    Netplay help
    netplayretroarchretropie
    10 Posts 3 Posters 917 Views
    • UberLumbyU
      UberLumby
      I was curious if there was a way to view the netplay lobby list on retropie. I was trying to netplay with a friend and I tried hosting and he tried hosting and both times the client failed to join. When I tried to manually type in his IP in retroarch and save the game core the game would crash after reloading.
      He is using the image I created so I know we are on the same versions emulators and roms.
      All the guides for retropie netplay seem really out of date so I'm also wondering if there is any updated guides. We exchanged the correct IPs used in those guides as well we both failed to join whenever one of us would host the client would fail.
      [Linux 5.10.103-v7+ armv7l GNU/Linux
      Retropie 4.8
      Raspberry Pi 3B+]
      UberLumbyU 1 Reply Last reply Reply Quote 0
      • UberLumbyU
        UberLumby @UberLumby
        It says compatible content found when I see his host in netplay lobby but when I click on it, it says couldn't find a suitable core or content load manually. When I'm in the same core and content already lol
        Retropie 4.8
        Raspberry Pi 3B+]
          You may be experiencing this issue, since both Netplay clients are running RetroPie. There's a workaround available, but not a definitive resolution yet.
          • UberLumbyU
            UberLumby @mitu
            @mitu said in Netplay help:
            That is exactly my problem thanks! I'll read into this. I was also thinking maybe installing hamachi on both mine and my friends retropie would work. I used to use hamachi back in the day for diablo 2 lans over the internet
            Problem is I'm not the best with linux commands so installing that would be hard for me Haha
            Retropie 4.8
            Raspberry Pi 3B+]
              mitu Global Moderator @UberLumby
              @UberLumby The issue is not related to network connectivity, installing Hamachi would not help in this case.
              UberLumbyU 1 Reply Last reply Reply Quote 1
              • UberLumbyU
                UberLumby @mitu
                Yeah I got side tracked the end of the thread they start talking about network issues and I was hoping it wasn't 2 issues I'm getting just the 1. I'll try it later. Thanks again you've been a major help multiple times
                Retropie 4.8
                Raspberry Pi 3B+]
                • UberLumbyU
                  From what I gather this is what I need to do
                  There is a workaround for this, just by adding the cores to the location where RetroArch expects them:
                  copy the core .info file(s) from https://github.com/libretro/libretro-core-info to $HOME/.config/retroarch/cores
                  symlink the core .so file to the same location - for instance fceumm:
                  ln -s /opt/retropie/libretrocores/lr-fceumm/fceumm_libretro.so
                  Where are the .info and .so files located on my retropie? So I can copy and paste them all to the retroarch core folder
                  Retropie 4.8
                  Raspberry Pi 3B+]
                  saccublendaS 1 Reply Last reply Reply Quote 0
                    @UberLumby said in Netplay help:
                    There are no .info files - as said, you need to download them. As for where are they located - each one has it's own folder under /opt/retropie/libretrocores.
                    • saccublendaS
                      saccublenda @UberLumby
                      @UberLumby You can follow the instructions here.
                      • UberLumbyU
                        UberLumby @saccublenda
                        @saccublenda said in Netplay help:
                        Thank you
                        "Create a symbolic link to the RetroArch core you want to use for netplay in the directory where the core info file was stored, for example
                        ln -s /opt/retropie/libretrocores/lr-fceumm/fceumm_libretro.so $HOME/.config/retroarch/cores"
                        This confused me a bit but I think I understand this creates a link to the existing .So I was copying and pasting them into the retroarch cores folder last night lol ops...
                        Retropie 4.8
                        Raspberry Pi 3B+]
