    The buttons "Right top" and "Left top" do not register
    buttonsconfigeasysmxgamepad
    3 Posts 2 Posters 319 Views
    • E
      Enmaboya
      A clean Retripie 4.6, Rasberry pi 4 installation is used.
      I can register "Right top" and "Left top" buttons, EasySMX gamepad is used, defined as xbox 360 controller.
      I.e. in my case I can click on the left and right trigger as many times as I like but the clicks are not registered.
      It may happen that the buttons are not working, but I checked on Windows - everything is OK.
        Can you re-install the xpad driver and reboot, then re-try the input configuration in EmulationStation ?
        • E
          Enmaboya
          Yes, it solved the problem.
          thank you!
