM_LOAD16_BYTE( "202-9c.020",   0x000000, 0x002000, CRC(f8c4b977) SHA1(824d33baa413b2ee898c75157624ea007c92032f) )
                                            	ROM_LOAD16_BYTE( "203-8d.020",   0x004001, 0x002000, CRC(0e9f99a3) SHA1(37bba66957ee19e7d05fcc3e4583e909809075ed) )
                                            	ROM_LOAD16_BYTE( "204-9d.020",   0x004000, 0x002000, CRC(f667374c) SHA1(d7be70b56500e2071b7f8c810f7a3e2a6743c6bd) )
                                            	ROM_LOAD16_BYTE( "205-8e.020",   0x008001, 0x002000, CRC(1edd05b5) SHA1(cc712a11946c103eaa808c86e15676fde8610ad9) )
                                            	ROM_LOAD16_BYTE( "206-9e.020",   0x008000, 0x002000, CRC(bb8926b3) SHA1(95c6ba8ac6b56d1a67a47758b71712d55a959cd0) )
                                            	ROM_LOAD16_BYTE( "207-8f.020",   0x00c001, 0x002000, CRC(c7383902) SHA1(f76e2c95fccd0cafff9346a32e0c041c291a6696) )
                                            	ROM_LOAD16_BYTE( "208-9f.020",   0x00c000, 0x002000, CRC(608690c9) SHA1(419020c69ce6fded0d9af44ead8ec4727468d58b) )
                                            ROM_END
                                            ROM_START( foodfc )
                                            	ROM_LOAD16_BYTE( "113-8c.020",   0x000001, 0x002000, CRC(193a299f) SHA1(58bbf714eff22d8a47b174e4b121f14a8dcb4ef9) )
                                            	ROM_LOAD16_BYTE( "114-9c.020",   0x000000, 0x002000, CRC(33ed6bbe) SHA1(5d80fb092d2964b851e6c5982572d4ffc5078c55) )
                                            	ROM_LOAD16_BYTE( "115-8d.020",   0x004001, 0x002000, CRC(64b93076) SHA1(efa4090d96aa0ffd4192a045f174ac5960810bca) )
                                            	ROM_LOAD16_BYTE( "116-9d.020",   0x004000, 0x002000, CRC(ea596480) SHA1(752aa33a8e8045650dd32ec7c7026e00d7896e0f) )
                                            	ROM_LOAD16_BYTE( "117-8e.020",   0x008001, 0x002000, CRC(12a55db6) SHA1(508f02c72074a0e3300ec32c181e4f72cbc4245f) )
                                            	ROM_LOAD16_BYTE( "118-9e.020",   0x008000, 0x002000, CRC(e6d451d4) SHA1(03bfa932ed419572c08942ad159288b38d24d90f) )
                                            	ROM_LOAD16_BYTE( "119-8f.020",   0x00c001, 0x002000, CRC(455cc891) SHA1(9f7764c15dea7568326860b910686fec644c42c2) )
                                            	ROM_LOAD16_BYTE( "120-9f.020",   0x00c000, 0x002000, CRC(34173910) SHA1(19e6032c22d20410386516ffc1a809ae50431c65) )
                                            ROM_END
                                             *	Game driver(s)
                                            GAMEC( 1982, foodf,  0,     foodf, foodf, 0, ROT0, "Atari", "Food Fight (rev 3)",    &foodf_ctrl, &foodf_bootstrap  )
                                            GAMEC( 1982, foodf2, foodf, foodf, foodf, 0, ROT0, "Atari", "Food Fight (rev 2)",    &foodf_ctrl, &foodf_bootstrap  )
                                            GAMEC( 1982, foodfc, foodf, foodf, foodf, 0, ROT0, "Atari", "Food Fight (cocktail)", &foodf_ctrl, &foodfc_bootstrap )
