    TTX Tech PS2 with USB dongle left and right triggers don't work.
    controllerps2 controllerps3 controllercontrol input
    2 Posts 1 Posters 464 Views
      testmeforspam
      Hello there, so I've run jstest and this is what I've discovered:
      I am running off of a Rasberry Pi 4 Model B
      The controller is a TTX Tech ps2 controller, and I'm connecting it to my Rasberry Pi with a USB dongle.
      At rest (not pressing the triggers down) axes 2 (left trigger) and 5 (right trigger) read -32767.
      When pressed down Axes 2 and 5 read as + 32767
      When pressed buttons 6 (left trigger) and 7 (left trigger) turn on.
      When selecting Configure Input, pressing either left or right trigger allows me to enter the controller input menu. So it is recognizing these as buttons.
      I've tried installing ps3 controller drivers, enabling 3rd party support, and nothing.
      I'm about to try and reinstalling retropie on my rasberry pi and starting from scratch but I'd like to know what I can do to fix this. I have a second controller that has the same issue. Same model and everything.
      I appreciate the help!
        testmeforspam
        I've tried using the xboxdrv and these are my results (any help at this point is helpful):
        cat /proc/bus/input/devices
        List of Devices:
        First Device:
        N: Name="Sony PLAYSTATION(R)3 Controller Motion Sensors"
        H: Handlers=event1
        Second Device:
        N: Name="Sony PLAYSTATION(R)3 Controller"
        H: Handlers=event2 js0
        ls /dev/input/by-id/
        event location by name for later use
        List of Devices:
        Fist Device:
        usb-Sony_PLAYSTATION_R_3_Controller-event-if00
        Second Device:
        usb-Sony_PLAYSTATION_R_3_Controller-event-joystick
        evtest /dev/input/event[•]
        I ended up trying evtest /dev/input/event1 for N: Name="Sony PLAYSTATION(R)3 Controller Motion Sensors". This did not work.
        evtest /dev/input/event2
        This command works.
        The device I'll be working with from now on is the following:
        Second Device:
        List of control input buttons and ABS codes begin here.
        D-Pad:
        BTN_DPAD_UP
        BTN_DPAD_DOWN
        BTN_DPAD_LEFT
        BTN_DPAD_RIGHT
        Buttons:
        BTN_SOUTH
        BTN_EAST
        BTN_WEST
        BTN_NORTH
        BTN_START
        BTN_SELECT
        Bumpers:
        BTN_TL
        BTN_TR
        Triggers:
        BTN_TL2
        ABS_Z
        BTN_TR2
        ABS_RZ
        Analog Sticks:
        BTN_THUMBL
        BTN_THUMBR
        ABS_X
        ABS_Y
        ABS_RX
        ABS_RY
        In the end, I ended up placing this in the /etc/rc.local file
        #!/bin/sh -e
        # rc.local
        # This script is executed at the end of each multiuser runlevel.
        # Make sure that the script will "exit 0" on success or any other
        # value on error.
        # In order to enable or disable this script just change the execution
        # bits.
        # By default this script does nothing.
           --evdev /dev/input/by-id/usb-Sony_PLAYSTATION_R_3_Controller-event-joystick \
           --silent \
           --detach-kernel-driver \
           --force-feedback \
           --deadzone-trigger 15% \
           --deadzone 4000 \
           --trigger-as-button \
           --mimic-xpad \
           --dpad-as-button
           --evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_RX=x2,ABS_RY=y2,ABS_Z=lt,ABS_RZ=rt \
           --evdev-keymap BTN_SOUTH=a,BTN_EAST=b,BTN_WEST=x,BTN_NORTH=y,BTN_TL=lb,BTN_TR=rb,BTN_THUMBL=tl,BTN_THUMBR=tr,BTN_SELECT=back,BTN_START=start,BTN_DPAD_UP=du,BTN_DPAD_DOWN=dd,BTN_DPAD_LEFT=dl,BTN_DPAD_RIGHT=dr \
           --ui-buttonmap guide=void \
        exit 0
        And even then, I can't get retropie to recognize my controller as anything other than a playstation 3 controller AND now retropie won't finish rebooting.
        It gets stuck after a message stating:
        "You Xbox/Xbox360 controller should now be available as:
        /dev/input/js1
        /dev/input/event3
        Press Ctrl-C to quit"
        And then the next 3 lines are about Samba NMB Daemon being Started, Starting, and Started again. At this point the boot ceases all function.
        When I try the following command I get the same error message at boot.
        #!/bin/sh -e
        # rc.local
        # value on error.
        # bits.
           --evdev /dev/input/event2 \
           --silent \
           --force-feedback \
           --deadzone 4000 \
           --mimic-xpad \
           --dpad-as-button
        exit 0
        I hope this information helps clarify my issue with this controller.
