    Journey sound sample in mame2003-plus, solved
    samplesjourney
    86 Posts 7 Posters 16.4k Views
      mahoneyt944 @grant2258
      @grant2258 no, I'm at work so I can't right now. What happens though is when I go to the service menu and enter the cassette test menu. When I flip the up button to start the cassette I hear screeching. If I press down it stops. If I let it play eventually after about 30 seconds it crashes the emulator and throws me to emulationstation. So I took that sample, opened it in audacity cut it to 1:50 (originally 3:03) then exported it as .wav 16 bit pcm. I retest the above senario and the sample works just fine. So next I try the cut sample at 1:55, this time I get the screech and crash. For some reason it doesn't like the sample size over a certain size.
      But then you got the sample to work through final fight, so I really don't know. It must be related to how we are initiating the sample with the mcr driver? Maybe the output is wrong, 2010mame looks like this:
      static DRIVER_INIT( journey )
      	mcr_init(machine, 91475, 91464, 90913);
      	mcr_sound_init(machine, MCR_SSIO);
      	ssio_set_custom_output(4, 0x01, journey_op4_w);
      And our 2003plus wip
      	MCR_CONFIGURE_SOUND(MCR_SSIO);
      	install_port_write_handler(0, 0x00, 0x00, mcr_control_port_w);
      	install_port_write_handler(0, 0x04, 0x04, journey_sample_select_w);
      	mcr12_sprite_xoffs = 0;
      	mcr12_sprite_xoffs_flip = 0;
      arcadez2003A 1 Reply Last reply Reply Quote 0
        grant2258 Banned
        to be honest i just compiled it a while back and got the same result not really looked into it much yet cold be anything need to see where its segfaulting to get a clue else your just guessing. The driver is completely different to the one we are using
          @grant2258 yeah that's the next step.
            skj @mahoneyt944
            Have you tried the sample at Twistys mame samples?
              mahoneyt944 @skj
              @skj I think it's the same sample from what I can tell
                grant2258 Banned
                https://github.com/libretro/mame2003-plus-libretro/blob/0134c428b75882aa474f78dbbf2c6ecde49b97b7/src/common.c#L302
                comment this for now and change it to if(1) something else must be triggering this will need to follow the code at some point this code.
                  @grant2258 that's what I was looking at earlier but passed it when you said about in being flac related. Does that fix the issue with the sample loading? Can't we just raise the GAME_SAMPLE_LARGE to fit our sample it's capped at 10 mb and our sample is 15+
                    grant2258 Banned
                    I think i know what the problem is there is a flag that checks if contents is ost sample
                    https://github.com/libretro/mame2003-plus-libretro/blob/0134c428b75882aa474f78dbbf2c6ecde49b97b7/src/sound/samples.c#L32-L45
                    will check it later on i would guess this is the issue with using big samples like this.
                      grant2258 Banned
                      @arcadez2003 do you have links to them samples you had to shrink sorted the problem will test the ole samples that never worked before as well. This is actually great doing it this way because it unloads the sample when it stops if its huge its so smaller systems like the mini collection can play the samples without loading em all at one time.
                      • arcadez2003A
                        arcadez2003 @grant2258
                        @grant2258 said in Journey sound sample in mame:
                        I still got the one for Teki Paki how to get it to ya though.?? im not sure if we can share samples on here.??
                        Arcade Addict
                          grant2258 Banned
                          think samples are ok to be honest as long as its not the full metallica collection! I could always drive round bring a thumb stick sanitize it throw it you while maintaining a two meter distance just for something to do during this lockdown is driving me nuts!. Seriously thrown me a link anywhere on github if you dont want to post a link here.
                          • arcadez2003A
                            arcadez2003 @mahoneyt944
                            @mahoneyt944 said in Journey sound sample in mame:
                            I think how i set it up is correct but when dealing with code written for a totally different driver and reworking it to fit our older one can always be problematic.
                            certainly all i know is with both my MAME72 and MAME84 xbox ports i can play the journey sample from twistys site from beginning to end with no problems.
                            and that's the full on sample btw i've not altered it whatsoever.
                            Now the main problem for me at least is listening to that uncool song so many times now has got me actually singing it in the shower etc etc :)
                            Arcade Addict
                            • arcadez2003A
                              Ok check the comments in my last commit to MAME2003+ in 10 mins or so
                              Arcade Addict
                                grant2258 Banned
                                cheers bud can post there so ill thank you now haha!
                                • arcadez2003A
                                  So whatya think @grant2258 the full on sample works for me with no issues on both my xbox standalone MAME ports so i assume the code i added to the driver is good
                                  can this be another of those issues caused by stuffing standalone emulator cores into a frontend.?? or maybe platform related as obviously none of ya's are using
                                  the xbox like i am.
                                  Arcade Addict
                                    grant2258 Banned
                                    This looks like it was an issue from adding the ost load and unload support it basically loads a sample if its small enough else it just loads it when its needed and unloads it when it stops when its bigger than a certain size. I added a condition in to fix tmnt samples not playing but it broke the samples that are too big if you didnt have the ost flag set. I just fixed it another way
                                    • arcadez2003A
                                      Right then so it's not my driver code, lovely to have that cleared up so now i can move on to something else and let you guys sort this out ha ha
                                      Arcade Addict
                                        grant2258 Banned
                                        Well this is nothing to do with me haha! It working spot on it too much. Just like that big sega update mate it was all good! @mahoneyt944 will be happy ill leave a link later with a fix for plus if he wants to add it there see there is a few pull request there lol.
                                          mahoneyt944
                                          @arcadez2003 @grant2258
                                          Good deal. I'm going to mess with the mute settings to figure out what actually works best in the bonus scene ...which means I have to play the hell out of this game. For some reason setting it to 25 in the interface made it sound too quiet, but that's the recommend level. I think this might be because the sample volume is being cut down before mixing so the game sounds are much louder.
                                          Basically instead of stopping the song I mute and unmute, this allows the song to play random clips Everytime you hit the bonus round. So a pause workaround. Since stop resets to the beginning of the song every time. It's a cleaver trick to get different audio clips
                                          I'll update with your patch before I test though then make the pull request on 2003plus once it sounds spot on.
                                            mahoneyt944
                                            OK, after beating the first level about 15 times..... I feel really good about the volume setting. It's just slightly louder than the game sounds which is what you want at a concert lol. I replaced the stop feature with mute so the first time you get to the bonus it plays from the intro. After that, every bonus scene gets a random clip of the song. Using stop you only get the intro and without pause this is a good compromise. I made a new pull request if you guys would test it out on other platforms..xbox, whatever. Let me know how it sound in the bonus and cassette menu. https://github.com/libretro/mame2003-plus-libretro/pull/787/files
                                            Scratch that. A bit loud on my cab, I'll back it down. More testing
