    Controller Issue with Diswoe Switch Pro Controller
    controllerdiswoebluetoothproblem
    2 Posts 2 Posters 2.5k Views
      Bam666
      Pi Model or other hardware: Raspberry Pi 3 Model B+
      Power Supply used: 5V, 2,5A
      RetroPie Version Used: 4.6
      Built From: Pre made SD Image on RetroPie website - Filename: retropie-buster-4.6-rpi2_rpi3.img
      USB Devices connected: Cherry Keyboard
      Controller used: Diswoe Wireless Controller for Nintendo Switch (https://www.amazon.de/Diswoe-Wireless-Controller-Bluetooth-einstellbarem-schwarz-1/dp/B07TRQH45S)
      Hi there,
      I am having trouble to connect the mentioned Controller via Bluetooth. I can connect the Controller by holding down the Homebutton for a few seconds, then the Player LEDs are blinking fast. The System sees the Controller and I can connect, so it seems. The LEDs dont stop blinking, like it has trouble to indicate the Player Number or something like that. If I take a look in the Connected Device List the Controller is listed with the Alias "Pro Controller".
      If I go back to Emulationstation and want to configure the Inputs, there is the Message, that one Gamepad is available, but if I press any Button on the Controller it doesnt recognize it.
      Under /dev/input/ I have a js0, but I also tried it with jstest and no success. The Controller is recognized with the Alias "Pro Controller" but no Button has any effect.
      If I connect the Controller via USB it works just fine, but no success via Bluetooth.
      Bluetoothctl is also showing that the Controller is paired, trusted and connected.
      I dont know what to do. Maybe someone here can help me with some new ideas.
      Greetings
      Bam
        stefanbaranowski
        Hey Bam,
        Did you ever get this working in the end? I have the exact same issue, same controller as yourself but running on a Pi4.
        Wondering if it can be solved or if I should look at purchasing another controller.
        Thanks!
