    CD-I does not want to load after updating Retropie
    cd-ilr-messpi4
    44 Posts 7 Posters 7.6k Views
    • DTEAMD
      DTEAM @Folly
      @folly said in CD-I does not want to load after updating Retropie:
      @DTEAM
      @michel30
      @swagford
      Today I got it working again with the new lr-mess. (through valerino's script)
      Though we have to dig deep to find what's cousing the problem here.
      It seems a combination problem that has to do with the :
      BIOS;
      commandline;
      lr-mess version;
      core options;
      Probably the new lr-mess wants to know the system "cdimono1" and the type of rom "-cdrm". (so the old way still does not work)
      This is how i got it working again:
      I used @valerino 's Retropie fork from https://github.com/valerino/RetroPie-Setup
      Here is his post : https://retropie.org.uk/forum/topic/25576/new-scriptmodules-lr-vice-xvic-gsplus-proper-lr-mess-integration
      (earlier I already installed the lr-mess binary with the original RetroPie-Setup)
      I replaced the original RetroPie-Setup directory with valerinos's fork.
      Then I installed "lr-mess-cdi" from the experimental packages.
      You can only use "source" that will install the system with some scripts and configs (it installs very fast)
      Placed my "cdimono1.zip" in the BIOS directory.
      This file contains :
      cdi200.rom
      cdi220b.rom
      cdi220.rom
      zx405037p__cdi_servo_2.1__b43t__llek9215.mc68hc705c8a_withtestrom.7201
      zx405042p__cdi_slave_2.0__b43t__zzmk9213.mc68hc705c8a_withtestrom.7206
      (with only the first 3 files it will not work !, then i got initializing !)
      Placed my game-rom in /home/pi/RetroPie/roms/cdimono1
      Then I could run the longnamed .chd "arcade classics (1996)(namco - philips)(eu)[!][compilation].chd"
      I edited the configs manually to get mouse and joystick working again in fullscreen.
      The configs now in a diffent place.
      /opt/retropie/configs/cdimono1
      It's still "Work In Progress"
      I finally decided to update Retropie and try what you said.
      I did that and It works!! Big thanks for that @Folly !
      Only one subtlety. It works with the 2 files from cdi910 and not the two same files found in cdimono1.7z from MAME 0.225. I rebuilt the cdimono1 with the good 2 files. I used .zip and not .7z
      • FollyF
        Folly @DTEAM
        @dteam said in CD-I does not want to load after updating Retropie:
        @DTEAM
        @michel30
        @swagford
        BIOS;
        commandline;
        lr-mess version;
        core options;
        cdi200.rom
        cdi220b.rom
        cdi220.rom
        Nice to hear.
        Good job !
        Which files do you actually mean ?
        I know that 2 of the 5 files are not used if using the standard CDI type. I kept the others in the cdimono1.zip because they were originally in there. The reason is : it should be possible to select other types of CDI players in lr-mess or mame.
        • DTEAMD
          DTEAM @Folly
          • FollyF
            Folly @DTEAM
            Thanks.
