    Raspberry 4 HDMI resolution Problem
    hdmi raspi4
    7 Posts 4 Posters 455 Views
    • O
      olivfpv
      Hi,
      I'm pretty new in the emulation word and even more in the raspberry one
      here my setutup
      Raspberry 4 B 4Go
      viewsonic vx3276 1990 X 1080
      power supply : already tried many
      Build From : I ve tried with noobs, raspberry imager,
      when it boot I pass the first rainbow, then raspberry it got an error message saying
      lvl10: error creating dsl windows
      could not initialize Egl
      lvl10: renderer failed to initialize
      lv10 windows failed to initialise
      To be honest since I got this raspberry 4 its a lot of trouble for everything with this hdmi resolution problem
      I only succeed to install raspian and it was a lot of fight to make it work
      I ve tried to edit the config.txt with my setup of the rasbian which is working but nothing is happening
      I ve tried do disable gl driver
      Does somebody as an idea to how fix it ?
      Thank you
        dankcushions Global Moderator
        Raspberry 4 B 4Go
        what is this?
        assuming you mean rpi4, just use the rpi4 image provided: https://retropie.org.uk/download/
        O Thorr69T 2 Replies Last reply Reply Quote 0
        • O
          olivfpv @dankcushions
          @dankcushions thank for your answer I. have only of course downloaded the image provided for the rpi4
          as many users I have problem with the hdmi resolution
          I have tried everything I found
          raspi_config
          edit the config.txt
          nothing is working
          • Thorr69T
            Thorr69 @dankcushions
            @dankcushions said in Raspberry 4 HDMI resolution Problem:
            Raspberry 4 B 4Go
            what is this?
            4Go = 4 Gigabytes
            RPi 3b
            Official PSU
            Official RetroPie image
            Pandora's Box 5 controller
              Post your config.txt to see what is set there.
              I suppose this is actually 1920x1080.
              • O
                olivfpv
                Yes it is 1920x1080 it was already a pain installing rasbian I had to install a lite version go to raspotify config change the resolution and install a desktop environnement
                I have the same problem when I try to install Lakka, rétropie impossible to force the resolution to 1920x1080
                I don’t know if it’s me but I didn’t have so much problems with raspberry 3
                  @olivfpv said in Raspberry 4 HDMI resolution Problem:
                  You're mentioning a resolution setting, but your error in the first post is from EmulationStation. Post your config.txt and the output from tvservice -m DMT.
                  Disabling the OpenGL driver is not supported and RetroPie (and the majority of the emulators) will not work without it.
