    CD-I does not want to load after updating Retropie
    cd-ilr-messpi4
    44 Posts 7 Posters 7.6k Views
      mitu Global Moderator @Folly
      @Folly said in CD-I does not want to load after updating Retropie:
      cdi200.rom
      cdi220b.rom
      cdi220.rom
      zx405037p__cdi_servo_2.1__b43t__llek9215.mc68hc705c8a_withtestrom.7201
      zx405042p__cdi_slave_2.0__b43t__zzmk9213.mc68hc705c8a_withtestrom.7206
      So it looks like it's a 'bios' issue, the error message reported previously was complaining about some missing roms - which seem to be included in your cdimono1.zip file.
      • FollyF
        Folly
        Indeed , for the "new lr-mess" in cdimono1.zip we need to add :
        (These files can be taken from the cdi910 file)
        The above bios, together with valerino's script can be a solution to this problem.
        But trying the "new lr-mess" the old way from "arcadia" with :
        /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mess/mess_libretro.so --config /opt/retropie/configs/arcadia/retroarch.cfg "/home/pi/RetroPie/roms/arcadia/Philips_CD-I/cdimono1/arcadecl.bin"
        still gives :
        [libretro INFO] Starting game:cdimono1
        [libretro ERROR] Error parsing game path: cdimono1
        [libretro ERROR] Error parsing system name: cdimono1
        [libretro ERROR] Error parsing parent path: cdimono1
        [libretro INFO] Game name: cdimono1, Game description: CD-i (Mono-I) (PAL)
        [libretro INFO] Creating frontend for game: cdimono1
        [libretro INFO] Softlists: 1
        segmentation error
        Here it uses the 'mame_softlists_auto_media = "enabled"' and 'mame_softlists_enable = "enabled"' so the shornamed file maches the game driver. It seems that it cannot find the right game driver as it did with the "old lr-mess"
        So in this way the the issue is not yet solved.
        • Z
          zerojay @Folly
          I edited the configs manually to get mouse and joystick working again in fullscreen.
          The configs now in a diffent place.
          /opt/retropie/configs/cdimono1
          Could you explain what changes you had to make here?
          • FollyF
            Folly
            @zerojay
            I enabled the mouse (will only work if emulationstation is run from the cli (boot into cli).
            Added joystick buttons.
            Removed the black CDI lcd within the screen.
            Turned off the qui.
            Placed my configs here :
            https://github.com/FollyMaddy/retropie-philips-cdi-tools/tree/master/configs
            Make a backup of your old files and copy them to /opt/retropie/configs/cdimono1
            I have bundeled all information, about the configs, in my script (not working at the moment with the "new lr-mess") :
            https://github.com/FollyMaddy/retropie-philips-cdi-tools/blob/master/retropie_philips_cdi_setup.sh
            You can read that if you want.
            Though the directory's are different, the info of the configs are essentially the same.
            jamrom2J 1 Reply Last reply Reply Quote 1
            • FollyF
              Folly
              @DTEAM
              @michel30
              @swagford
              @zerojay
              It seems that for the es-theme-carbon, cdimono1 does not exist.
              So I created my own.
              Feel free to use this :
              https://github.com/FollyMaddy/retropie-philips-cdi-tools/tree/master/es-theme-carbon
              Copy it to /etc/emulationstation/themes/carbon/
              • Z
                zerojay
                I ended up creating my own theme for snes-mini for it (and several other missing systems), but thanks, I'm sure someone else will appreciate it.
                • DTEAMD
                  DTEAM @Folly
                  @Folly
                  Thanks. Nice job
                  • jamrom2J
                    jamrom2 @Folly
                    boot into cli
                    Thanks for posting this. First I've read anywhere that those two "extra" files were required in the cdmono1 BIOS.
                    I have it working, however, what do you mean by getting the mouse working by booting ES into the cli? How do I do that on a consistent game for game basis. Meaning... exit one game, start another.
                    I've never booted into cli before.
                    Thanks again,
                    JR
                    • FollyF
                      Folly @jamrom2
                      @jamrom2 said in CD-I does not want to load after updating Retropie:
                      boot into cli
                      Well, I run my ES from the Desktop enviroment, so I can access my files directly.
                      Without the need of using SSH, filezilla or boot my roms without ES.
                      By CLI (Command Line Interface), I mean boot into the Terminal.
                      If you have the normal Retropie image. The pi will automatically boot into the CLI and start ES automatically.
                      So than, if your mouse configuration is good, your mouse will work.
                      You can just run your rom from ES, Escape, and boot another rom from ES.
                      • FollyF
                        Folly
                        @jamrom2
                        Have you made some progress ?
                        • jamrom2J
                          jamrom2 @Folly
                          @Folly Yes, thank you! But I am not all that proficient with booting from CLI. I have Retropie set up with a MegaPi case from Retroflag, so it's more or less select game and go. I'm trying to keep it really simple.
                          Hopefully there will be adjustment made to lr-mess that fix the mouse issues in CD-i as well as the Apple emulators.
                          • FollyF
                            Folly
                            @jamrom2
                            I think you can wait a long time then, I don't see any progress right now.
                            Well, forget about the CLI.
                            I think you are good to go with your OS.
                            If not, you are at least able to stop the drifting.
                            You can try this first simple step (enable your mouse) :
                            • run a cd-i game
                            • press F1 (go into the Retroarch menu)
                              (navigate with cursors, z(back) and x(forward))
                            • go to "options"
                            • go to "Enable in-game mouse" to "On" (use x to set it to On)
                            • press F1 again to get back to your game
                            • escape the game
                            • restart the game
                            If all is good, the pointer will not drift and you will be able to move it with your mouse.
                            (mouse buttons will likely still not work, or only 1 will work)
                              michel30
                              @Folly Thanks for sharing all these information..
                              My CDi is now working on my PI4.
                              • jamrom2J
                                jamrom2 @Folly
                                @Folly
                                Finally got around to messing with this... works great! Thanks!
                                • FollyF
                                  Folly @jamrom2
                                  @Folly
                                  Super !!!
                                    michel30
                                    @Folly I was searching to get my xbox 360 controller running the game under CD-I the only way now is with the mouse...
                                    I found this webpage: https://cdii.blogspot.com/2019/10/how-to-configure-ps4-xbox-360.html but the menu what this user is showing, I could not find it..
                                    Do you or does other members now how get the controller working for CD-I..
                                    Thanks..
                                      mth75 @michel30
                                      @michel30 said in CD-I does not want to load after updating Retropie:
                                      Thanks..
                                      Try this in your cdimono.cfg.
                                      <?xml version="1.0"?>
                                      <!-- This file is autogenerated; comments and unknown tags will be stripped -->
                                      <mameconfig version="10">
                                          <system name="cdimono1">
                                              <video>
                                                  <target index="0" view="Main Screen Standard (4:3)" />
                                              </video>
                                              <input>
                                                  <port tag=":slave_hle:MOUSEBTN" type="P1_BUTTON1" mask="1" defvalue="0">
                                                      <newseq type="standard">
                                                          JOYCODE_1_BUTTON1
                                                      </newseq>
                                                  </port>
                                                  <port tag=":slave_hle:MOUSEBTN" type="P1_BUTTON2" mask="2" defvalue="0">
                                                          JOYCODE_1_BUTTON2
                                                      </newseq>
                                                  </port>
                                                  <port tag=":slave_hle:MOUSEX" type="P1_MOUSE_X" mask="1023" defvalue="0" keydelta="6">
                                                      <newseq type="increment">
                                                          JOYCODE_1_XAXIS_RIGHT_SWITCH JOYCODE_1_HAT1RIGHT
                                                      </newseq>
                                                      <newseq type="decrement">
                                                          JOYCODE_1_XAXIS_LEFT_SWITCH JOYCODE_1_HAT1LEFT
                                                      </newseq>
                                                  </port>
                                                  <port tag=":slave_hle:MOUSEY" type="P1_MOUSE_Y" mask="1023" defvalue="0" keydelta="6">
                                                          JOYCODE_1_YAXIS_DOWN_SWITCH JOYCODE_1_HAT1DOWN
                                                      </newseq>
                                                          JOYCODE_1_YAXIS_UP_SWITCH JOYCODE_1_HAT1UP
                                                      </newseq>
                                                  </port>
                                              </input>
                                              <image_directories>
                                                  <device instance="cdrom" directory="/home/pi/RetroPie/roms/cdimono1/" />
                                              </image_directories>
                                          </system>
                                      </mameconfig>
                                      • FollyF
                                        Folly @mth75
                                        EDIT :
                                        Deleted my suggestion.
                                        I read the question wrong.
                                        @michel30 : First try the solution of @mth75.
                                        This could be the solution.
                                          michel30 @Folly
                                          @folly and @mth75 Thanks mth75 it works :-) ;-)
                                            mth75 @michel30
                                            @michel30 Very nice!!!!
