    Sega model 3 #segamodel3
    sega model 3supermodel
    304 Posts 23 Posters 114.1k Views
    • DTEAMD
      DTEAM @Red_Trev
      @red_trev
      When you set your controller, it sets your Supermodel.ini located in /opt/retropie/emulators/supermodel/bin/Config
      When It's done, you have to copy that file to /home/pi/Config or create a symbolic link with It :
      mkdir  /home/pi/Config
      ln -s /opt/retropie/emulators/supermodel/bin/Config/Supermodel.ini /home/pi/Config/Supermodel.ini
      Even if you used the other method, Supermodel.ini will be configured.
      @mechafatnick
      in supermodel.ini, I've try this to exit (where JOY1_BUTTON15 is my R3 button):
      InputUIExit = JOY1_BUTTON15
      But it doesn't work
        mechafatnick @Red_Trev
        The command begin XINIT is just that - a command. You could quit out of ES and launch it by copying and pasting it into the command prompt.
        I'm not sure if you could go much bigger than that, mind you. i used 496 x 384 because it's the native resolution of the M3 hardware.
        Red_TrevR 2 Replies Last reply Reply Quote 0
          mechafatnick @DTEAM
          @dteam Yeah I think you'd were on the right track with diddling with the inputs in the source code.
          However, I suspect they're hardcoded for the moment because they break something if you mess with them. There is a Supermodel forum and they seem friendly enough. It might be worth asking there.
          • DTEAMD
            DTEAM @mechafatnick
            @mechafatnick
            That's fine if they hardcoded that for the keyboard, but they should offer the option to set It in supermodel.ini for the gamepad, in parallel like the rest. That would be really great
            everything is already in Inputs.cpp to do that
            using namespace std;
            CInputs::CInputs(CInputSystem *system) : m_system(system)
            	// UI controls are hard coded here, everything else is initialized to NONE so that it can be loaded from
            	// the config file.
            	// UI Controls
            	uiExit             = AddSwitchInput("UIExit",             "Exit UI",               GAME_INPUT_UI, "KEY_ESCAPE");
            	uiReset            = AddSwitchInput("UIReset",            "Reset",                 GAME_INPUT_UI, "KEY_ALT+KEY_R");
            	uiPause            = AddSwitchInput("UIPause",            "Pause",                 GAME_INPUT_UI, "KEY_ALT+KEY_P");
            	uiSaveState        = AddSwitchInput("UISaveState",        "Save State",            GAME_INPUT_UI, "KEY_F5");
            	uiChangeSlot       = AddSwitchInput("UIChangeSlot",       "Change Save Slot",      GAME_INPUT_UI, "KEY_F6");
            	uiLoadState        = AddSwitchInput("UILoadState",        "Load State",            GAME_INPUT_UI, "KEY_F7");
            	uiMusicVolUp	   = AddSwitchInput("UIMusicVolUp",		  "Increase Music Volume", GAME_INPUT_UI, "KEY_F10");
            	uiMusicVolDown	   = AddSwitchInput("UIMusicVolDown",	  "Decrease Music Volume", GAME_INPUT_UI, "KEY_F9");
            	uiSoundVolUp	   = AddSwitchInput("UISoundVolUp",		  "Increase Sound Volume", GAME_INPUT_UI, "KEY_F12");
            	uiSoundVolDown	   = AddSwitchInput("UISoundVolDown",	  "Decrease Sound Volume", GAME_INPUT_UI, "KEY_F11");
            	uiDumpInpState     = AddSwitchInput("UIDumpInputState",   "Dump Input State",      GAME_INPUT_UI, "NONE");	// disabled for release
            	uiClearNVRAM       = AddSwitchInput("UIClearNVRAM",       "Clear NVRAM",           GAME_INPUT_UI, "KEY_ALT+KEY_N");
            	uiSelectCrosshairs = AddSwitchInput("UISelectCrosshairs", "Select Crosshairs",     GAME_INPUT_UI, "KEY_ALT+KEY_I");
            	uiToggleFrLimit    = AddSwitchInput("UIToggleFrameLimit", "Toggle Frame Limiting", GAME_INPUT_UI, "KEY_ALT+KEY_T");
            #ifdef SUPERMODEL_DEBUGGER
            	uiEnterDebugger    = AddSwitchInput("UIEnterDebugger",    "Enter Debugger",        GAME_INPUT_UI, "KEY_ALT+KEY_B");
            #endif
            • Red_TrevR
              Red_Trev @mechafatnick
              @mechafatnick said in Sega model 3 #segamodel3:
              thanks ! one last question ... if i wanted to play this on retroarch, is it a matter of copying over the sane files u created or is it a whole new method ?
              I have retroarch installed on my Xbox one S and the graphics performance boost it gives to Dreamcast / PSP is amazing . would love to get supermodel on it too !
                @red_trev another method. Unfortunately this version is a Linux executable, so won't work on the Xbox. It looks like work was started on a Retroarch version but it doesn't seem to have gone anywhere.
                I don't know if you could install the windows version if the Xbox is in Dev mode?
                Red_TrevR 1 Reply Last reply Reply Quote 0
                • Red_TrevR
                  @mechafatnick another option would be to convert the supermodel.exe to an app then load that in dev mode, though u would prob have to dev custom screens to input the options
                  • Red_TrevR
                    tried that but it threw an error:
                    bash:XINIT:/opt/retropie/emulators/supermodel/bin/supermodel : no such file or directory
                    even though I can navigate to that exact file via cmd line & have full rwxr permissions
                      @red_trev That's weird! Maybe navigate to /opt/retropie/emulators/supermodel/bin/
                      and xinit supermodel, without the rest of the directory structure
                      • Red_TrevR
                        @mechafatnick thanks , ill give that a go later ....
                        i have tried modifying the arcade 'emulators.cfg' to
                        supermodel = "XINIT:/opt/retropie/emulators/supermodel/bin/supermodel -game-xml-file=/opt/retropie/emulators/supermodel/bin/Config/Games.xml -legacy3d -sound-volume=50 -music-volume=80 -no-vsync -no-throttle -no-dsb -res=1024,768 -fullscreen %ROM%"
                        when i launched a game, it had the same small video box in the center of the screen, the actual game picture seemed to be bigger but it was zoomed into the bottom left corner (and my controls stopped working)
                        is there anyway of preventing the output from being displayed like this ?
                        also there is a method of setting resolution on a per game or global level via the Supermodel.ini file (https://www.supermodel3.com/AdvancedUsage.html#ConfigFile)
                        as this file appears in 3 places (config, bin, pi/home/config), i assume the same modified file must be placed in each place ?
                        and even then, how would the values in 'emulators.cfg' affect it ? which set of instructions take precedence ?
                        thanks again !
                        M Red_TrevR 2 Replies Last reply Reply Quote 0
                          @red_trev ahh remember you have two factors in play - the size of the screen the emulator is rendering and then the window the emulator is placed in in the pi.
                          It sounds like the emulator window is bigger as per the file but the actual window the emulator is being placed into isn't. You should be able to solve it by launching a game from emulation station, entering the configuration menu then changing the default video mode for super model (i use 87-46 myself.)
                          the one in /home/config is the one you need to edit. The arguments you feed to the editor will take priority so if you want to mess with the resolutions per game you'll need to dump those.
                          Remember though that the Pi is definitely not the optimum hardware for Model 3 emulation so i wouldn't push the resolution too far!
                          • Red_TrevR
                            @mechafatnick i have had better luck with the cmd line ...
                            I cd to
                            then ran the command
                            ./supermodel -game-xml-file=/opt/retropie/emulators/supermodel/bin/Config/Games.xml -legacy3d -sound-volume=50 -music-volume=60 -no-vsync -no-throttle -no-dsb -res=496,384 fvipers2.zip
                            which gave the following (poor screen shot)
                            Error: Failed to parse /opt/retropie/emulators/supermodel/bin/Config/Games.xml
                            Error: Game & ROM set definintions could not be loaded! ROMs will not be detected.
                            Error: Could not open 'fvipers2.zip'.
                            Looking at this, i believe fvipers2.zip has to be in /opt/retropie/emulators/supermodel/bin and i also must remove the part of the line which points to the xml, therefore i should run the following , please confirm ?
                            ./supermodel -legacy3d -sound-volume=50 -music-volume=60 -no-vsync -no-throttle -no-dsb -res=496,384 ./fvipers2.zip
                            it seems to be they way its done in this video =>
                            M DTEAMD 2 Replies Last reply Reply Quote 0
                              @red_trev They're running it from the desktop so they already have a window system it can use. If we're running from the command line you need xinit to give it a window system. You also need to pass it the full path to the rom (eg. /home/pi/RetroPie/roms/model3/dirtdvls.zip)
                              not sure why the games.xml can't be parsed. I don't know if its the screenshot but it looks like 'Comfig rather than 'Config'
                              I can't believe i missed out on the whole PPC underclocking angle! That's quite an exciting easy update
                              • DTEAMD
                                DTEAM @Red_Trev
                                @mechafatnick
                                The method above (video) seems to be perfect to fix the exit buttons problem and more. I'll replace the Keyboard buttons combos for UI settings by gamepad buttons combos (and more save buttons). After that. I'll generate the Makefile and build with the following
                                ln -s Makefiles/Makefile.UNIX Makefile .
                                I'm not sure about his 3d setup. Have you an opinion about that. Does he make any tuning errors on the video for 3d?
                                • Red_TrevR
                                  @mechafatnick got it working , and yes there was a typo ...
                                  first i Filezilla'd the ROM into the same folder as the supermodel emulator (opt/retropie/emulators/supermodel/bin)
                                  then via cmd line i cd to
                                  then i ran the command
                                  ./supermodel -legacy3d -sound-volume=50 -music-volume=60 -no-vsync -no-throttle -no-dsb -res=1000,768 ./fvipers2.zip
                                  no need for xinit as you can see ....
                                  game loaded, all controlls worked, video filled the screen of my 28 inch tv perfectly, though it did seem to slow down the game slightly ....
                                  i will have a play around with the settings & when i find what works the best ill report back ;)
                                    mechafatnick @DTEAM
                                    @dteam let me know how you get on! 😁 I've already added a couple of options for underclocking and got a couple of titles running better.
                                    • DTEAMD
                                      DTEAM @mechafatnick
                                      @mechafatnick
                                      I know, what you have done work very well. Honnestly, It's awesome! That's why I would like to continue to use it. Can you provide a link with what you have done, but not compiled with Makefiles. I would like to get what you have done but modify inputs.cpp
                                      like this :
                                      uiExit             = AddSwitchInput("UIExit",             "Exit UI",               GAME_INPUT_UI, "KEY_ESCAPE,JOY1_BUTTON1+JOY1_BUTTON10");
                                      or
                                      uiExit             = AddSwitchInput("UIExit",             "Exit UI",               GAME_INPUT_UI, "JOY1_BUTTON1+JOY1_BUTTON10");
                                      and after that use Makefiles
                                        mechafatnick
                                        Controls
                                        @dteam Yep that'll work, but why stop there? If you change the system controls to common controls you can map all of them in supermodel.ini. This morning I edited inputs.cpp to comment out the lines corresponding to exit/pause/screenshot/save states and then add these lines to the common controls section :
                                        uiExit             = AddSwitchInput("UIExit",   "Exit UI",   Game::INPUT_COMMON, "NONE");
                                        uiPause            = AddSwitchInput("UIPause",  "Pause",     Game::INPUT_COMMON, "NONE");
                                        uiScreenshot       = AddSwitchInput("UIScreenShot",	 "Screenshot", Game::INPUT_COMMON, "NONE");
                                        uiSaveState        = AddSwitchInput("UISaveState",   "Save State",    Game::INPUT_COMMON, "NONE");
                                        uiLoadState        = AddSwitchInput("UILoadState",   "Load State",    Game::INPUT_UI, "NONE");
                                        Build it (you can follow the instructions in the video) You can then map all these functions in supermodel.ini:
                                        InputUIExit = KEY_ESCAPE,JOY1_BUTTON10+JOY1_BUTTON9
                                        InputUIPause = JOY1_BUTTON9+JOY1_BUTTON1
                                        InputUIScreenShot =  JOY1_BUTTON9+JOY1_BUTTON5
                                        InputUISaveState = JOY1_BUTTON9+JOY1_BUTTON7
                                        InputUILoadState = JOY1_BUTTON9+JOY1_BUTTON8
                                        Save states wont work for me, but the rest work a treat :D
                                        Performance
                                        In terms of performance, i originally completely the section about underclocking the PPC. When running games, the real CPU is occasionally idle while its waiting for memory transfers to happen, so why waste our precious PI resources emulating a CPU that isn't doing anything? Underclocking the CPU frees up Pi resources to run the rest of the emulation better, but underclocking it too far means that our emulated CPU can no longer run the game (in virtual fighter 3, for example, i had Kage literally come apart at the seams :D)
                                        What i did was edit /opt/retropie/configs/model3/emulators.cfg and clone the entry multiple times, with different clock rates from 48-25. This allows us to find the optimum for any given game and save it as that rom's custom emulator in emulation station:
                                        Supermodel-normal = "XINIT:/opt/retropie/emulators/supermodel/bin/supermodel -game-xml-file=/opt/retropie/emulators/supermodel/bin/Config/Games.xml -legacy3d -sound-volume=50 -music-volume=60 -no-vsync -no-throttle -no-dsb -res=496,384 %ROM%"
                                        Supermodel-45-hz-PPC-Underclock = "XINIT:/opt/retropie/emulators/supermodel/bin/supermodel -game-xml-file=/opt/retropie/emulators/supermodel/bin/Config/Games.xml -ppc-frequency=45 -legacy3d -sound-volume=50 -music-volume=60 -no-vsync -no-throttle -no-dsb -res=496,384 %ROM%"
                                        Supermodel-48-hz-PPC-Underclock = "XINIT:/opt/retropie/emulators/supermodel/bin/supermodel -game-xml-file=/opt/retropie/emulators/supermodel/bin/Config/Games.xml -ppc-frequency=48 -legacy3d -sound-volume=50 -music-volume=60 -no-vsync -no-throttle -no-dsb -res=496,384 %ROM%"
                                        Supermodel-40-hz-PPC-Underclock = "XINIT:/opt/retropie/emulators/supermodel/bin/supermodel -game-xml-file=/opt/retropie/emulators/supermodel/bin/Config/Games.xml -ppc-frequency=40 -legacy3d -sound-volume=50 -music-volume=60 -no-vsync -no-throttle -no-dsb -res=496,384 %ROM%"
                                        Supermodel-35-hz-PPC-Underclock = "XINIT:/opt/retropie/emulators/supermodel/bin/supermodel -game-xml-file=/opt/retropie/emulators/supermodel/bin/Config/Games.xml -ppc-frequency=35 -legacy3d -sound-volume=50 -music-volume=60 -no-vsync -no-throttle -no-dsb -res=496,384 %ROM%"
                                        Supermodel-30-hz-PPC-Underclock = "XINIT:/opt/retropie/emulators/supermodel/bin/supermodel -game-xml-file=/opt/retropie/emulators/supermodel/bin/Config/Games.xml -ppc-frequency=30 -legacy3d -sound-volume=50 -music-volume=60 -no-vsync -no-throttle -no-dsb -res=496,384 %ROM%"
                                        Supermodel-25-hz-PPC-Underclock = "XINIT:/opt/retropie/emulators/supermodel/bin/supermodel -game-xml-file=/opt/retropie/emulators/supermodel/bin/Config/Games.xml -ppc-frequency=25 -legacy3d -sound-volume=50 -music-volume=60 -no-vsync -no-throttle -no-dsb -res=496,384 %ROM%"
                                        default = "Supermodel-45-hz-PPC-Underclock"
                                        • DTEAMD
                                          DTEAM @mechafatnick
                                          @mechafatnick
                                          Awsome!! Is It updated on your download link? With what you have done, This could work like retroarch hotkeys. For savestate is It a folder problem? For Supermodel.ini, the emulator set control in the emulator folder but read in home/pi/Config that’s why I have use a symlink instead of a new supermodel.ini file (see my post about that above). For savestate it’s maybe the same. Maybe It create it in one place and read in another place.
                                          With dose changes, could it be on the official experimental list in retropie ?
                                          For the fullscreen problem, i’ll try to found a solution for that, but I’m not an expert for that 😁
                                            mechafatnick @DTEAM
                                            @dteam I didn't even think about the possibility of it actually ending up as an experimenal emulator. I just wanted to run some arcade-perfect VF3 :D
                                            I've amended the zips on my guide and also put my amends to the sourcecode up on github for anyone who's interested:
                                            https://github.com/Mechafatnick/SuperModelPi
                                            FollyF DTEAMD Red_TrevR 3 Replies Last reply Reply Quote 3
