    Not able to connect with VNC Viewer
    vncsshvnc viewerretropie 4.6raspberry pi 4
    8 Posts 2 Posters 4.3k Views
    • Jacksons20J
      Jacksons20
      So I just got Retropie 4.6 because it worked for my Raspberry pi 4 and I installed it without Raspian because it always takes a very long time to get the setup running. I tried to use VNC Viewer for it and I enabled SSH and it gives me an error each time I try to turn it on. Do I have to install Raspian to get VNC Viewer working?
        @Jacksons20 said in Not able to connect with VNC Viewer:
        Retropie is built on Raspbian, so not sure what you need to install, but I guess the desktop/X.org environment ?
        Note that RetroPie doesn't support working from the desktop/X.org session, but install and the desktop from EmulationStation - https://retropie.org.uk/docs/FAQ/#where-did-the-desktop-go.
        Jacksons20J 2 Replies Last reply Reply Quote 0
        • Jacksons20J
          Jacksons20 @mitu
          @mitu I think I might just live with it but I will try to figure it out. Thanks for the help!
          • Jacksons20J
            Jacksons20 @mitu
            @mitu Well I tried what the doc said and it gave me this message when I did 'startx' message.jpg
              mitu Global Moderator @Jacksons20
              @Jacksons20 I think the message is self explanatory - only console users can use startx. You have to choose between running EmulationStation (and the emulators) or the desktop environment, where you can use VNC.
              Jacksons20J 1 Reply Last reply Reply Quote 0
              • Jacksons20J
                Jacksons20 @mitu
                @mitu Well I only have the base image of Retropie 4.6, but I want to be able to play Retropie from my computer, would I just choose Emulationstation?
                And does it give me a choice?
                  @Jacksons20 Then install an emulator on the computer then ?
                  Who ?
                  • Jacksons20J
                    Jacksons20 @mitu
                    @mitu VNC still says that there is no desktop there and its running
