    FBA/NEO GEO PS4 Control not mapped
    neogeofba confcontrollersconfigurationfinal burn alphretoarch
    3 Posts 3 Posters 727 Views
      adamskix
      Hi,
      I have used retroarch to map my ps4 contoller to emulators on retropie. It is fine on Snes, Mame, Sega etc but does not work on Neo Geo and FBA games. I cannot even appear to get into the retroarch menu once I have started a game to change it. All I can do is get back to the menu by pressing L2 & R2 at the same time.
      Help please?
        barbudreadmon @adamskix
        @adamskix said in FBA/NEO GEO PS4 Control not mapped:
        Probably because you are using pifba, which is not a retroarch core. With all its hacks it shouldn't be called fba either actually.
        Except if you have a good reason to stay with pifba (are you on a pi0/pi1 ?), it's recommended to use the latest iteration of the fbalpha emulator, which is actually called fbneo now.
          Did you configure your controller in EmulationStation ? The configuration you set there should create automatically the configuration for RetroArch - so you don't need to re-configure it again in each libretro core.
          How did you install RetroPie ?
