    Sega model 3 #segamodel3
    sega model 3supermodel
    304 Posts 23 Posters 139.1k Views
      mitu Global Moderator @DTEAM
      @dteam said in Sega model 3 #segamodel3:
      I don't know that much about Xinit. Probably @mitu know what to do.
      xinit is in the xinit package, but installing xorg should install xinit as a dependency.
      /dev/shm/retropie_xinitrc: line 6: /opt/retropie/emulators/supermodel/bin/supermodel: Permission denied
      This looks like the file is not executable by the running user. Check that the executable bit is set on the file with ls -l /opt/retropie/emulators/supermodel/bin/supermodel.
      DTEAMD 2 Replies Last reply Reply Quote 1
      • DTEAMD
        DTEAM @mitu
        Finally, we don't need /home/pi/Config folder You need It . It's just a permission problem. It's a good emulator and It runs well on Pi4. I'm trying to found a way to exit it without a keyboard.I haven't found anything yet.
        Red_TrevR 1 Reply Last reply Reply Quote 0
        • DTEAMD
          DTEAM @mitu
          @mitu said in Sega model 3 #segamodel3:
          I confirm, It was the problem , In my new edit above, I have use .
          pi@retropie:~ $ chmod 755 -R /opt/retropie/emulators/supermodel/bin
          To fix that.
          • Red_TrevR
            Red_Trev @DTEAM
            @dteam i gave permissions to all those files just incase, ill remove the extra Config folder once im up & running :
            @mitu please confirm the correct command line argument to install Xorg & any dependency's, is the below whats needed ? :
            sudo apt-get install xorg --install-suggests
            mituM DTEAMD 2 Replies Last reply Reply Quote 1
              mitu Global Moderator @Red_Trev
              @red_trev said in Sega model 3 #segamodel3:
              sudo apt install xorg should be enough.
              DTEAMD Red_TrevR 2 Replies Last reply Reply Quote 0
              • DTEAMD
                DTEAM @mitu
                The official source is here https://www.supermodel3.com/Download.html
                They give the source code "Supermodel Version 0.2a source code" . You have the readme.txt file with informations about the emulator.
                They talk about gamepads setup (we can't modify the Esc button... for now) and they give the game compatibility matrix.
                • Red_TrevR
                  Red_Trev @mitu
                  same issue as before, it fetches 97%, hangs, then fails (excuse the poor screenshot)
                  error says : "Temporary failure resolving 'raspbian.raspberrypi.org'"
                  although i can hit it via web browser, so it is not offline: http://raspbian.raspberrypi.org/
                  to add, when i navigate to the URL in the error message (http://raspbian.raspberrypi.org/raspbian/pool/main/x/xterm/) the file its looking for (xterm_344-1_armhf.deb) is not listed .... also http://​raspbian.raspberrypi.org/raspbian buster/ does not exist
                  is there any other way i can install via command line ?
                  • DTEAMD
                    DTEAM @Red_Trev
                    Finally, you need It to use your gamepad setting. It could be a symbolic link with /opt/retropie/emulators/supermodel/bin/Config/Supermodel.ini
                    mkdir  /home/pi/Config
                    ln -s /opt/retropie/emulators/supermodel/bin/Config/Supermodel.ini /home/pi/Config/Supermodel.ini
                      This looks like an interrupted network connection. Run sudo apt update before and make sure it completes, then try installing the package(s) again.
                        mechafatnick @Red_Trev
                        @red_trev OOps! I've updated the link so it should work now: link
                        I also completely forgot about those initial permission issues. I think I had them too. As Mitu says. hopefully sudo apt update fixes it for you!
                        For anyone interested, both Dirt Devils and WRC Le Mans are fixable:
                        -To fix Dirt Devils, copy epr-19338a.bin from your Scud Race zip into the Dirt Devils zip. The game should run now
                        -To Fix Lemans, you need a copy of Sega Touring Car Championship. Rename the contained epr-18261.ic9 to epr-18261.bin and drop it into your lemans zip.
                        DTEAMD Red_TrevR 2 Replies Last reply Reply Quote 1
                        • Red_TrevR
                          Red_Trev @mitu
                          I have some custom systems for Atomiswave / Naomi , will the update wipe these?
                          I have the updated 'es_systems' file on my laptop , if I Filezilla this into the correct folder after an update should the custom systems appear again?
                            No.
                            A customized es_systems.cfg file is not deleted/modified by an update (either OS/package or RetroPie).
                            • DTEAMD
                              DTEAM @mechafatnick
                              @mechafatnick
                              In the original open source Supermodel_0.2a_Src, they give a Makefile.SDL.UNIX.GCC and we can see in Supermodel_0.2a_Src\Src\Inputs\Inputs.cpp a split between UI keys and configurables keys for Supermodel.ini
                              Do you think It's hard to add UI Controls "settable" in Supermodel.ini . So we could use the keyboard shortcuts (hotkeys) on the gamepads and close the emulator from a gamepad.
                              UI Controls -----> Inputs.cpp only usable with keyboard for now
                              using namespace std;
                              CInputs::CInputs(CInputSystem *system) : m_system(system)
                              	// UI controls are hard coded here, everything else is initialized to NONE so that it can be loaded from
                              	// the config file.
                              	// UI Controls
                              	uiExit             = AddSwitchInput("UIExit",             "Exit UI",               GAME_INPUT_UI, "KEY_ESCAPE");
                              	uiReset            = AddSwitchInput("UIReset",            "Reset",                 GAME_INPUT_UI, "KEY_ALT+KEY_R");
                              	uiPause            = AddSwitchInput("UIPause",            "Pause",                 GAME_INPUT_UI, "KEY_ALT+KEY_P");
                              	uiSaveState        = AddSwitchInput("UISaveState",        "Save State",            GAME_INPUT_UI, "KEY_F5");
                              	uiChangeSlot       = AddSwitchInput("UIChangeSlot",       "Change Save Slot",      GAME_INPUT_UI, "KEY_F6");
                              	uiLoadState        = AddSwitchInput("UILoadState",        "Load State",            GAME_INPUT_UI, "KEY_F7");
                              	uiMusicVolUp	   = AddSwitchInput("UIMusicVolUp",		  "Increase Music Volume", GAME_INPUT_UI, "KEY_F10");
                              	uiMusicVolDown	   = AddSwitchInput("UIMusicVolDown",	  "Decrease Music Volume", GAME_INPUT_UI, "KEY_F9");
                              	uiSoundVolUp	   = AddSwitchInput("UISoundVolUp",		  "Increase Sound Volume", GAME_INPUT_UI, "KEY_F12");
                              	uiSoundVolDown	   = AddSwitchInput("UISoundVolDown",	  "Decrease Sound Volume", GAME_INPUT_UI, "KEY_F11");
                              	uiDumpInpState     = AddSwitchInput("UIDumpInputState",   "Dump Input State",      GAME_INPUT_UI, "NONE");	// disabled for release
                              	uiClearNVRAM       = AddSwitchInput("UIClearNVRAM",       "Clear NVRAM",           GAME_INPUT_UI, "KEY_ALT+KEY_N");
                              	uiSelectCrosshairs = AddSwitchInput("UISelectCrosshairs", "Select Crosshairs",     GAME_INPUT_UI, "KEY_ALT+KEY_I");
                              	uiToggleFrLimit    = AddSwitchInput("UIToggleFrameLimit", "Toggle Frame Limiting", GAME_INPUT_UI, "KEY_ALT+KEY_T");
                              #ifdef SUPERMODEL_DEBUGGER
                              	uiEnterDebugger    = AddSwitchInput("UIEnterDebugger",    "Enter Debugger",        GAME_INPUT_UI, "KEY_ALT+KEY_B");
                              #endif
                              Also in Inputs.cpp and settable in Supermodel.ini (partial view)
                              	// Common Controls
                              	start[0]           = AddSwitchInput("Start1",   "P1 Start",  GAME_INPUT_COMMON, "NONE");
                              	start[1]           = AddSwitchInput("Start2",   "P2 Start",  GAME_INPUT_COMMON, "NONE");
                              	coin[0]            = AddSwitchInput("Coin1",    "P1 Coin",   GAME_INPUT_COMMON, "NONE");
                              	coin[1]            = AddSwitchInput("Coin2",    "P2 Coin",   GAME_INPUT_COMMON, "NONE");
                              	service[0]         = AddSwitchInput("ServiceA", "Service A", GAME_INPUT_COMMON, "NONE");
                              • Red_TrevR
                                Red_Trev @mitu
                                thanks , I have tried update / upgrade, then install Xorg / xinit and the same issue arose .... missing files on the 'raspbian.raspberrypi.org' , which i confirmed by navigating via web browser & searching the folder structure.
                                is there any other way of installing Xorg / xinit, or should I chase up raspbian themselves & ask for the missing files to be re-uploaded ?
                                i see a similar file name (xterm_344-1+deb10u1_armhf.deb ) in this website: http://archive.raspbian.org/raspbian/pool/main/x/xterm/
                                  The problem is on your end - your internet connection is not working correctly (DNS issues ?), the necessary file(s) are there, in the Raspberry Pi's repository.
                                  Is a simple ping to raspbian.raspberrypi.org working ? Do you have any proxy set-up ?
                                  • Red_TrevR
                                    Red_Trev @mitu
                                    fixed it ! .... thought it might be SSH interfering with it, so went to turn it OFF via Raspi-Config, when i clicked that menu option the below happened automatically:
                                    when done, i turned off SSH, was able to install Xorg no problem via cmd line, rebooted system, Supermodel worked perfect
                                    moral of the story is to update the underlying OS every-so often ! thanks for your help ;)
                                    • Red_TrevR
                                      Red_Trev @DTEAM
                                      @dteam what is button 5 & 6 on the keyboard / game pad ?
                                      • Red_TrevR
                                        Red_Trev @mechafatnick
                                        @mechafatnick regarding your recommened edits to the ’emulators.cfg’ file in /opt/retropie/configs/arcade
                                        supermodel = "XINIT:/opt/retropie/emulators/supermodel/bin/supermodel -game-xml-file=/opt/retropie/emulators/supermodel/bin/Config/Games.xml -legacy3d -sound-volume=50 -music-volume=60 -no-vsync -no-throttle -no-dsb -res=496,384 %ROM%"
                                        i assume these are command line arguments specified here:
                                        https://www.supermodel3.com/Usage.html
                                        (e.g.) To run at 1024x768 in full screen, type:
                                        supermodel scud.zip -res=1024,768 -fullscreen
                                        There is also an option to tweak these in the ConfigFile itself:
                                        https://www.supermodel3.com/AdvancedUsage.html#ConfigFile
                                        It will be trial & error to get the sweet spot for my own hardware & display, so is there a method to launch a game from the command line with a few different combos ?
                                        and then, should i update the ’emulators.cfg’ file , the ConfigFile, or both, with my new settings values ?
                                        thanks in advance !
                                        • DTEAMD
                                          DTEAM @Red_Trev
                                          @red_trev
                                          You have to set your gamepad before with:
                                          cd /opt/retropie/emulators/supermodel/bin
                                          ./supermodel -config-inputs
                                          If you go in your Supermodel.ini , you will see your default settings for Keyboard.
                                          like (partial view Supermodel.ini) :
                                          ; Common
                                          InputStart1 = "KEY_1,JOY1_BUTTON9"
                                          InputStart2 = "KEY_2,JOY2_BUTTON9"
                                          InputCoin1 = "KEY_3,JOY1_BUTTON10"
                                          InputCoin2 = "KEY_4,JOY2_BUTTON10"
                                          InputServiceA = "KEY_5"
                                          InputServiceB = "KEY_7"
                                          InputTestA = "KEY_6"
                                          InputTestB = "KEY_8"
                                          • Red_TrevR
                                            Red_Trev @DTEAM
                                            @red_trev
                                            ; Common
                                            have you tried the Xbox controller option described here ?
