    Journey sound sample in mame2003-plus, solved
    samplesjourney
    86 Posts 7 Posters 16.5k Views
    • RiverstormR
      Riverstorm
      Here's a link to the samples from Twisty's. The samples are still full length. I've only changed the sample rate and bit depth to make them quite a bit smaller (down to under 4MB). The information of each version is below. Let me know what you think of the quality if you listen to them.
      @grant2258 - I agree, I would love to see the original CD's from any of the 7 or 8 custom OST's that have been implemented into m3plus. If they are true CD quality I could easily rip and split the channels out for much better quality and then do a clean shrink.
      1. 44100 Hz, 16-bit, 1 channel - 15.4MB (Original WAV)
      2. 44100 Hz, 8-bit, 1 channel - 7.73MB
      3. 22050 Hz, 16-bit, 1 channel - 7.73MB
      4. 22050 Hz, 8-bit, 1 channel - 3.86MB
      If we can't link Twisty's samples just let me know and I'll remove them.
        mahoneyt944 @Riverstorm
        @Riverstorm grant fixed large sample support. Now they all work as they should. Pull request made if you want to test: https://github.com/libretro/mame2003-plus-libretro/pull/787/files
        • RiverstormR
          Riverstorm
          @mahoneyt944 - Ah, ok, that was quick!
          • RiverstormR
            Riverstorm
            @mahoneyt944 - By the way I did email Twinaphex asking if he might merge the pull requests (politely and with please ;) but they may be busy or affected by COVID or something but at least we tried. I did see markwkidd replied to an old issue last week but I can't find who or where to look to see who has those permissions on Github.
            • arcadez2003A
              arcadez2003 @mahoneyt944
              @mahoneyt944 said in Journey sound sample in mame:
              @arcadez2003 @grant2258
              OK, after beating the first level about 15 times..... I feel really good about the volume setting. It's just slightly louder than the game sounds which is what you want at a concert lol. I replaced the stop feature with mute so the first time you get to the bonus it plays from the intro. After that, every bonus scene gets a random clip of the song. Using stop you only get the intro and without pause this is a good compromise. I made a new pull request if you guys would test it out on other platforms..xbox, whatever. Let me know how it sound in the bonus and cassette menu. https://github.com/libretro/mame2003-plus-libretro/pull/787/files
              Significant changes require a small update to the whatsnew just so folks know about it long after this thread has been forgotten ;)
              https://github.com/libretro/mame2003-plus-libretro/pull/789/commits/35c29bc9d69cfc85a9b8754d1a52ac5398c6e58b
              Arcade Addict
                mahoneyt944 @arcadez2003
                @arcadez2003 lol very true, still need to adjust the level down though. It sounds good on my Vizio tv, but a bit loud in my cabinet. I'll try 100 on my cabinet.
                • RiverstormR
                  Riverstorm
                  @arcadez2003 - True, thanks, I find it very useful. Will the DAT need an update also to add the new sample?
                    @Riverstorm final version posted #787
                    Just compile it with the other changes if you want and add the sample.
                    bios/mame2003-plus/samples/journey.zip
                    Plays great.
                      mahoneyt944
                      Now that journey is sorted what game is this trio cracking into next? šŸ˜‚. Making some awesome improvements here. Nice work!
                      • RiverstormR
                        Riverstorm
                        @mahoneyt944 - Thanks for starting the work on this one. It's a great addition!
                        One of the best features of m3plus is dynamic DAT generation. I'm not sure what gets updated for it to work. Basically you can start any game and create a DAT file on the fly to build a current set. I know many just download/build sets manually but I prefer using ClrMamePro/DATs to stay current with sets and run them through every few months if there's changes/additions.
                          @Riverstorm
                          Now that's it fixed, I don't want to play it. šŸ˜… I had to beat the first level maybe 20+ times for testing. So I'm good on journey for awhile. If I ever get the itch to update it any, it would be cool to add more tracks. Maybe the whole album or some live versions?... then use a random pick each time you get to the bonus round instead of the mute feature we utilized. A journey machine should have more than one song in my opinion. But most people only play a round or two then move on so the repetitive nature doesn't set in haha. If I hear separate ways one more time!
                            mahoneyt944
                            @grant2258
                            I updated my repository then merged your sample pause support, created an official pull request for it as well. Thank you. #795
                              mahoneyt944
                              The volume of this sample seems to be off a bit. Other mames have it set at "25". When we were using the mute trick as a pause workaround the volume was set at "100". Now with pause functional, somewhere around "50" seems close. I have tested this on both my setups which are very different.
                              My cab setup uses a single speaker, 3.5 aux jack, to an amplifier which is bridged to get full sound out of one speaker.
                              My tv setup uses dual built in speakers through HDMI.
                              I find with my cab, the sample volume is very close to game sounds volume with "50" set but with my tv setup the sample is a bit quiet.
                              "75" is too loud in my cab.
                              Seems like something may need adjusted somewhere to get the sample volume more accurate but for now I made a pull request to set the volume to "60". Which is a mid point for my two setups. I'll have to look into it more when I get time.
                                grant2258 Banned
                                there is two place you can change the volume mixer volume and the sample itself.
                                struct Samplesinterface journey_samples_interface =
                                	1,
                                	25,
                                	journey_sample_names
                                static WRITE_HANDLER( journey_sample_select_w )
                                  /* start sample with looping on and pause it) */
                                  if (!sample_playing(0) )
                                    sample_start(0, 0, 1);
                                    sample_set_pause(0, 1);
                                    sample_set_volume(0,100);
                                    sample_set_pause(0, ~data & 1);
                                and
                                	1,
                                	5,
                                will give you a completely different 100% volume to keep some sanity set both amps to 50% volume so they are at the same levels when comparing.
                                  mahoneyt944 @grant2258
                                  @grant2258
                                  I was playing with the sample volume before but couldn't get it quite right for both setups. This seemed to be close though.
                                  	1,
                                  	100,
                                      sample_set_volume(0, 100);
                                  Or else this
                                  	1,
                                  	60,
                                    grant2258 Banned
                                    well the values are up to you if you think that sits at the right level with the normal game music will be fine.I would imagine the lower frequencies like the bass would distort when you put the volume up if its too loud when you put the amp volume up.
                                      @grant2258 I'll have to test it more and figure out where it sounds best.
                                        grant2258 Banned
                                        I wouldnt worry about it too much if i where you if it sounds ok to you should be fine.
                                        • arcadez2003A
                                          arcadez2003
                                          @grant2258 said in Journey sound sample in mame2003-plus, solved:
                                          Good job on adding the sample pausing feature, i'll look into porting this across to the xbox cores sometime.
                                          Arcade Addict
                                          • Lyle_JPL
                                            Lyle_JP
                                            If memory serves, the cassette single used in the original Journey machine was mono. Using a high quality stereo rip from CD doesn't just cause space and memory issues, it's also less authentic.
