    Audio issues after latest Raspbian updates (June 2020)
    audiobusteremulationstatioraspbianupdate
    104 Posts 27 Posters 66.2k Views
      MISTERHOLLYW00D
      I have some audio issues. Not sure if anyone here knows how to fix this.
      I use this user created script that allows for a volume switch of off medium high.
      This worked fine but since the update its ran to some issues. When system is rebooted the switch might not work anymore.
      Plus on the Pi4 it won't work at all.
      I think its the PCM not being located
      Here is the script I'm using
      https://drive.google.com/file/d/1oy5WzMGDGdXXdjEkhYcXtn7YQCJzAdbb/view
      https://icculus.org/~icculus/dotplan/arcade1up/arcade1up-volume-gpio.c
        mitu Global Moderator @MISTERHOLLYW00D
        @MISTERHOLLYW00D said in Audio issues after latest Raspbian updates:
        Here is the script I'm using...
        You'll have to ask the user that created the script to amend it for the changes brought by the Raspbian Linux kernel updates. You can try replacing "PCM" in the source code with the correct mixer name (HDMI/Headphones, depending on what you use for audio output) and re-compile the .c file included in the instructions.
        UberLumbyU 1 Reply Last reply Reply Quote 0
        • UberLumbyU
          UberLumby @mitu
          Does this by chance effect the audio playing games? I've noticed some consoles have very low audio compared to others even when I have my sound settings at 100% but I don't see any errors I have BGM on emulation station that still works fine
          [Linux 5.10.103-v7+ armv7l GNU/Linux
          Retropie 4.8
          Raspberry Pi 3B+]
            mitu Global Moderator @UberLumby
            @UberLumby No, the info in this topic applies to EmulationStation only.
            • Y
              Yobiwan
              I had to revert to the previous Audio configuration in order to use 3.5mm output. It works now, but splashscreen's audio is distorted. Like metallic sound...
              I downgraded firmware but same issue.
                mitu Global Moderator @Yobiwan
                @Yobiwan Don't understand why, the headphone jack works fine in either configurations (upgraded kernel/firmware or not).
                • XEntombmentXX
                  XEntombmentX
                  When I originally installed RetroPie, I had no audio whatsoever and this worked great for fixing both in-game and in the menu. However, I screwed something up somewhere along the line, so I reimaged my SD card and did a clean install. After that, and after going through all of these steps, I have sound in my ROMs, but not in EmulationStation menu itself.
                  I'm going through HDMI, which has been set in the Audio menu in RetroPie, in raspi-config, and retropie_setup (which has been updated). My EmulationStation core package is updated from source (for whatever reason, it's not giving me a version number). My sound in EmulationStation is set to Default, HDMI, ALSA.
                  Pi Model: 4B+
                  Power Supply: Pi Brand Supply
                  RetroPie Version: 4.6.7
                  Built From: RPi Imager to microSD
                  USB Devices: WD 2TB external HDD
                  Controller: Xbox One S controller, wired
                    Did you also update the kernel/firmware during the updates ? EmulationStation's version appears when you bring up the menu with Start in the main carousel.
                    XEntombmentXX 2 Replies Last reply Reply Quote 0
                    • XEntombmentXX
                      XEntombmentX @mitu
                      @mitu said in Audio issues after latest Raspbian updates:
                      I thought I did, but I'll try it again.
                      Ah okay, it's 2.9.3RP
                      • XEntombmentXX
                        XEntombmentX @mitu
                        @mitu I made sure to update the kernel and other underlying packages and the issue still persists.
                          mitu Global Moderator @XEntombmentX
                          @XEntombmentX If you run
                          uname -r && aplay -l
                          what's the output ?
                          XEntombmentXX 1 Reply Last reply Reply Quote 0
                          • XEntombmentXX
                            XEntombmentX @mitu
                            5.4.51-v7l+
                            card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
                              Subdevices: 4/4
                              Subdevice #0: subdevice #0
                              Subdevice #1: subdevice #1
                              Subdevice #2: subdevice #2
                              Subdevice #3: subdevice #3
                            card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
                              Subdevices: 4/4
                              @XEntombmentX This looks ok. Are you able to set the volume in EmulationStation without the errors shown in the starting post ? Do you have sound enabled in EmulationStation ?
                              • XEntombmentXX
                                XEntombmentX @mitu
                                @mitu Yes, it keeps the volume at the level I've set it to, navigation sounds are on, no errors when launching games.
                                  @XEntombmentX I can't think of anything else - I would have said to check if the volume is muted, but if it works in games, then it shouldn't be necessary.
                                  • XEntombmentXX
                                    XEntombmentX @mitu
                                    @mitu Huh, I changed my theme and back again and it's working fine now. That's strange, but hey, I'm just glad it works :D
                                      kactius
                                      HI everyone:
                                      Pi Model :(2B, pi3, pi3b+)
                                      Power Supply used: official
                                      RetroPie Version Used : retropie-buster-4.6-rpi2_rpi3 update retropie setup script to 4.6.8 last commit 5days ago 0ce9f214
                                      Emulationstation by source V2.9.3RP
                                      Kernel: 5.4.68-v7+
                                      Built From: RetroPie website, and update by me hand retropie setup, packages and system.
                                      Raspi-config 20200902
                                      I have a strange change that I can't understand how to change it or understand what it can affect
                                      By the moment.... I just have no sound when I change resolution from 1920 to a lower resolution and/or when change audio menu options in emulationstation
                                      Attention to : kernel version and Subdevices: 3/4
                                      Working in hdmi :
                                      Audio Card: Default
                                      Audio Device: HDMI
                                      OMX Audio Device: ALSA
                                      Change to headphone lost all sound.
                                      Symptoms include:
                                      Error messages showing when a game is launched (lvl0: VolumeControl::init() - Failed to find mixer elements).
                                      Sound missing in EmulationStation and/or games.
                                      System Volume slider stuck at 0% in EmulationStation's Sound settings.
                                      Other Symptoms:
                                      In ocassions is imposible to restart system...
                                      5.4.68-v7+
                                        Subdevices: 3/4
                                        Subdevices: 4/4
                                      By the moment only find a solution downgrade kernel from 5.4.68-v7+ to 5.4.51-v7+
                                      sudo apt update
                                      sudo apt install --reinstall libraspberrypi0 libraspberrypi-{bin,dev,doc} raspberrypi-bootloader raspberrypi-kernel
                                        mitu Global Moderator @kactius
                                        @kactius How is your issue related to the topic at hand, which is about EmulationStation ? Open a new topic and add the info from https://retropie.org.uk/forum/topic/3/read-this-first.
                                          kactius @mitu
                                          @mitu sorry, ok maybe it's more of a system error produced by me or something else than something else. And that I don't understand or can't find the correct way to fix it.
                                          Update my first post in this threat... % solved
                                            bcnr33hideaki @kactius
                                            @kactius said in Audio issues after latest Raspbian updates:
                                            @kactius any luck fixing your issue? I got the exactly same issue as you.
                                            My uname and iplay is exactly the same.
                                            Thanks.
