    How do I save my Advance Mame Settings?
    advance mamemameconfig
    6 Posts 3 Posters 1.2k Views
    • JirynJ
      Jiryn
      Pi 4, 4GB of ram
      Raspberry Pi USB-C AC adapter
      V 4.6 downloaded from the site, updated to latest version through ethernet
      How do I save my advance mame settings?
      I hit tab, set up the games to run how I want.. but if I reset or change games I have to do it all again.
      I didn't see a save config option anywhere.
        gomisensei @Jiryn
        @Jiryn please read and follow https://retropie.org.uk/forum/topic/3/read-this-first.
        • JirynJ
          Jiryn
          Sorry, got ahead of myself and added the requested info!
          Didn't think it was as needed on general discussions.
          Thank you!
            jmbooth2000
            advmame automatically saves anyupdated setting on exit it you have "config save_at_exit" in your advmame.rc file. You can find it in ~/.advance/advmame.cfg.
            Unfortunately there is a bug they are working on that may also require you to set "misc_smp no". This isn't ideal as it turns off multiprocessor support for this emulator. That said I didn't notice much impact on a Pi4.
            Once you have done that when you exit advmame normally (i.e. whatever you set the ui_cancel function to.
            There is a thread I found and commented on earlier today as I was struggling with exactly the same issue.
            Jonathan
            JirynJ G 2 Replies Last reply Reply Quote 0
            • JirynJ
              Jiryn @jmbooth2000
              @jmbooth2000 said in How do I save my Advance Mame Settings?:
              Jonathan
              Let's see if it'll let me access it via scp now, last time I tried it denied my pc but liked my laptop.. odd.
                gomisensei @jmbooth2000
                @jmbooth2000 yeah, i was just trying to make sure he had the pi4 issue before posting that same thing.
