    Joystick and buttons help
    joystickcontroller
    5 Posts 3 Posters 180 Views
    • N
      NurseAngela
      Hi I have bought 2 joysticks and buttons sets online and before I set them up I was wondering how do I assign the left and right trigger, d-pad, thumb stick buttons and shoulder buttons and also hot key? Thank you for your help and guidance for all my stupid questions it’s been a massive help.
        Clyde
        Simply put, you invoke the Controller Configuration and set up all of those buttons. If that doesn't work, tell us the details.
        • N
          NurseAngela @Clyde
          @Clyde said in Joystick and buttons help:
          Thank you I didn’t realise you could hold a button to skip them. I’m guessing I won’t be able to play games that have triggers and shoulder buttons.
          ClydeC M 2 Replies Last reply Reply Quote 0
            Clyde @NurseAngela
            @NurseAngela Depending on the system(s) you want to play, that may me a problem or not.
            If you want to play many games that use those buttions, you should consider buying an appropriate controller anyway.
              mark1986 @NurseAngela
              @NurseAngela what I have is a cheap usb PS2 replica controller which I have assigned as player one for consoles such as N64, PS1 etc that would need the trigger buttons
