    Bluetooth Controller Issues
    bluetoothcontrollerxbox controller
    4 Posts 3 Posters 1.4k Views
    • W
      w0nderw0rm
      Pi Model or other hardware: Pi 4
      Power Supply used: CanaKit 3.5A USB-C Raspberry Pi 4 Power Supply
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.6
      USB Devices connected: An older Logitech keyboard only
      Controller used: None (this is my problem)
      Error messages received: More below
      How to replicate the problem: It's actually several issues
      I'm a totally newbie in Retropie. I know a very small amount about Linux in general so it's probably best to assume I know nothing. :)
      I've been trying to get one of the newer Xbox One controllers to work wirelessly. I can get it paired but when I try to connect to it, Retropie fully crashes. I get a several lines of output from the crash but I'm not even sure where I can go to copy and paste that for you.
      I decided to try to connect the Xbox controller through SSH. I can get it to connect with bleutoothctl but it disconnects a few seconds later. This is what I get:
      [CHG] Device EC:83:50:10:1D:8C Connected: yes
      [CHG] Device EC:83:50:10:1D:8C ServicesResolved: yes
      Failed to connect: org.bluez.Error.Failed
      [CHG] Device EC:83:50:10:1D:8C ServicesResolved: no
      [CHG] Device EC:83:50:10:1D:8C Connected: no
      I made sure to install the Xbox controller driver package but that didn't seem to have any impact.
      This is what I get from a bluetooth status:
      systemctl status bluetooth
      ● bluetooth.service - Bluetooth service
      Loaded: loaded (/lib/systemd/system/bluetooth.service; disabled; vendor prese
      Active: active (running) since Tue 2020-07-21 04:41:27 BST; 8min ago
      Docs: man:bluetoothd(8)
      Main PID: 1884 (bluetoothd)
      Status: "Running"
      Tasks: 1 (limit: 4915)
      Memory: 972.0K
      CGroup: /system.slice/bluetooth.service
      └─1884 /usr/lib/bluetooth/bluetoothd
      Jul 21 04:41:27 retropie bluetoothd[1884]: Starting SDP server
      Jul 21 04:41:27 retropie bluetoothd[1884]: Bluetooth management interface 1.14 i
      Jul 21 04:41:27 retropie bluetoothd[1884]: Sap driver initialization failed.
      Jul 21 04:41:27 retropie bluetoothd[1884]: sap-server: Operation not permitted (
      Jul 21 04:41:27 retropie bluetoothd[1884]: Failed to set privacy: Rejected (0x0b
      Jul 21 04:43:51 retropie bluetoothd[1884]: sdp_service_search_attr_async: Error
      Jul 21 04:43:51 retropie bluetoothd[1884]: EC:83:50:10:1D:8C: error updating ser
      Jul 21 04:46:09 retropie bluetoothd[1884]: EC:83:50:10:1D:8C: error updating ser
      Jul 21 04:46:13 retropie bluetoothd[1884]: sdp_service_search_attr_async: Error
      Jul 21 04:46:13 retropie bluetoothd[1884]: EC:83:50:10:1D:8C: error updating ser
      I tried connecting Nimbus from Steelseries. It connects just fine but only the big button in the center works. Nothing else responds to attempts to map the buttons.
      I hope this is just a case of a newb not knowing what he missed. I'm out of ideas and kind of frustrated. It seems like a lot of people are using the controller without a problem.
      Any advice would be greatly appreciated. Thanks in advance.
        Update your RetroPie-Setup script and then install the xpadneo driver from the drivers section. Re-try to pair the gamepad and see if it works.
        • W
          w0nderw0rm
          Awesome! This worked like a charm. Thank you!
            mjeshurun @w0nderw0rm
            Hi @w0nderw0rm , did @mitu ‘s solution allowed you to use just the Xbox One controller, or the solution also allows you to use the Nimbus Steelseries?
            I just started researching which controller to order that would work best for RetroPie AND Apple Arcade on iPhone, and it looks like the Steelseries Nimbus+ is a great controller (but I’m not sure it works with RetroPie).
            Is there a better controller I should consider?
            Maybe the 8bitdo SN30 Pro+ ?
