    Roms Mame And FBA directly at 90 °
    mame90°fba
    6 Posts 3 Posters 669 Views
      A Former User
      Hi all,
      I have a big problem under retropie crt evo rpi3b with Mame and FBA games.
      In fact the vertical games do not launch correctly but directly at 90 °.
      The image is therefore turned to the right and this for all vertical games. How to set the automatic orientation when launching games to have them normally and not oriented at 90 °?
      Thank you in advance.
        dankcushions Global Moderator @A Former User
        @cyclair said in Roms Mame And FBA directly at 90 °:
        crt evo rpi3b
        sorry but we do not support this, or any other third party images.
          A Former User
          I have the same concern with a sd that I make myself under the last version of retropie, therefore the problem does not come from retropie crt evo but well from retropie itself.
          Okay i'll do it all by myself
          Thank you
            @cyclair if you are using current retropie and fill out https://retropie.org.uk/forum/topic/3/read-this-first i am happy to help
              A Former User
              i have an rpi3b with aukru power supply.
              I have version 4.5 of retropie with only roms Mame and FBA on a sd 32go.
              Logitech USB controller.
              The roms are reversed for vertical games.
              Does that fulfill your conditions? Thank you
                pjft @A Former User
                @cyclair Probably not enough. The link clearly asks for some logs and config files so that we aren't pulling things out of thin air. To be clear, with pretty much thousands of people running and playing vertical games on the official image, especially on the RPi3B that's been around for quite a while, I would vouch for the fact that what you're facing is pretty much configuration issues from that exact image.
                But do share more details per the link shared above - type of screen you're using, etc.
