    Audio issues after latest Raspbian updates (June 2020)
    audiobusteremulationstatioraspbianupdate
    104 Posts 27 Posters 73.2k Views
      mitu Global Moderator @Sid1968
      @Sid1968 as said in the topic starter, you can get back to your previous configuration without downgrading anything. There's no reason to use rpi-update.
      S Y 2 Replies Last reply Reply Quote 0
        Sid1968 @mitu
        @mitu Ok i agree. :-)
        • Y
          Yobiwan @mitu
          @mitu Is it possible to prevent this error message to appear again by reverting back to previous configuration ?
            mitu Global Moderator @Yobiwan
            @Yobiwan Yes, but I wouldn't recommend that. You have the new settings explained in the first port, once you set them, you shouldn't get any error.
            Y 1 Reply Last reply Reply Quote 0
            • Y
              Yobiwan @mitu
              @mitu OK thanks ! i'm out of data for this month (deep countryside!) so in a few days I will try updating all of that.
                amansur
                @mitu, Hi, I am running my Raspberry Pi 3b+ with an audio jack and I've been having sound problems as mentioned in this post (no audio from games, although I can verify my computer's audio works by running an mp3 file on omxplayer). The errors I've been getting when trying to change my audio settings in emulation station is "lvl0: VolumeControl::init() - Failed to attach to default card". I followed all the steps and configured the audio in the menu as you suggested. But, still hasn't solved anything, unfortunately.
                I've been looking through blog posts all day trying to fix this, but it hasn't been working. If you'd like me to make a new post and list my system specs and whatnot, please let me know, and thank you.
                  amansur @amansur
                  @amansur Nvm, I gave up and just decided to reboot everything on the pre-installed image. For those that manually installed and are having trouble like I was and nothing seemed to be working, just do that. My recommendation.
                  • Y
                    Yobiwan
                    Error message has gone, ingame audio is back, but my intro video has no audio anymore...
                    mituM 1 Reply Last reply Reply Quote 1
                      @Yobiwan Please open a separate topic and add your system info, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first.
                      • U
                        undrwater @amansur
                        @amansur
                        When you say "just do that", what is the "that" that you're talking about?
                        Nothing from the above has fixed audio here, and I'm getting the same error.
                        Just an FYI, this is a freshly flashed image on an SD card in an RPi 3b.
                          amansur @undrwater
                          @undrwater Sorry for not being clear. What I mean by "that" is simply downloading the RetroPie software from the pre-made image as opposed to the manual installation. After doing so, I was able to figure it out.
                          Since you are still getting issues, after the installation, I followed these instructions from this video:
                          . I did not have to edit any config files, as these instructions do so automatically.
                          By audio settings currently are: Audio Card (Default), Audio Device (PCM), Enable Navigation Sounds (On) Enable Video Audio (ON), DMX Player Audio Device (Local).
                          It's worth noting that when I type in "uname -r" I see my version is "4.19.97-v7+" but in my old configuration (before I went with the flashed installation) it was at 4.19.118 or above. So if you followed the instructions in the video AND you have a lower kernel number than 4.19.118, then you should be fine... If your kernel number is at or above 4.19.118 and the post's instructions didn't work, then try downgrading the kernel. In essence, that's what I probably ended up doing when I switched over.
                            @amansur said in Audio issues after latest Raspbian updates:
                            This is not recommended, as mentioned before. The first post has instructions on how to configure your sound if your wish to use the previous configuration style (single audio device) with newer Linux kernel versions.
                              draxd
                              Hello,
                              I have encountered this problem and now I have no sound on my image . What I think happened in my case is that on boot Retropie updated firmware and kept old kernel modules that do not work with this firmware. I'm not expert here, so maybe I'm talking silly. I presume firmware is only rewritten when new version is found.
                              I do have backup of my image from time when it worked properly. Is there any way to revert to my old firmware and disabled updates of firmware ?
                              Thanks.
                                @draxd said in Audio issues after latest Raspbian updates:
                                If you used apt to update your system, then I don't think that's the case. The only method I'm aware that can mix/match kernel and firmware versions is using rpi-update and skipping kernel updates.
                                The subject of this topic is how to change the settings so your audio works after the latest update, why do you want to downgrade instead of applying these new settings ?
                                  draxd @mitu
                                  Hi, I managed to fix it by updating kernel and fallowing your instructions. Thanks.
                                  I do not know how system updated to latest version of firmware. I pretty much did nothing. My Raspberry pi was offline for
                                  pretty long time (for few months, playing retro games don't really requires internet) and this happened first time I rebooted it after connecting to Internet.
                                    tendiesaregood
                                    @mitu i am working on my first project ever, and i just started working on audio today. i have the pi zero w, and i plugged headphones into the display, which is connected to hdmi. i have never had it working and the volume slider keeps resetting to 0%. which fix should i try?
                                      mitu Global Moderator @tendiesaregood
                                      @tendiesaregood The Pi zero W doesn't have an analog jack, just the miniHDMI port, so your sound should be configured with HDMI.
                                      momentarydogmaM V 2 Replies Last reply Reply Quote 0
                                      • momentarydogmaM
                                        momentarydogma @mitu
                                        @mitu This is driving me absolutely batty... I set up the latest version of Retropie (4.6) downloaded directly from the website this morning to install on my 3B+. Upon first boot, I am able to do everything normally, but I have no sound and no matter what option I select from the menu, I get a message saying "failed to find mixer elements". I am using an HDMI monitor with no built-in speakers, so I have a small USB amplifier with a 3.5mm audio jack plugged into the Pi. I have tried everything on this thread and nothing seems to work... adding text to my cmdline.txt file added a few new options to my audio settings (previously it was just HDMI and headphones), but no matter what I select, I still get no sound and the "failed to find mixer elements" message. What am I doing wrong here?
                                          mitu Global Moderator @momentarydogma
                                          @momentarydogma Did you set your Audio output from the RetroPie menu ?
                                          momentarydogmaM 1 Reply Last reply Reply Quote 0
                                          • V
                                            VictimRLSH @mitu
                                            @mitu said in Audio issues after latest Raspbian updates:
                                            This brings up an interesting question. If I wanted to use a Pi Zero for a portable music player, what is the best way to get good sound from it other than an HDMI connection? Is there a way to output decent sound to GPIO pins that an audio amp chip can use?
                                            System Config: Retropie 4.4 with full desktop, RPi 3B, 256gb SD, 5v 2.1A 5,200 mAH USB battery. EasyMSX controller mounted with Pimoroni Hyperpixel 4 (non touch). Also running 4.6 on a 4gb Pi 4 serving as my primary desktop computer now.
