    Help With Dosbox "xboxdrv" Driver
    dosboxgamepadmouse mapping
    13 Posts 3 Posters 1.8k Views
    • E
      escc1986
      This Question is for anyone who can help me ... but maby @ExarKunIv could help if he is not busy
      Hi ExarKunIv ... remember this
      https://retropie.org.uk/forum/topic/24836/scummvm-controlller-issues/101
      You Told me to put this in putty to test the gamepad while the game was running
      	--evdev /dev/input/event0 \
      	--silent \
      	--detach-kernel-driver \
      	--force-feedback \
      	--mimic-xpad \
      	--trigger-as-button \
      	--evdev-absmap ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y \
          --evdev-keymap KEY_#305=a,KEY_#304=b,KEY_#307=x,KEY_#308=y,KEY_#310=tl,KEY_#311=tr,KEY_#314=back,KEY_#315=start \
      	--ui-axismap dpad_x=REL_X:10,dpad_y=REL_Y:10 \
      	--ui-buttonmap a=BTN_LEFT,b=BTN_RIGHT,start=KEY_F5,back=KEY_ESC \
      	--ui-buttonmap guide=void,x=void,y=void,lb=void,rb=void,tl=void,tr=void,lt=void,rt=void,back=void \
      	--ui-axismap x2=void
      to try to get the gamepad acting like a mouse for scummvm
      well i was wondering if i could do the same but with the Dosbox Emulation .... The Original Dosbox Emulator on pi (not ir-Dosbox)
      my main purpose as some games i have loaded dont run on Ir-dosbox
      and i want to use my nes gamepad as a mouse
      all the settings of the keys & buttons are still the same ... may i ask .. could anyone help
      Thank you in advance
        There's a section in the Docs dealing with xboxdrv, which describes how to automatically start (and stop) it, based on system/game.
        • E
          escc1986 @mitu
          thank you
          i could honestly say i have looked through it too many times and i dont seem to undestand it ... i truly need alot of help with it , if someone is willing to help , i would appreciate it
          • E
            escc1986 @escc1986
            @ExarKunIv
            i also made an
            xdrive folder
            and made a pc.cfg
            inside that xdrive folder
            with this located inside the pc.cfg
            [xboxdrv]
            silent=true
            deadzone=4000
            deadzone-trigger=15%
            dpad-as-button=false
            trigger-as-button=true
            detach-kernel-driver=true
            #force-feedback=true
            mimic-xpad=true
            [evdev-absmap]
            ABS_X=x1
            ABS_Y=y1
            ABS_Z=x2
            ABS_RZ=y2
            ABS_HAT0X=dpad_x
            ABS_HAT0Y=dpad_y
            [evdev-keymap]
            BTN_SOUTH=a
            BTN_EAST=b
            BTN_NORTH=x
            BTN_WEST=y
            BTN_TL=lb
            BTN_TL2=lt
            BTN_TR=rb
            BTN_TR2=rt
            BTN_SELECT=back
            BTN_START=start
            BTN_THUMBL=tl
            BTN_THUMBR=tr
            [ui-axismap]
            x1=KEY_LEFT:KEY_RIGHT
            y1=KEY_DOWN:KEY_UP
            dpad_x=REL_X:10
            dpad_y=REL_Y:10
            [ui-buttonmap]
            a=BTN_LEFT
            b=KEY_LEFTCTRL
            x=KEY_ENTER
            y=KEY_R
            lb=KEY_C
            lt=KEY_A
            rb=KEY_SPACE
            rt=KEY_D
            back=KEY_F5
            start=KEY_ESC
            tr=KEY_K
            tl=KEY_Y
            # EOF #
            • E
              escc1986 @escc1986
              @ExarKunIv
              the left button works like a left click
              the right button works as well
              the
              d pad does not worki as a mouse (pointer does not move)
              any help ?
              • E
                escc1986 @escc1986
                @ExarKunIv
                i also placed this in the +Start DOSBox.sh
                sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv >> /dev/shm/runcommand.log 2>&1 --evdev /dev/input/event0 --config /opt/retropie/configs/all//xdrive/pc.cfg &
                • ExarKunIvE
                  ExarKunIv @escc1986
                  @escc1986 everything looks good and as far as i know it should work as is.
                  i was going to be messing with a few dos game myself today with my xboxdrv.
                  so ill let you know what i find
                  • E
                    escc1986 @ExarKunIv
                    @ExarKunIv
                    Thank You
                    yeah the controller dpad doest work , weird ...
                    please let me know your results , Thank you
                    • E
                      escc1986
                      "dpad does not work " sorry for the misspell
                      • E
                        escc1986
                        i got it to work in dosbox here is what i did
                        place this in roms/pc/+Start DOSBox.sh
                        after: #!/bin/bash
                        place this in pc.cfg
                        [xboxdrv]
                        silent=true
                        deadzone=4000
                        mimic-xpad=true
                        [evdev-absmap]
                        ABS_X=x1
                        ABS_Y=y1
                        [ui-axismap]
                        x1=REL_X:5
                        y1=REL_Y:-5
                        [evdev-keymap]
                        BTN_SOUTH=b
                        BTN_EAST=a
                        [ui-buttonmap]
                        a=BTN_LEFT
                        b=BTN_RIGHT
                        # EOF #
                        • E
                          escc1986
                          @ExarKunIv
                          Thanks for all your help before when you were helping me with the Scummvm mouse pointer ...
                          with all that info i put the use toward this
                          your great !!!
                          Appreciate it
                          • ExarKunIvE
                            ExarKunIv @escc1986
                            @escc1986 glad you got it all squared away.
                            i just my dosbox working again and was about to start messing with it.
                            im still going to but now its no rush. lol
                            • E
                              escc1986 @ExarKunIv
                              @ExarKunIv
                              lol no problem
                              You helped me get my set up for my controller and helped me with the keys ... i have struggled with this for 4 days lol ... glad it works and i hope others can see this and get the idea how it works :)
