    Box86 and Wine on RPi4
    box86wineqemux86windows
    475 Posts 40 Posters 284.0k Views
    • FollyF
      Folly @shavecat
      @shavecat
      Looks like garbish. ;-)
      I don't see executables.
      Where is your installation of claw ?
      Go there, it you have :spaces: in a directory use :
      cd "insert your path to claw"
      shavecatS 1 Reply Last reply Reply Quote 0
      • shavecatS
        shavecat @Folly
        @folly
        what do u mean ?
        cd
        /media/usb0/roms/wine/CLAWALL/Claw
        ? :O
        • FollyF
          Folly @shavecat
          @shavecat
          I can't look into your computer.
          But if you installed claw, I think you have to know where ;-)
          I suggest looking somewhere in :
          cd "/home/pi/.wine/dosdevices/c/windows/Program Files"
          use ls to list directory's and files.
          • shavecatS
            shavecat @Folly
            @folly
            its here yes
            • FollyF
              Folly @shavecat
              @shavecat
              Ok looks better.
              Just do, for only the files in that directory :
              md5sum *
              And compare them with the ones @mth75 has.
              Then you probably can see if you both have other files or not.
              shavecatS 1 Reply Last reply Reply Quote 1
              • shavecatS
                shavecat @Folly
                @folly @mth75
                got this
                pi@retropie:/media/usb0/roms/wine/CLAWALL/Claw $ md5sum *
                md5sum: Assets: Is a directory
                a4a7a31ba3ae75bda182d641b698f22d  CLAW.EXE
                11342f264593a420c0ebc1746399cb6b  CLAW.REZ
                c862d315f99ea065ca819921e4010eb6  CLAW.USR
                04f19d66b0ee3fc1ce53f1ecf702f7f7  CrazyHook.dll
                28dbdf17dcf8c22a70d4d7bdcd310271  CrazyHook.lua
                b210307bbe724c80d28e6e5b9e8fd281  CrazyPatches.lua
                md5sum: Custom: Is a directory
                5eae2f3532d882a2f175331cd20d8d04  DDraw.dll
                7f8958bd8c5fe32ec5b2c2eaf9bd675c  dgVoodoo.conf
                56661a182f701704ad612d6c0722b061  dgVoodooCpl.exe
                48e73dcd7489e0af53a2d577393c54a6  lfs.dll
                e09ae9a385a80fbb7686ca6d22684d6c  lua51.dll
                md5sum: Movies: Is a directory
                19df9f8df6cdcebecf6c43cb5df885be  MSS32.dll
                7f8da89204332df95cfc41f6e85dc515  MSVCR120.DLL
                7458d054333a05172148541cf266d79b  SMACKW32.dll
                M FollyF 2 Replies Last reply Reply Quote 0
                  mth75 @shavecat
                  @shavecat
                  Another version it seems.
                  • FollyF
                    Folly @shavecat
                    @shavecat
                    Indeed seems to be a different version.
                    This can be the problem.
                    Now you know, you both have not the same version.
                    • shavecatS
                      shavecat @Folly
                      @folly @mth75
                      Thanks !:))
                      cant find that version shame :\
                        TedMaul
                        Further to my earlier post, this is the script I was attempting to run from roms/ports:
                        [Removed]
                        Does anyone have any ideas? I am trying to follow some of the instructions from earlier in this thread, but I'm worrying that what I'm doing has already been superseded by what has been discovered since!
                          mitu Global Moderator @TedMaul
                          @tedmaul Please remove the SpacePinball script, it's referencing/downloading copyrighted material.
                            TedMaul @mitu
                            @mitu Apologies - I thought because it was on archive.org it was fair game, and the script was from further up the thread. I've removed it now.
                            Either way, as always grateful for any pointers from anyone, thanks in advance.
                            • shavecatS
                              shavecat @mth75
                              @mth75
                              Hey
                              Found the same version !
                              but i still get a black small screen on the side for a sec' then its gone...
                                George @shavecat
                                @shavecat can you share the output of:
                                cat /dev/shm/runcommand.log
                                Perhaps also edit your Ports script (not the installation script), removing WINEDEBUG=-all and replacing it with BOX86_LOG=1. Then try to run it again and then share the output of runcommand.log again.
                                Can you also share the Ports script (not the installation script).
                                Thanks!
                                - George
                                • shavecatS
                                  shavecat @George
                                  @george
                                  Hey im running it from wineexpelor .
                                    George @shavecat
                                    @shavecat gotcha. Did you run Wine Explorer from Emulation Station? If so, you can edit that ports script to remove WINEDEBUG=-all and replace it with BOX86_LOG=1.
                                    • shavecatS
                                      shavecat @George
                                      @george
                                      thanks
                                      *sorry didnt do it right
                                      So -
                                      pi@retropie:~ $ cat /dev/shm/runcommand.log
                                      Hello logfile - runcommand-onstart checking in here
                                      Parameters:
                                      Executing: xinit /dev/shm/retropie_xinitrc -- vt1 -keeptty
                                      _XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root
                                      X.Org X Server 1.20.4
                                      X Protocol Version 11, Revision 0
                                      Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
                                      Current Operating System: Linux retropie 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l
                                      Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M video=HDMI-A-1:1920x1080M@60,margin_left=0,margin_right=0,margin_top=0,margin_bottom=0 smsc95xx.macaddr=DC:A6:32:14:7A:95 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e22bcd10-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait loglevel=3 consoleblank=0 plymouth.enable=0
                                      Build Date: 05 June 2019  12:49:54PM
                                      xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
                                      Current version of pixman: 0.36.0
                                              Before reporting problems, check http://wiki.x.org
                                              to make sure that you have the latest version.
                                      Markers: (--) probed, (**) from config file, (==) default setting,
                                              (++) from command line, (!!) notice, (II) informational,
                                              (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
                                      (==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Tue Mar  2 17:05:42 2021
                                      (==) Using config directory: "/etc/X11/xorg.conf.d"
                                      (==) Using system config directory "/usr/share/X11/xorg.conf.d"
                                      (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
                                      Set mode 1920x1080@60Hz on HDMI-1
                                      Executing (via xinit): /opt/retropie/ports/claw/claw_xinit.sh
                                      server does not have extension for -dpms option
                                      Debug level is 1
                                      Dynarec for ARM, with extension: HALF FAST_MULT EDSP NEON VFPv4 IDIVA PageSize:4096
                                      Box86 with Dynarec v0.2.0 b2d5587 built on Mar  1 2021 00:17:27
                                      BOX86: Wine detected, WINEPRELOADRESERVE=""
                                      Using default BOX86_LD_LIBRARY_PATH: ./:lib/:lib32/:x86/
                                      Using default BOX86_PATH: ./:bin/
                                      Counted 28 Env var
                                      Looking for /opt/retropie/ports/wine/bin/wine
                                      argv[1]="/media/usb0/roms/wine/CLAWALL/2/CLAW.EXE"
                                      argv[2]="-fullscreen"
                                      Using native(wrapped) libpthread.so.0
                                      Using native(wrapped) libdl.so.2
                                      Using native(wrapped) libc.so.6
                                      Using native(wrapped) ld-linux.so.2
                                      Using native(wrapped) librt.so.1
                                      Using emulated /opt/retropie/ports/wine/bin/../lib/wine/ntdll.so
                                      Using native(wrapped) libm.so.6
                                      Debug level is 1
                                      Counted 29 Env var
                                      Debug level is 1
                                      Counted 29 Env var
                                      Looking for /opt/retropie/ports/wine/bin/wineserver
                                      Using emulated /opt/retropie/ports/wine/lib/wine/../libwine.so.1
                                      0050:err:ole:start_rpcss Failed to start RpcSs service
                                      009c:err:ntoskrnl:ZwLoadDriver failed to create driver L"\\Registry\\Machine\\System\\CurrentControlSet\\Services\\wineusb": c0000142
                                      003c:fixme:service:scmdatabase_autostart_services Auto-start service L"wineusb" failed to start: 1114
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/kernel32.so"/0x64c4c168, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/kernelbase.so"/0x64c7d5b8, 2)
                                      Using emulated /opt/retropie/ports/wine/lib/wine/user32.so
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/advapi32.so"/0x64cc6cf8, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/sechost.so"/0x64cc8078, 2)
                                      Using emulated /opt/retropie/ports/wine/lib/wine/ucrtbase.so
                                      Using emulated /opt/retropie/ports/wine/lib/wine/gdi32.so
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/setupapi.so"/0x64cefe70, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/rpcrt4.so"/0x64cf34b0, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/version.so"/0x64cf3aa8, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comdlg32.so"/0x64cf7678, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comctl32.so"/0x64d01028, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/imm32.so"/0x64d01ac0, 2)
                                      Using emulated /opt/retropie/ports/wine/lib/wine/shell32.dll.so
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/shell32.so"/0x64d0fb80, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/shlwapi.so"/0x64d24360, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/shcore.so"/0x64d24cd8, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/ole32.so"/0x64d2bde8, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/combase.so"/0x64d2dcd8, 2)
                                      Using emulated /opt/retropie/ports/wine/lib/wine/winspool.drv.so
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winspool.so"/0x64d2e350, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winmm.so"/0x64d3d818, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/msacm32.so"/0x64d3e178, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/dplayx.so"/0x64d415b8, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/wsock32.so"/0x64d41d38, 2)
                                      Using emulated /opt/retropie/ports/wine/lib/wine/iphlpapi.dll.so
                                      Using native(wrapped) libresolv.so.2
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/iphlpapi.so"/0x64d41ed8, 2)
                                      Using emulated /opt/retropie/ports/wine/lib/wine/ws2_32.dll.so
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/ws2_32.so"/0x64d50a38, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/wininet.so"/0x64d612d0, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/mpr.so"/0x64d62470, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/dsound.so"/0x64d64a08, 2)
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/ddraw.so"/0x64d68228, 2)
                                      Using emulated /opt/retropie/ports/wine/lib/wine/wined3d.dll.so
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/wined3d.so"/0x64d68228, 2)
                                      Using emulated /opt/retropie/ports/wine/lib/wine/opengl32.dll.so
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/opengl32.so"/0x64d7a3c8, 2)
                                      Using native(wrapped) libfreetype.so.6
                                      Using native(wrapped) libfontconfig.so.1
                                      Using emulated /opt/retropie/ports/wine/lib/wine/winex11.drv.so
                                      Using native(wrapped) libXext.so.6
                                      Using native(wrapped) libX11.so.6
                                      Using native(wrapped) libxcb.so.1
                                      Using native(wrapped) libXau.so.6
                                      Using native(wrapped) libXdmcp.so.6
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winex11.so"/0x65221380, 2)
                                      Using native(wrapped) libXinerama.so.1
                                      Using native(wrapped) libXxf86vm.so.1
                                      Using native(wrapped) libXrender.so.1
                                      Using native(wrapped) libXrandr.so.2
                                      Using native(wrapped) libXcomposite.so.1
                                      Using native(wrapped) libXi.so.6
                                      Using native(wrapped) libXcursor.so.1
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/uxtheme.so"/0x654c9960, 2)
                                      Using native(wrapped) libcups.so.2
                                      Using native(wrapped) libpng16.so.16
                                      Using emulated /opt/retropie/ports/wine/lib/wine/winejoystick.drv.so
                                      Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winejoystick.so"/0x659b4398, 2)
                                      Using native(wrapped) libGL.so.1
                                      /opt/retropie/ports/claw/claw_xinit.sh: line 5:  6672 Segmentation fault      BOX86_LOG=1 LD_LIBRARY_PATH="/opt/retropie/supplementary/mesa/lib/" setarch linux32 -L /opt/retropie/ports/wine/bin/wine '/media/usb0/roms/wine/CLAWALL/2/CLAW.EXE' -fullscreen
                                      xinit: connection to X server lost
                                      waiting for X server to shut down wm_set_cursor_visibility: visible using XCreateFontCursor
                                      (II) Server terminated successfully (0). Closing log file.
                                      Hello logfile - runcommand-onend checking in here
                                      Any ideas ? :))
                                        George @shavecat
                                        @shavecat Thanks. I had seen your other post earlier and it looked like an issue with ALSA or the MIDI sequencer, but I don't see those error messages now.
                                        I wonder what might happen if you take the -fullscreen out of the script.
                                        You could also try adding the following to the script right before BOX86_LOG...:
                                        MESA_EXTENSION_OVERRIDE="-GL_ARB_vertex_program"
                                        Though I am not sure it will have much of an effect. Finally, perhaps CLAW requires DirectX to be installed. You might be able to find out more information by adding the following line to the script:
                                        WINEDEBUG=+loaddll
                                        That should log which DLLs are being loaded, and if they are being loaded natively or using Wine's Built-In version. Perhaps it might also tell you if it can't find one.
                                        Hope that helps.
                                        - George
                                        • shavecatS
                                          shavecat @George
                                          @george
                                          thanks alot again for trying help :)
                                          so add all to the scrpit
                                          now im getting this -
                                          Parameters:
                                          (==) Log file: "/home/pi/.local/share/xorg/Xorg.0.log", Time: Tue Mar  2 23:29:52 2021
                                          Debug level is 1
                                          Counted 29 Env var
                                          Debug level is 1
                                          Counted 30 Env var
                                          Debug level is 1
                                          Counted 30 Env var
                                          wine: Unhandled page fault on read access to FFFFFFFF at address 423A8348 (thread 00b0), starting debugger...
                                          00b0:err:seh:start_debugger Couldn't start debugger L"winedbg --auto 136 72" (1359)
                                          Read the Wine Developers Guide on how to set up winedbg or another debugger
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/kernel32.so"/0x6490d388, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/kernelbase.so"/0x6493e7d8, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/advapi32.so"/0x64978390, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/sechost.so"/0x64989288, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/setupapi.so"/0x649b1088, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/rpcrt4.so"/0x649b46c8, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/version.so"/0x649b4cc0, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comdlg32.so"/0x649b8890, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/comctl32.so"/0x649c2240, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/imm32.so"/0x649c2cd8, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/shell32.so"/0x649d0d98, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/shlwapi.so"/0x649e5578, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/shcore.so"/0x649e5ef0, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/ole32.so"/0x649ed000, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/combase.so"/0x649eeef0, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winspool.so"/0x649ef568, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winmm.so"/0x649fea30, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/msacm32.so"/0x649ff3a8, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/dplayx.so"/0x64a027e8, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/wsock32.so"/0x64a02f68, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/iphlpapi.so"/0x64a02f80, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/ws2_32.so"/0x64a118d8, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/wininet.so"/0x64a22148, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/mpr.so"/0x64a232f8, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/dsound.so"/0x64a25890, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/ddraw.so"/0x64a290b0, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/wined3d.so"/0x64a290b0, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/opengl32.so"/0x425bd498, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winex11.so"/0x42e92998, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/uxtheme.so"/0x434ffe70, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winejoystick.so"/0x444e1600, 2)
                                          0024:fixme:d3d:wined3d_guess_card_vendor Received unrecognized GL_VENDOR "Broadcom". Returning HW_VENDOR_NVIDIA.
                                          0024:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
                                          00d8:err:d3d:wined3d_debug_callback 0x168ce0: "GL_INVALID_ENUM in glEnable(GL_PROGRAM_POINT_SIZE)".
                                          Using native(wrapped) libvulkan.so.1
                                          Warning, function vkGetPhysicalDeviceSurfaceCapabilities2KHR not found in lib libvulkan.so.1
                                          Warning, function vkGetPhysicalDeviceSurfaceFormats2KHR not found in lib libvulkan.so.1
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/mmdevapi.so"/0x4a68b730, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/oleaut32.so"/0x4a68b730, 2)
                                          Using emulated /opt/retropie/ports/wine/lib/wine/winepulse.drv.so
                                          Using native(wrapped) libpulse.so.0
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winepulse.so"/0x4a6f0a08, 2)
                                          Using emulated /opt/retropie/ports/wine/lib/wine/winealsa.drv.so
                                          Using native(wrapped) libasound.so.2
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/winealsa.so"/0x4a70f248, 2)
                                          ALSA lib seq_hw.c:466:(snd_seq_hw_open) open /dev/snd/seq failed: No such file or directory
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/msacm32.so"/0x4c0df930, 2)
                                          Warning: Cannot dlopen("/opt/retropie/ports/wine/lib/wine/midimap.so"/0x4c0f24e0, 2)
                                          0024:err:winediag:MIDIMAP_drvOpen No software synthesizer midi port found, Midi sound output probably won't work.
                                          0024:fixme:ddraw:ddraw_surface1_Flip Ignoring flags 0x1.
                                          0024:fixme:ddraw:ddraw7_WaitForVerticalBlank iface 00133BA0, flags 0x1, event 00000000 stub!
                                          8639|SIGSEGV @0x62869070 (???(/opt/retropie/emulators/box86/box86/0x62869070)) (x86pc=(nil)/???:"???", esp=0x1cdfd4c), for accessing (nil) (code=1/prot=0), db=(nil)((nil):(nil)/(nil):(nil)/???:clean)
                                          wine: Unhandled page fault on read access to FFFFFFFF at address 00000000 (thread 00d8), starting debugger...
                                          Debug level is 1
                                          BOX86: Wine detected, WINEPRELOADRESERVE="010000000-01001a000"
                                          winedbg detected, not launching it!
                                          00d8:err:seh:start_debugger Couldn't start debugger L"winedbg --auto 32 268" (1359)
                                            George @shavecat
                                            @shavecat it's possible something might be out of date on your system. Can you run the following at the command line and send us the output?
                                            uname -a
                                            dpkg -l
                                            - George
